Question about Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune washer MAH550B sounds like water is in the barrel if I manually spin the barrel. Is this normal?
  • 1122 Answers
SOURCE: washer machine maytag neptune front load
take the back panel off,see if the belt has broke if not,check your motor control board for burn spots ,front bottom right inside washer,if not that then your motor has gotten weak and will not turn the drum,let me knoe what you find-mike
Posted on Jul 12, 2008
dh1200s
  • 335 Answers
SOURCE: I need an instruction manual for Maytag topload washer Neptune TL
Get the Service Manual this will help you diagnose issues with this washer.  I found a Service repair manual on this site search for this; FAV6800 Manual.  Check the postings and you will find a URL to the manual.
From another member a step by step to dump water from machine in diag mode  ""One other thing I learned for those of you who don’t want to bail out the water in the tub. If you want to have the machine drain the excess water without bailing this should work. Turn the machine off and make sure the "locked door" light goes off. Then hold the "Spin" and "Enviro Plus" buttons at the same time for 3 seconds. "00" should then show up on the display. Then hit the "Delicate" button, then the “Pre-soak” button. This should activate the pump and get all the water out. Once the water is out hit the off button. You then may want to try the Spin cycle alone. These directions can be found on the Troubleshooting Manual found folded up behind the rear panel of the machine where the main electrical circuit board is located.""
Posted on Dec 15, 2008
SOURCE: My Maytag Neptune washer won't spin during the spin cycle.
I'm having the same problem...Does it say LR?
Posted on Jul 20, 2009
milten1
  • 1304 Answers
SOURCE: Maytag Neptune Front Load Washer Model MAH4000AWW low last spin
two problems here,
your shaft seal is running on its last leg
the sound is unmistakeable and always described the same...
the water issue, you probably have a trickle leak through the cold water valve
the mixing valve is quite an easy repair, but I would have to say with all honesty, it probably time for a new machine
the hub seal is a tub replacment call
2 hrs of labor if hes good
and the tub runs around 500.00 dollars
sory for the bad news
Posted on Oct 10, 2009
SOURCE: I have a maytag neptune washer model# mah300aww.
Your tub seal leaked water into the tub bearings causing them to fail. Maytag only offers the bearings as part of the outer tub assembly and the repair can be pricey. A little research may turn up a service company in your area that has the tool to replace only the tub bearing. The repair becomes more affordable that way.
Posted on Jan 25, 2010
Testimonial: "Thank you. You gave me enough evidence now to get a new washer. Any recommendations? Most reliable front loaders."
My maytag neptune spins water out, the tub is empty but when you turn the tub manually you can hear water sloshing and the clothes smells moldy after washing
There will always be some residual water left in the outer tub after draining. This is normal for most washers. Purchase a container of Oxy-clean and cycle the washer a few times using hot water settings with a half-cup of Oxy-clean added to each cycle. This will help remove any organic matter left behind that might be causing odors.
Oct 15, 2014 | Maytag Neptune MAH5500B Front Load Washer
Spin cycle does not engage
UPLOADING OR FRONT LOADING WASHER..........CHECK ITS BALANCE LEVELS.
Feb 24, 2012 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune washer always has water in the drum after wash is done? Any ideas? I can hear lots of water left in the washer when I spin the drum manually and of course it has a moldy smell having water...
The liquid is a saline solution which is hermetically sealed in the front balance ring on the spinner. It is there to reduce vibration and acts like a gyroscope when the spinner revolves. Good sound to hear when you spin the basket. The smell can be gotten rid of by using a washing machine cleaner like tide.
Dec 26, 2010 | Maytag Neptune MAH5500B Front Load Washer
Water trapped below the barrel
It is normal to have residual water in the drain lines and drain pump following a wash cycle. This is the low point of the drain cycle and gravity will ALWAYS cause some water to be there. As long as the water is not visible in the spin basket, and the washer is properly draining during the wash and rinse cycles, you have nothing to worry about.
If you have any questions, please post back and let me know. I hope this is helpful to you.
Apr 23, 2010 | Maytag Neptune MAH5500B Front Load Washer
Why isn't the maytag neptune draining? when you spin the barrel you can hear water?
if you do not see water in the tube and the clothes have spun out enough to go into the dryer when the washer cycle finishes the washer has drained out all of the water the water you hear in the tub when the door is open and you spin the tub with your hand that liquid is in the sealed balance ring , that is a sealed channel around the front of the tub to help the machine stay balanced it does not come out
Apr 04, 2010 | Maytag Neptune MAH5500B Front Load Washer
Removed both water pump hoses, No blockages drum still has water init. Is this normal? Won't drain and go to final spin. Pump clean and spins free. Maytag Neptune MAH5500B
Water pressure switch adjustment or clogged. Check the small connecting hose to the switch body.
Final spin command signal generates from this part only.
Mar 30, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune MLG2000AWW does not turn off at end of spin cycle
d sounds as if your having a timer issue here. not recognizing the end of cycle and entering a new one ( bad timer).. as far as time of unlocking this is normal, theres a wax motor holding the door shut for i believe 3 min's.. and the water sloshing sounds is also normal they use a "water filled" balance ring around the perimeter of tub to help with the overall balance of machine
Mar 20, 2009 | Maytag Neptune MAH5500B Front Load Washer
Standing water in the barrel
Unfortunatly this is normal for the neptune washers and there is no solution other than to use the machine often so the water does not stagnate.
Feb 27, 2009 | Maytag Neptune MAH5500B Front Load Washer
Water left in barrel (not the tumbler)
If you can't see any water and just hear it, this is completely normal. This is a front load washer and has a special cover of the inner tub basket. This cover contains some water that has been sealed in at the factory to keep the load balanced while it is spinning.
Nov 25, 2006 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
