I have a Panasonic TV model CT-20G5B, manufactured en 2000. I dont´t have any picture and sound, only snow, the display show the channel I´m select, the external input (video and audio), work good, the problem is only en the channe, Any fixes?. Thanks a lot. Francisco Rodriguez
3 Suggested Answers
SOURCE: necesito el diagrama del modelo CT-27S2S CHASIS:AEDP224
amigo te puedo dar fotos de la pcb, esque tengo uno con un problema de vertical y video y estoy igual que tu no tengo el manual si te sirve de algo mi correo es electroeljunquito@hotmail.com saludos
Posted on Apr 24, 2009
nicknovikov
  • 100 Answers
SOURCE: I have a Panasonic TV, model CT-20G5B,
capacitors in vert.output.
Posted on Jun 28, 2009
I have a Panasonic TV CT-34WX50 every time I change channels
it sounds that have problem in the chroma board ( video board ) a small board that hooked up in the neck of the picture tube. if the color is greenish the cause is dead in red video driver transistor or open resistance. hope this can help good luck.
Jul 26, 2012 | Panasonic CT-34WX50 34" TV
I hv PANASONIC COMMERCIAL TV - MODEL CT 2522 HE. I am facing problem to preogramme all channels.when I open MANU with univeral remote control,or panasonic master remote,I donot find option for PROGRAMME...
I am facing problem to preogramme all channels.when I open MANU with univeral remote control,or panasonic master remote,I donot find option for PROGRAMME CHANNEL.SOME OF THE CHANELS SKIP,I want all channels to be programmed..pls give the solution
Nov 24, 2009 | Panasonic CT25G7 25" TV
TV comes on with snow and clears up after 10-15 mins
Their is no more you can do.
You need a professional.
Stop using the TV until it is repaired.
Call the manufacturer to find you nearest authorized service center.
MR. TV Sales & Service Inc
Milwaukee Wisconsin 53405
(414) 762-8600
Established 1974
Mar 24, 2009 | Pioneer SD-P62A3-K 62" Rear Projection...
CT-36SL14 powers on with clicking noise.
Sorry, but you've been had. From what you describe, it sounds like the set is going into high voltage shutdown. It does this if picture tube voltage goes over limits that might cause excess x-ray radiation, and the only way to clear the shutdown is to unplug the set. A number of things might be causing the problem, including a bad picture tube which would exceed the cost of a new TV. Without checking the set myself I couldn't suggest anything specific, and there are few repairs you would be able to try for yourself without the tools and some experience.
The only "solution" to this, I think, is to try to get your money back from the seller as the item was misrepresented, and apply it toward a set you can see working before you buy it.
Dec 07, 2008 | Panasonic CT-36SL14 36" TV
Panasonic TV-Sound but no picture.
    According to the symptoms, There is a problem in vertical out section.Just check it there must be a capacitor that has been burst or leak.And second one reason could be the malfunctioning of vertical IC.Which is also in the vertical section.
Thanks for using fixya.
Dec 01, 2008 | Panasonic CT-27D12D 27" TV
Panasonic tv old model
curve picture and auto shutdown
May 10, 2008 | Panasonic CT-20D11 20" TV
No sound on my 8year old panasonic tv.
It worked fine yesterday. Sound on all channels. Sometimes the picture goes black on channel 6. We can get it back by going up one channel, then back to 6. it is due to cable signal ie weak. now there is no sound this is due to sound section 1 loose connect in sound section 2 speaker 3 problem in sound section some part must have failed.
Sep 17, 2007 | Panasonic CT-32SX12 32" TV
CT-36D12
Instead of explaining the SAP/Stereo function to you, the easiest way to get the TV back to normal is while the set is on press the ACTION and POWER buttons at the same time and hold them until the CHK screen appears. Once that does release the buttons and then press the action button again to exit the CHK screen. Your TV is now back to the factory settings and will need to have the channels programmed again. By the way the SAP/STEREO button on the remote should be near the upper left hand corner of the remote itself.
Mar 25, 2007 | Panasonic CT-36D32 36" TV
Intermittent blue circle on display
Yes this is certaintly a strange one, as you say not all channels have it?? Ok lets try to narrow it down a bit. Do you have cable or satallite ? Is the cable or sat. connectected through the video inputs or does your TV have to be on a certain channel? ok and you say its not there when your watching a dvd? The only answer here is that you have a problem with your cable or the sat system, as the channel stays the same on whatever channel your watching while on the cable, so if you have a problem with some and not others , Your TV dosent know the differance from one channel or another, as its always on the same channel on the tv . So what does this tell you?? Theres a problem with the sat or cable reciver! Cant be the TV as I said the TV doent know the differance from one channel to another as it always stays on the same channel. Sounds like you need toi have cable come in to check the impedence and signal streinth.. now if your sying thast the tvs on locals and some do it and others dont ?? then theres outside interference causeing this problem? Good luck
Jul 25, 2006 | Panasonic CT-26WX15 26" TV
Televison & Video Logo
62 people viewed this question
Top Televison & Video Experts
Electro Med Services...
