Question about Powermatic 1352001 3520B 20x35" Wood Turning Lathe
My Belt on My 3520 lathe seems to be slipping, and the lathe is barely a year old.
Mower only barely moves in forward or reverse
first is it HYDRO or belt driven?
hydro fluid is low old or wore out, or belt slipping
belt drive belts stretched, oil on them, tension spring off,
or belts just worn out
Sep 22, 2015 | Garden
2007 chevrolet equinox transmission slipping
Odd question
You have a vehicle barely 6 years old with
a failed transmission & now can not use it at all
Once they slip your done
Has to be rebuilt
Did you not change the fluid ever 3 years?
That may cost you $3500 verse $80 for a fluid
change 3 years ago & again now
Can't change it now it slips,it will get worst
Mar 11, 2013 | 2008 Chevrolet Equinox
Why do cutting blades start slipping in heavy grass?
either the engine speed is to low or the belt is slipping how old is the belt is there a oil leak that got the belt wet with oil?
May 20, 2012 | Garden
My 4 year old roper washer leaves grease on clothes. On spin cycle the machine makes a screaching noise, and the clothes don't spin dry.
Possible that the belt is slipping and also there is some issue with the agitator as the gaps within seems to bring up the dirt or grease mix to the clothes.
So it is important to remove the panel and check the play on the belt, replace if the play is high and check if the agitator bearings are worn out. If so the agitator assembly must be taken out and checked.
Dec 09, 2011 | Washing Machines
Noisy headstock on 15 inch variable speed lathe
Usually not. Is lathe leveled, and base secured, check for soft feet. This can set up vibration and load bearings.If motor is belt drive check belt condition, pulley alignment, belt tension.
Jul 29, 2009 | Tools & Hardware - Others
Treadmill may be slipping
Depending if this is a new issue or old, It could be a couple of issues. Check the belts for slipping. Proper tension on walking belt (check your manual) or drive belt -remove the cover and you might be able to see if the belt is slipping or it could be a load issue (electronics not sensing added load fast enough). My bet is belt tension. Also Lubricate,lubricate,lubricate
www.twincityrepair.com
Feb 28, 2009 | Reebok Exercise & Fitness
How to replace belt??
there are two wheels unplug every thing and turn upside down you will find the other wheel
Sep 21, 2007 | Amana ALW480DA Top Load Washer
Powermatic 1352001 3520B 20x35" Wood Turning Lathe Logo
71 people viewed this question
Top Powermatic Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Powermatic Tool and Hardware - Other Expert? Answer questions, earn points and help others
