Question about Olympia Standard 300 Typewriter
Problem as follows:- 1. The curser does not move to the folllowing line (below) after enter button pressed 2. How to re-set left & right margin Thank you, Husaini
  • Olympia Master
  • 3,594 Answers
If you mean that the paper dosen't space up you may have the lower feed rolls open (lever on top R. hand side)
To set the margins, go to the margin, press but don't hold the mar rel key, space or baclspace to desired position, press L. or R. margin to set it.
DickyO
Posted on Sep 28, 2010
What could cause norstar m7208 phone to not receive incoming calls
If you have lines appearing on your phone and they don't ring you need to program lines to ring. This type of programming is done from a M7310 phone. Page 323 of this manual shows how to program this on a NorthStar MICS Ver 6 phone system.
http://pdf.textfiles.com/manuals/TELECOM-F-R/Nortel%20MICS%20System%20Installer%20Guide%206.1.pdf
Enter the programming mode : Feature **266344
Password:266344
You will have 4 programming buttons on your phone, normally the 2 top left and 2 top right of the 2 vertical rows.
top left = move up one level
lower left = back
top right = select
lower right = next
once you enter the programming mode press next to "Terminals and Sets"
press select
enter your extension number
press select
press next to "Line Access"
press select
press next to "Line Assignment"
press select
use the next key to go to the line you want and use the soft-key below the display to change it from "Appear" to "Appear and Ring"
May 05, 2015 | Nortel Norstar M7208 Telephone
How do you access trouble codes on 2003 harley davidson deuce?
With the newer HD Security Systems using proximity FOBs where the key FOB needs to be close to the bike to start, this is now more important then ever. If the battery in your FOB dies and you have not set your Harley Alram Override PIN Code, you will not be starting your bike. It is just as important for those with oler Harley Davidsons with the push button alarm FOB. It you set your alarm and the battery dies before you return to your bike, again you will not be starting the bike.
If you haven't set the PIN over ride for your HD security alarm system...do it now! Here's how you do it...
(To view how to deactivate the security system with the manual PIN code, see below.
Setting or Changing Your Security System Alarm Override PIN
Button less fobs (Smart FOB)
1. Select 5 digit code ( each digit being a 1 thru 9) and record it on the wallet card in the owners manual.
2. With an assigned FOB present, turn IGN key ON - OFF - ON - OFF - ON
3. Press Left turn signal switch 3 times.
4. Press Right turn signal switch one time and release.
*Turn signals will flash 3 times. Current PIN will appear in the odometer. The first digit will be flashing.
5. Enter first digit (a) of the new PIN by pressing left turn signal (a) times.
6. Press right turn signal 1 time and release.
*The new digit (a) will replace the current in the odometer window.
7. Enter second digit (b) of the new PIN by pressing left turn signal switch (b) times.
8. Press right turn signal 1 time and release.
*The new digit will replace the current in odometer window.
9. Enter the third digit (c) of the new PIN by pressing left turn signal (c) times.
10. Press the right turn switch 1 time and release.
*The new digit (c) will replace the current in the odometer window.
11. Enter forth digit (d) of the new PIN by pressing left turn signal switch (d) times.
12. Press the right turn switch 1 time and release.
13. Enter the fifth digit (e) of the new PIN by pressing left turn signal (e) times.
*The new digit (e) will replace the current in the odometer window.
14. Press the right turn switch 1 time and release.
15. Before the module rearms, turn ignition key to OFF.
* The odometer will return to mileage display.
**Turning the ignition to OFF stores the new pin in the module.
Push Button fobs
4. Press button on fob twice
5. Enter first digit of the new PIN by pressing left turn signal until the desired number appears.
Press button on fob twice to enter number.
6. Enter second digit of the new PIN by pressing left turn signal until the desired number appears.
7. Enter third digit of the new PIN by pressing left turn signal until the desired number appears.
8. Enter forth digit of the new PIN by pressing left turn signal until the desired number appears.
9. Enter fifth digit of the new PIN by pressing left turn signal until the desired number appears.
Turning the ignition to OFF stores the new security PIN.
Using the Security Alarm PIN Override to Start Your Harley Davidson
1. Turn the IGN key to IGNITION and immediately hold both turn signal switches until 5 dashes appear in the odometer window.
2. Enter the first digit of your PIN (a) by pressing the left turn signal switch (a) times.
3. Press the right turn signal switch 1 time to move to the next digit.
4. Enter the second digit of your PIN (b) by pressing the left turn signal switch (b) times.
5. Press the right turn signal switch 1 time to move to the next digit.
6. Enter the third digit of your PIN (c) by pressing the left turn signal switch (c) times.
7. Press the right turn signal switch 1 time to move to the next digit.
8. Enter the forth digit of your PIN (d) by pressing the left turn signal switch (d) times.
9. Press the right turn signal switch 1 time to move to the next digit.
10. Enter the fifth digit of your PIN (e) by pressing the left turn signal switch (e) times.
11. Press the right turn signal switch 1 time to move to the next digit.
12. Press the right turn signal switch one time and the security system alarm is turned off.
May 20, 2014 | 2003 Harley Davidson FXSTDI Softail Deuce
Phone not ringing in normal mode
I believe this is a programming issue.
To change the ringing assignments on extensions enter programming mode by pressing Feature **266344 and password 266344 if it hasn't been changed. You have to do this from an M7310 phone. The top two buttons on each side will move you through programming. The top right button is the SHOW button and the button below it is the NEXT button. The top left button is the HEADER button and the button below it is the BACK button.
Your first category should be TERMINALS & SETS. Press the SHOW button and using the dial pad enter the extension number. The display should show the extension number or name. Press SHOW three times and the display should show LINE ___.
With options to SCAN or LIST. Pressing SCAN will show the lines assigned to the extension. Use the CHNG option to change how the line is on the phone. RING ONLY - UNASSIGNED - APPEAR ONLY - AND APPEAR & RING. Change the lines you want to ring in NORMAL DAY MODE to APPEAR & RING for this extension and press SCAN to move to the next assigned line. Use this same method for any extension you want to change the ringing on.
Dec 18, 2013 | NorStar M7310 Corded Phone
W580i gprs setting vodafone postpade
Settings - GPRS WAP
Sony Ericsson W580i GPRS WAP Pay & Go settings
Please note all steps must be completed to ensure the settings are correctly configured.
Please ensure that when entering 'O2' into the settings that the letter 'O' is selected not a zero.
The W580i has a central navigation button (Navi key) and two soft keys slightly above this.
1. Press 'Menu' (right softkey).
2. Highlight 'Settings' and press 'Select' (left softkey).
3. Scroll to the 'Connectivity' tab by pressing the Navi key to the right.
4. Scroll to 'Data communication' and press 'Select' (left softkey).
5. Highlight 'Data accounts' and press 'Select' (left softkey).
6. Highlight 'New account' and press 'Add' (left softkey).
7. On the 'Account type' screen, highlight 'PS data' and press 'Select' (left softkey).
8. On the 'Account Name' screen, enter 'O2 WAP GPRS', press 'Continue' (left softkey).
9. On the 'New PS data' screen, highlight 'APN' press 'Edit' (left softkey), enter 'payandgo.o2.co.uk' and press 'OK' (left softkey).
10. Highlight 'Username' press 'Edit' (left softkey), enter 'payandgo' and press 'OK' (left softkey).
11. Highlight 'Password' press 'Edit' (left softkey), enter 'password' and press 'OK' (left softkey).
12. Press 'Save' (right softkey).
13. Press the 'back' arrow key (key directly below left softkey) 2 times.
Activate GPRS settings:
14. Highlight 'Internet settings' and press 'Select' (left softkey).
15. Highlight 'Internet profiles' and press 'Select' (left softkey).
16. Highlight 'New profile' and press 'Add' (left softkey).
17. Highlight 'Name:' press 'Add' (left softkey), enter 'O2 WAP GPRS' and press 'OK' (left softkey).
18. Highlight 'Connect using' press 'Select' (left softkey), highlight 'O2 WAP GPRS' and press 'Select' (left softkey).
19. Press 'Save' (right softkey).
Change GPRS settings:
20. Highlight 'O2 WAP GPRS' and press 'More' (right softkey).
21. Highlight 'Settings' and press 'Select' (left softkey).
22. Ignore 'Connect using'
23. Highlight 'Use proxy:' press 'Select' (left softkey), highlight 'Yes' and 'Select' (left softkey).
24. Highlight 'Proxy address:' press 'Edit' (left softkey), enter '193.113.200.195' (to bring up the number press the number until it appears. Add the dots with the '1' key) and 'OK' (left softkey).
25. Highlight 'Port number:' press 'Edit' (left softkey), enter '8080' and press 'OK' (left softkey).
26. Highlight 'Username' press 'Edit' (left softkey), enter 'payandgo' and press OK (left softkey).
27. Highlight 'Password' press 'Edit' (left softkey), enter 'password' and press OK (left softkey).
28. Press 'Save' (right softkey).
Change Homepage:
29. Highlight 'O2 WAP GPRS' and press 'More' (right softkey).
30. Highlight 'Advanced' and press 'Select' (left softkey).
31. Highlight 'Change homepage' and press 'Select' (left softkey).
32. Highlight 'Name:' and press 'Edit' (left softkey). Hold the 'c' button (to the right of the Navikey) to clear any text in the field. Enter 'O2 ACTIVE' and press 'OK' (left softkey).
33. Highlight 'Address:' and press 'Edit' (left softkey). Hold the 'c' button (to the right of the Navikey) to clear any text in the field. Enter 'http://wap.o2.co.uk' and press 'OK' (left softkey).
34. Press 'Save' (right softkey).
35. Press the backward arrow key (key directly below left hand soft key).
36. Highlight 'O2 WAP GPRS' and press 'Select' (left softkey).
37. Press the 'back' button (to left of Navi key) 3 times to return to the standby screen.
Feb 19, 2013 | AT&T Sony Ericsson W580i Cell Phone -...
How to set the time on an adidas sports watch ADP6034
1.
In time mode, press and hold A for 2 seconds to enter time setting.
2.
Press C to increase setting value. Press D to decrease setting value.
3.
Press B to enter next setting field.
4.
Press pusher A to exit setting mode.
From Left top button A and following B & right top C & D bottom.
Dec 27, 2012 | Watches
How to set date and time
Set the date and time:
The current date and time are shown in the display when the machine is on and ready for use (Ready mode). The date and time will be printed on all faxes you send.
1. Press Menu.
2. Press Left Right Arrow to choose SET DATE & TIME and press Start/Enter.
3. Press Start/Enter when the display shows Date Format.
4. Press Left Right Arrow to select either Europe (day month year) or USA (month day year) and press Start/Enter.
5. Press Start/Enter when the display shows Date & Time.
6. Set the date and time. You can move the cursor by pressing Left Right Arrow.
7. Press Start/Enter when the date and time are correct.
1-AM 2-PM will display.
8. Press 1 or 2.
Dec 07, 2010 | HP 1050 Plain Paper Inkjet Fax
Zone 2 volume control
Sounds like the Zone 2 amp was set to external, see below for instructions on setting it back up.
How do I setup Zone 2 on the RX-V661 Using the internal power amp.
Setting the RX-V661 remote control to operate Zone 2
1. Using a ballpoint pen or similar object and press the Code set
button. The Transmit indicator on the remote should flash twice.
2. Using the numerical key pad on the remote and key in 9992, the
Transmit indicator should flash.
You will now need to assign the receivers internal amp for Zone 2.
1. Set the remote control selector to AMP. Selector is on side of remote.
2. Press the Set Menu Button.
3. Arrow down to Manual Setup.
4. Press the Enter button.
5. Arrow to the Sound Menu option and press Enter.
6. In the Sound Menu arrow to Speaker Set and press Enter.
7. Arrow to the EXTRA SP ASSIGN and select ZONE2. This may require using LEFT or RIGHT arrow.
8. Press the Return button to exit out and return to the Manual
Setup.
Apr 05, 2009 | Yamaha RX-V661 Receiver
Change name on a Nortel M7324
1. Press the Rls button then ** FEATURE 266344 (CONFIG)
2. Password is 23646 (ADMIN) The display reads Terminals & Sets
3. Press SHOW ans enter the Extension for which you want to enter a name.
4. Press SHOW, again
5. Press the NEXT key until the display reads NAMES at the top left corner.
6. The bottom right corner reads CHANGE, press the far right soft key.
7. To move from one letter to the next use the far right and far left soft keys or the # key.
8. When you are finished Press next.
9. Press the HEADING key to get back to TERMINALS & SETS and start again!
Navigation Keys: Line 1 = HEADING Speed Dial = SHOW
Line 2 = BACK Last No. = NEXT
This can only be done from the main handset and only one at a time. The Soft Keys are the three small buttons right bellow the screen.
Jan 28, 2009 | NorStar M7324 Telephone
Toshiba TP50H15
You can adjust the lines and make them straight. You can also in the same process, make them line up.
1. With the TV on, press the mute button the remote control so that you have picture but no sound.
2. With remote in one hand (holding it as far from the TV as you can but still be able to reach the TV with your other hand), press and hold the mute button again, with the other hand, using the control panel underneath the screen, press the menu button on the TV set.
You will notice an "S" on the screen on the right hand side about 2/3 from the left, halfway up the screen (If you did this right).
This means you are in service mode.
With the remote, curse right only once and you will have some information displayed in the upper left. The top line is Item, the one underneath is Data.
Press "7." This will display the built in cross hatch pattern. You can move the line around with the directional circle located at the center of the remote. Using the "3" button, you can decide which color to move. To move the curser to a new location, The number pad doubles as a direction key pad. (2-up), (4-left), (6-right), (8-down). To simplify the process, you can eliminate the red or blue or green lines and only focus on one color at a time. "0" will shut on/off the green line. "100 button" will shut on/off the red line. "CH RTN or Enter will shut on/off the blue line.
"7" will exit the process as well as get you there.
Power off when you are done and turn back on.
Repeat as needed.
Jul 05, 2008 | Toshiba 50HX81 50" Rear Projection...
How to change the time on screen
generic for all phones... the standard way to change the time and show it on screen is simply going to the settings and look for time settings... in here, you can actually change the time, the date , and the year and you can also change the time format form 12 hour to 24 hour.
Apr 08, 2008 | Lands Phones
Olympia Standard 300 Typewriter Logo
Top Olympia Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
Are you an Olympia Office Equipment and Supply Expert? Answer questions, earn points and help others
