Question about Kicker Solo-Baric L7 S15L72 Car Subwoofer
Blown solobaric? i have two solobaric L7's 12 inch, i bought them from my friend and he said when he went to wire one up he put the wrong wires on and messed up the sub. any way to fix this problem?
  • Anonymous May 26, 2008
    COILISBURN
    Scholar:
  • 173 Answers
Maybe the amp is blown?
Posted on Sep 14, 2008
    Problem Solver:
  • 7 Answers
How did he messed up? anyways, if u push the cone of the sub down and u hear a sound like "TUN!" its most likely ur sub is irremediably damaged. The cone needs to come up perfectly as a good sub would do. I need to know exactly what ur friend did b.c it is quite weird to mess a good sub by slightly switching cables
Posted on May 24, 2008
2004 hyosung aquila 250 (gv250) bike got drenched when i went out and will not turn on, bought new battery but still no power to bike checked main fuse under leg 15a not blown, what else could it be
It sounds like something electrical, bikes are prone to this with all the semi-exposed electrical contacts.
I would start with the battery trace where the wires go to, and spray the contacts and connections good with some wd-40, then follow as many wires as you can and contacts and fuses, and even spark plug wires, trust me something electrical got wet , and it is just a matter of finding it.
This happened one time to my old Honda, and we push started it with my friends motorcycle, tied a rope from back of his bike to front of mine, I put it in 2nd gear, put in my clutch, when he took off slowly and we got up to about 5 miles an hour I released my clutch and after about of 50 ft. of spitting and spopping she started...
Jul 02, 2017 | Hyosung Motorcycles
Hello, im having problems with my Audiobahn a2300hct amp. Ive bought it from ebay, putted in my car, added my sub wirred on 2 ohm. It had pumped it for about 5 mins, and then went into a protection mode....
HELLO THESE AMPS ARE FAMOUS FOR DRAWING ALOT OF CURRENT AND IF YOU PLAY THE AMP WHILE THE VOLTAGE DROPS FOR TOO LONG YOU CAN FRY THE AMP BUT AS FAR AS THE SECOND AMP NOT WORKING AS WELL YOU MAY HAVE A PROBLEM WITH THE RCA'S OR THE OUTPUT ON YOUR HEAD UNIT WENT BAD OR YOU HAVE A BAD GROUND CHECK ALL FUSES THEN CHECK THE GROUND WIRE TO MAKE SURE ALL PAINT HAS BEEN SCRATCHED OFF AND THAT IT IS CONTACTING BARE METAL THE ONLY OTHER OPTION IS FIND A FRIEND THAT HAS THEIR WIRES RAN AND HOOK UP YOUR AMP ON THEIR SUB IF IT WORKS THEN TRY IT WITH YOUR SUB IF IT GOES INTO PROTECT THEN YOU MAY HAVE A BLOWN SUB CAUSING THE SHORT HOPE THIS HELPS THERE ARE ALOT OF OPTIONS START WITH THE WITH GROUND AND GO FROM THERE
Dec 06, 2014 | Car Audio & Video
I have this same problem
Check the power with a volt meter. The battery power, then the remote power. Also make sure it's grounded properly. bad grounds cause mayhem.
Sep 14, 2009 | Pyle BZDBP212 Car Subwoofer
I have 3 Kicker solobarics Hooked to 1 ohm, But
It likely has a blown voicecoil - or the voicecoil is damaged in a certain spot - so when you play a certain frequency it cuts out.
Aso check the integrity of the tinsel wires - if they are loose or hitting the basket, it would stop playing.
BTW - it is impossible to wire a 1 ohm load with (3) single or 4ohm voicecoils.
Be sure your wiring is correct - or the amplifier will be the next thing to go.
Thanks for using FixYa - Rating this FREE answer is appreciated.
Jul 05, 2009 | Kicker Solo-Baric L7 10'' Car Speaker
Need wiring diagram for Kawasaki FC420V engine
Send me your email and I'll send you a copy if this dosn't work...
This can be blown up too.
Apr 02, 2009 | Garden
1993 Lincoln Mark VIII has headlights that went out
CHECK THE WIRING OR THE HEAD LIGHT FOR IT TO BE BLOWN, ALSO CHECK FUSES
Feb 06, 2009 | 1993 Lincoln Mark VIII
How to wire up my kicker 12inch solobaric l5 2ohm to my zx500 2ohm mono amp. should it be ran in parallel or series? what is the best suggestion
Well first of all all solobarics are dual voice coil so you have 2 2ohm voice coils so if you wire them in parallel the sub will be pulling a 1ohm load wich would in time blow out your amp. So you want to wire both voice coils in series to produce a 4ohm load.
Oct 25, 2008 | Kicker Car Audio & Video
Cd player installation
read my other solution on the other one you posted. yes, the fuse is more-than-likely blown. but also you wired it completely wrong. look on my other solution on the other one you posted, it has the correct wiring diagram. there are 2 wires on the wiring diagram i posted that have the lights. one red is the int.light, and the other one is the turn signal wiring.
Aug 22, 2008 | 1990 Ford Taurus
My new head unit won't work
My thought is that there is a fuse blown. If you put the factory back in and that didn't light up then there is definately a fuse blown. Correct me if I'm wrong but guessing that you didn't cut the harness, by the fact that you could put the factory unit back in, you probaby don't have a problem with wiring. Aslong as you matched up wiring colors with the harnesses the wires should be fine. The next problem should be a fuse. Not all fuses blown in a way that is easy to see. Just replace the "radio" fuse in your fuse panel and give that a shot. If you still have problems get back to me. Good Luck!
-Andrew Hawkins
Jun 20, 2008 | Car Audio & Video
Kicker Solo-Baric L7 S15L72 Car Subwoofer Logo
210 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
