Question about LG 37LP1D 37 in. LCD Television
The screen has dark shadow in the corners - LG 37LP1D 37 in. LCD Television
I have a dark shadow square 3"x3" in the upper left corner of my screen. Any thoughts on the cause of this?
Darkness in the display, specifically a localized discoloration is a fault in the display/monitor itself. If there was an issue with the motherboard or graphics processor, it would affect the entirety of the display.
The display is obviously still working aside from the dark spot, but this is often an indicator that entire display may soon fail.
Regards,
Dan
IT Professional
May 04, 2011 | Computers & Internet
Dark shadow to the immediate right of my texts
Problaly you had a magnet near by that caused that Dark Shadow.
Feb 10, 2010 | HP Pavilion F50 17" Flat Panel LCD Monitor
DARK SHADOW EFFECT UPPER CORNERS OF SCREEN
I would check for dust particles before I attempted any type of repair on the unit.
Dust particles will appear as dark spots that are larger than the size of an individual pixel. It must first be determined if the particle(s) are on the LCD panels or the screen.
May 27, 2009 | Sony KDF-E42A10 42 in. LCD Television
Dark shadow on lcd tv We have a Samsung LCD and it has a dark shadow near the top of the screen. It looks like a storm cloud on the TV. It looks like it may be starting to do the same thing at the...
u need to replace the tv backlight. it can be done by urself but its kinda complicated its better to just tak eit in to a repair man. shouldnt be that costly.
Apr 08, 2009 | Samsung LNT3242H Television
Flashing shadow area on olympus e500
While in playback mode, image is blinking, the word shadow appears in lower right hand corner, use the info button repeatedly until all disappears and image is pure.
Mar 25, 2008 | Olympus EVOLT E-500 Digital Camera
Dark bottom half of screen and dark patch in corner
Thanks for the picture - that's a big help.
It looks you have the dreaded light tunnel collapse common to all LG1.gif DLP TV's. Inside the light engine there is a square tube made up of four mirrors. These mirrors deform and crack with the heat of the lamp. They fall down over the light aperture and cause a shadow of varying degrees. It is fixable now at a realistic price ( used to have to replace engine) as LG have made the parts available. It would take a competent tech around three hours to complete or if you are technically minded you could do it yourself. I hope this helps.
Hope Ya Fix It!
Jan 24, 2008 | LG RU-44SZ51D 44" Rear Projection...
Dark area on screen
sound if u might have what is called a crt burn
Jan 03, 2008 | Samsung HLN4365W 43" Rear Projection...
Dark spot in bottom right corner of screen
Is this a DLP or a conventional 3 tube projection tv?
Sep 15, 2007 | Hitachi 50V710 50" Rear Projection...
LG 37LP1D 37 in. LCD Television Logo
137 people viewed this question
Computer Repairing
Computer Repairing
