Question about ViewSonic VP181 18.1" LCD Monitor
I have a Viewsonic VP181 monitor that has a intermittent problem. When I start the computer, the power light on the power button is yellow and there is no display. If I unplug the monitor from the running computer, power off the monitor and then power it back on, the power light is green. I can plug the monitor back into the computer and the monitor works. Any suggestions as to how to fix? Thanks. Bill
  • ViewSonic Master
  • 3,866 Answers
You might need to replace the board that has the d-sub connector on it, ebay might have that, this is a fairly used monitor if you where to have it replaced by a repair shop it might not be worth your wild on it but its up to you. i price this board around
$35-50 bucks respectively.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Sep 27, 2010
Testimonial: "Thanks. I'll start looking for a new monitor cause I didn't pay that much for the one that is having the problem. I appreciate your reality check!"
  • ABRsvcs Oct 08, 2010
    The light on the monitor indicates that it is in power saver mode. This means that a signal isnot detected at the video input and the monitor shuts down to conserve power. When the computer starts up, the signal should be detected and the monitor should come on. There is a failure in the signal detection circuit. This can be as simple as a bad solder connection that is creating increased resistance inside the monitor or it can be a failure of the detection circuit itself. If you have any electronics experience, try resoldering the connections at either the VGA connector or at the connection point wihtin the monitor at the end of the video cable. Quite often there is a cable that connects the external VGA connector to a PC board via a short cable terminated in a flat connector.
    Hope this helps,
    Dan
Viewsonic VX2640W was running with the screensaver on,then suddenly went solid white. Turned off for thirty minutes then back on with same result. Unplugged from computer and turned on. Still turn
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Feb 03, 2014 | ViewSonic VX2640w LCD Monitor
ViewSonic monitor is starting to go dark
See if your monitor has a brightness control. The manual is here...
http://www.viewsonic.com/us/support/downloads/search_user_guides/
Nov 04, 2013 | ViewSonic VA1931WA LCD Monitor
Screen goes black or pixelates
Aug 18, 2013 | ViewSonic VX715 17" LCD Monitor
I have VIEWSONIC VA1912w-4 monitar. When i start power of my monitor the monitor light blinks and keeps on blinking. the monitor remains blank and some time from 5 minutes to 15minutes it starts.what is...
bharapatel5, You will just need to resolder one "thermally intermittant" poor solder connection inside the monitor. Go YOUTUBE and watch video clips, then do very close inspection of the "switch-mode-power-supply/ccfl inverter supply" printed circuit board. Inspect for "swollen" electrolytic filter capacitors that may need replacement also!!! Do more research here on fixya in the fixya profiles of "budmrtn" "buddymc" "12fixlouie" for lots more info that you will need. 12fixlouie
Dec 20, 2010 | ViewSonic VA1912wb Monitor
Viewsonic vx2835wm monitor, in DVI mode connection, altough getting signal from the PC(Other monitor connected and tested for graphic card problem-No graphics card problem!!) , Prompts "No input-signal"...
You will need to change the resolution of the screen on the computer to 800-600 and the bit to 24bits or 16bits, to do this right click on the windows screen, and click properties, goto settings.
You should see a slider at the bottem left of the screen to adjust the resolution, and a drop down bar on the other side for the bit rate. This should solve the problem, also you could open the scond screen also in the display properties, and drag what you need to see on the screen to that screen, you will know what i mean when you open screen 2 it just expands the desktop. hope this helps.
Aug 21, 2010 | ViewSonic VX2835wm Monitor
Won't power on
check your power supply maybe its too old to work for your computer. If the power supply is not the problem try checking the cables, there might be loose connections.
Also , you should check the power source of your home, maybe you have a low voltage and that wont turn on your monitor.
Jan 03, 2010 | ViewSonic VP181 18.1" LCD Monitor
ViewSonic VX900 was working fine. I was in the midst of shutting down the computer/monitor and the electricity flashed off, then back on. My monitor turned white, I played with trying to get the green...
The power board in your monitor was damaged when the power was interrupted. We can do the repair for you if you are interested. The repair charge runs $35 + return shipping.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Sep 18, 2009 | ViewSonic VX924 19" LCD Monitor
I have a VeiwSonic Monitor model VA712b that went blank.
sell it.. the product and sevice from viewsonic in my opinon sucks nothing but problems tv less then a year old want to ship it back and forth to fix it piece of s**t
Feb 26, 2008 | ViewSonic VA712B 17" Flat Panel LCD...
ViewSonic VP181 18.1" LCD Monitor Logo
111 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
