Question about HP Officejet 5610 All-In-One InkJet Printer
HP OFFICEJET 5610V No scan options
What do you mean the driver is gone? How can We replace the driver? Will it fix the " no scan options" error message and let us scan again?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 93 Answers
No scan options occur if the digital imaging monitor is not running on the taskbar of the computer. Once check whether the digital imaging monitor is running or not ans try to scan from the HP Solution center. If you are able to scan from HP Solution center, then search for the file hpqtra08.exe and run it and then try to scan from the all-in-one.
Posted on May 27, 2008
HP Officejet 5610v: Sent document to print. Somehow the settings were set to print offline, so nothing came out. I "unchecked" the "print offline" option. I tried to...
This Utility program resolve all the printing issue for HP Printers ( Network and USB connection )
This Utility will Resolve :
1. Check Connectivity between the Pc/laptop and HP Printer
2. Check if there any Documents stuck in Queue
3. Check if all the software/Drivers are correctly Installed
4. Check if the HP Printer icon is the default icon to print
5. Will Resolve Printer Spooler Issue and few more issue
This Utility program will fix all these issues.
Download the file on Desktop and Run the program ( Ex. File name = HPPDU.EXE )
Click Here to download the Utility and save on Desktop location
Run the HPPDU file and follow the instruction on screen to fix.
Regards,
Ron
* Please rate this solution with Thumbs up and comment to help us improve providing support
Feb 21, 2011 | HP Officejet 5610v All-In-One InkJet...
My HP Officejet 5610v All-in-One prints and copies but will not scan a document... WHY?
Please reload all software and drivers - once done try it ... it should work.
Thanks
Aug 26, 2010 | HP Officejet 5610v All-In-One InkJet...
New OS can't find software for Officejet 5610v
Download the driver/software from HP website. Just type the model number of your printer
May 24, 2009 | HP Officejet 5610 All-In-One InkJet...
NEED DISK FOR OFFICEJET 5610V I CANT DOWNLOAD THIS ON MY COMPUTER acer vista
the CD you have is fine for 5610, HP printer drivers are desgin for printer series . ex: 56xx, 4000, etc. yo will not find driver for 5610, but 5600 series driver.
May 22, 2009 | HP Officejet 5610 All-In-One InkJet...
Hp officejet 5610v all in one insallation software for windows vista
Try this link. It is the full intall file for the all in one being run on a Vista Machine. It worked fine for my installation.
Muck around on the site for a bit, and you can also find the same install file for Windows XP.
Good Luck
http://hp.driversdown.com/hp-drivers-download/HP-Officejet-5605-5610-5610v-5610xi-All-in-One-Driver-080.001.237.000-for-Windows--Vista-(32-64)_9168.shtml
Jul 22, 2008 | HP OfficeJet t45 All-In-One InkJet Printer
Hp officejet 5610v all-in-one printer
Hi i'm an EX HP employee give the model number and i'll give you the link
you can also go to www.hp.com and selct the option Drivers on the bottom left..
aj10@aol.in
thanks
Jun 04, 2008 | HP Officejet 5610 All-In-One InkJet...
No scan options- HP Office jet 5610v
Ok - the reason this error pops up is because there is a software issue going on. If the software is correctly installed you will see options for where the scan will go in the computer.
Having said that there are several things that can cause a problem between the printer and the software;
1) You are connecting the printer by USB to router - you may print but will never be able to scan as this is not a networkable printer. Connect it directly to your computer and recomplete the setup portion to configure the scanner.
2) You have not finished the setup. At the end of the installer you can setup the scanner but if you skipped this step you will have to redo it in order for it to connect. Click on the device manager in your dock and then next to information and settings there will be a little wheel. Click on the wheel and go to setup assistant. Complete the assistant and try to scan.
3) The printer is not grabbing the new software options - leave the printer turned on but unplug the power cord and wait for 30 seconds. Plug printer back in - when you do this it should initialize and will look to the mac for changes and the options should load.
4) Software missing - You MUST have the software for the printer installed for scanning function. Adobe and other programs cannot replace it - it has to be installed.
5) Software is corrupted. Uninstall the software (uninstaller is under applications in the HP folder) and then download and install the most recent full feature software and drivers for your operating system.
6) If all these steps fail you may have an issue with your computer and it's TWAIN drivers.
May 24, 2008 | HP Officejet 5610 All-In-One InkJet...
If you get the error while trying to scan with your HP 5610v All-In-One, the easy way to scan from your printer is to click on start, go to Paint and then File, the option "From Scanner or Camera" will come up.. click there and poof - you can scan anything you want and save it where you want... Problem solved!! good luck!!!
HP Officejet 5610 All-In-One InkJet Printer Logo
229 people viewed this question
Seeker5211
Seeker5211
