Question about Fisher and Paykel DEGX1 Electric Dryer
Where is the reset button on the top loader dryer
  • 32 Answers
Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ This forum will work you through your problem
Posted on Oct 15, 2010
How do I remove the face plate of the dryer
what make amd model dryer? as a general rule first UNPLUG the dryer, if it is gas turn off the gas supply then you have to remove the dryer door first for front loaders. Once that door is off look for any additional screw that were hidden, there may or may not be any. Then look for any brackets that may be attached to the top panel of the dryer. If it is a top loader skip that, then you pry the top of the dryer up they are usually held down by clips. Then grab/pry the front of the dryer off. Those panels are held on by clips also but take a look for any brackets that might have screws in them. It should all be visible.
Dec 17, 2014 | Dryers
Whirlpool Duet Dryer Lockout function stuck
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 06, 2010 | Whirlpool GEW9250 Electric Dryer
Fisher & Paykel front loader dryer ED56AU
What about the lint sensore, it may be faulty, sending a signal of a fire hazard.
Aug 11, 2009 | Fisher DEIX2 Dryer
I have an old Maytag top loader washing machine. The lid id broken so I have to flip it upside down and backwards to keep the button depressed for washing. The lid kept jiggling loose and I would have to...
Check the thermal fuse. It is about one inch long and is located just inside the rear of the dryer and is usually attached to the exhaust duct. It can be tested for continuity using a multimeter. A lack of continuity indicates a blown fuse. Hope this helped and best wishes.
Aug 05, 2009 | Washing Machines
Front loader gas dryer suddenly stopped heating
The dryer may have a clogged or kinked vent line.
This will stop the heating.
remove the vent line form the rear of the dryer and see if it is hotter.
if so the vent line needs to be cleaned or replaced
Apr 03, 2009 | Dryers
Splendide 2100 no longer dries clothes
We had the same problem with our splendide 2100 top loader. If you remove the top cover, you will find 2 circular like black discs (the size of a dime) on the right hand side about 6 inches from the front. You need to push those down (with a very small blunt object) to reset them. Please make sure that you unplug your washer/dryer before you attempt this. Good luck.
Aug 24, 2008 | Splendide 2100 Vented Washer-Dryer
Washing machine won't turn on
For the F&P machine.
Check the circuit board fuse. I had my machine do exactly the same thing. Just wouldn't power up at all, no lights, nothing.
The fuse is on the circuit board a small round red unit, with T1.6A250V written on the top.
Remove the 2 screws securing the control panel. Inside there is a grey plastic box. This houses your circuit board. You will need to have a multi meter and a soldering iron to replace this component.
May 22, 2006 | Fisher and Paykel (IWL12)
Fisher and Paykel DEGX1 Electric Dryer Logo
169 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Bill Eager
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
