Question about Goldstar Heating & Cooling
My A.C. unit is not cooling my room like it was a couple of days ago it just throws out air that is not cold and when I turn it on it the air that comes out on cool mode is like the air that comes out in fan mode. I cleaned the filter and disconnected from the receptacle. What could the problem be?
  • Goldstar Master
  • 43,501 Answers
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
Posted on Sep 27, 2010
Why can't I lower my honeywell 8500 below 67 on cool?
With a two story house you have to be aware that cold air flows downwards so any cold air coming from an ac unit will flow downstairs( normally down the stairway) so unless you can close off the down stairs then the up stairs unit will be cooling downstairs as well. Ac units have a thermostat located in the air intake and it cools until the cold air has risen to that point. In effect the space above the ac unit will be hotter than the floor. Knowing how they work ,you can see that the upstairs unit will never reach the set temperature because the cold air is continually heating from the house and will never get to the top thermostat.
So your solutions are
1-- fit controls that restrict the cold air from leaving the upper floor (Doors)
2--don't run the upper ac unit unless you are living up there (waste of money
)3 place an ac in each upper room and keep the room door closed
Aug 12, 2014 | Heating & Cooling
Not staying cool
sounds like it is either low on Freon or the compressor is going out. The blowing ice cold is an indicator that it may be freezing up because the low Freon. when it stops blowing cold, turn it to fan only mode and see if it gets colder again. If that is the case then the unit is low on freon and freezing up. I know that sounds confusing but that is how AC works. The low freon pressure means the gas is expanding too fast and the air flow cannot take up the cold from the evaporator fast enough. Turning the compressor off and keeping the fan on will alow the room air to take up the cold.
Apr 22, 2014 | Frigidaire FAM157S1A Air Conditioner
I have a 2006 Gulfstream Cavalier 8'x 32' Fema Travel Trailer with a Dometic Duo Therm AC unit which I have recently replaced the fan motor on. Had the dealership bench test motor prior to lea
There is ice forming on the evaporator coils. This is either from a low freon charge or a leak in the seals or windows and doors. Could also be that the drains are not working and water is building up and freezing
Oct 10, 2012 | Dometic Heating & Cooling
Purchased a couple of months ago. No problems with operation or cooling. Does a great job of colling the room and even risidual rooms on that level. Turned unit off while on vacation for one week. Upon...
When the environmental temperature is lower than the set range, the display will indicate "LO".
Lowering the temperature you have it set on, should resolve the problem.
Hope this helped you and thanks for choosing FixYa.
Aug 21, 2011 | Haier CPRB07XC7 Portable Air Conditioner
Friedrich Wallmaster is not throwing cold air.
I have the same problem - bought mine 4-5 years ago been suffering ever since - spent so much money on Friedrich and still using fans. Piece of ****.
Aug 21, 2009 | Friedrich M18CF Split System Air...
Our air conditoner is throwing out cold air but the room is very hot the fan is blowing out cold air too it is not cooling the room down.
sounds like it does not have enough BTUs
so many BTUs can cool somany cu-feet if sealed space
Like leaving the freezer door open too seal that room
Jul 31, 2009 | DeLonghi Pinguino PAC-290 Air Conditioner
No longer blows cold air and the unit is only 15 months old
First please clean the air filter and ensure that there is no dust settled on the filter which could chock the circulation of air.
To throw cool air the unit got to **** the air from the room and in case the air filter is blocked with dust then there will be no cooling at all.
Please ensure the thermostat knob is turned to the desired cooling level and try running the unit.
Ensure there is no escape route for the cool breeze.
Minimize the frequency of the door or window opening in the area to retain cooling efficiency.
I am sure your unit will work on taking the above precautions before operating it.
Jul 08, 2009 | Haier CPRD12XH7 Air Conditioner
Danby DPAC10061 portable air conditioner problem
you may have a factory defective unit that is not turning off the anti-frost heating coil (I have assumed yours contains this item based on your problem description). I would trade it in for a new unit, again assuming you have a warranty or the store offers a good in-store return policy. If this plan bombs, then open the unit and find the heating coil near the cool side of the radiator fins. then disconnect the power wires to the heater and prevent electrical short to wires with quality electrical tape.
Jul 06, 2007 | Danby DPAC8020 Air Conditioner
Lack of cooling
Check for blocked filters or coils, both on the hot side & the cool side. It is possible that either is blocked by airbourne dust or debris. This is common in areas with lots of poplar trees.
Jul 05, 2007 | Maytag NMPEB08F2A Air Conditioner
Dehumidify mode also cools
Some units do cool/dehumidify only im afraid why cant you let the unit dump its hot air into the room then it wont heat or cool the room?
Sep 03, 2006 | Danby DPAC9031 Silhouette 9,000 BTU...
Heating & Cooling Logo
112 people viewed this question
Top Goldstar Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
John Tripp
John Tripp
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
