Question about GE Profile Harmony DPGT750EC Electric Dryer
GE Profile harmony dryer problems
There is no exhaust coming out of the back of the dryer and there seems to be no heat. I checked the power connections and they are good. Please help
  • 1 more comment
  • Oscardex May 24, 2008
    Yes the tub is turning
    The tub is turning ..thanks
  • JANETROD66 Jul 01, 2008
  • 868 Answers
Is the tub turning??Could be 2 different problems.I'll be happy to guide you through it.
Posted on May 24, 2008
G.E. Profile Harmony Dryer heats then won't heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Oct 10, 2010 | GE Profile Harmony DPGT750EC Electric...
I have a ge harmony gas dryer and the blower isn't work can this cause a no heat issue
Yes. The blower draws the air from the heat source thru the tub and out the blower exhaust. This link should help with the Blower wheel assembly they also have diagrams or illustrations of your specific model
Sep 23, 2010 | GE Profile Harmony DPGT750GC Gas Dryer
My GE Harmony dryer has stopped heating. All of the cycles work (air comes out), it just wont get hot.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 17, 2010 | GE Profile Harmony DPGT750EC Electric...
I have a GE Dryer Profile Harmony. It is several years old. The dryer is not blowing air out the back ventilation so not drying. It is making a quiet odd sound as well. When I troubleshooted I shut the...
You vent is plugged very bad. Disconnect the vent tubing and thoroughly clean it out. It will heat and dry like new afterwards guaranteed. These dryers have sensors that shut the burner off if the exhaust is not venting properly. Once its cleared out it will run perfectly again
Apr 09, 2010 | GE Profile Harmony DPGT750EC Electric...
DescrI have a GE profile harmony electric dryer model #dpgt750ec1pl. About 5 minutes into a drying cycle the blower shuts down. There is still heat but no air coming out of the dryer duct. Any suggestions?...
you should not have heat when motor stops there is a switch in the motor to shut the element off....yours is not working(you could burn your house)replace the motor.
PLEASE DO NOT TRY IT AGAIN...can't be lucky all the time
Aug 07, 2009 | GE Profile Harmony DPGT750EC Electric...
Ge profile harmony electric dryer doesn't always heat.
Remove back of dryer and take out the elament shield and replace element don't over strech it start at one side and work it around thank you for useing fixya rate me
Jul 16, 2009 | GE Profile Harmony DPGT750EC Electric...
Doesn't heat the first load
Blower motor not getting up to speed probably.
Press home.
Press help.
Press both back and my cycles and hold until service mode comes up.
It will tell you what is wrong.
Turn off when done.
Jun 29, 2009 | GE Profile Harmony DPGT750EC Electric...
GE Profile Harmony DPGT750EC Electric Dryer Logo
126 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
