Question about Sanyo PLV Z1 Multimedia Projector
Hi, I have the Sanyo PLV-Z1. Just this evening I wanted to watch a movie but the thing doesn't work right any more. It projects the picture but it's very very very dark. I have to totally obscure the room in order to make out a very faded image. It has been used in eco modus for no more then 350 hours and 0 hours in normal modus. The lamp replacement light is NOT on. Any suggestions?
  • david_nase Sep 28, 2010
    no, this is definitely not it. It's not a cable thing and not a picture menu issue. the lamp has gone completely by now (doesn't project anything anymore)... So the new question is: How come the lamp replacement light is not on and how is it possible that it's broken after only 350 hours? I just want to be sure before spending 200 bucks on new lamp.
    sincerely
    david
  • david_nase Sep 29, 2010
    Well I guess this helped a little. Thank you
    President:
  • 2,047 Answers
The first thing to be checked in such a situation is the connecting cable. Often times these cables get discrepancies midway and these in turn cause poor picture quality. Try using a different cable to confirm if it is indeed the cable.
Secondly check the settings for brightness and the contrast settings if they have been tampered with or reset they could also cause such picture quality.
Finally regardless of the lamp replacement light coming on if the lamp is weak it could bring about poor picture quality. Check the above options by the order in which i have arranged them.
Hope this solution has been helpful?
Posted on Sep 27, 2010
  • Rockme
    Rockme Sep 28, 2010
    Usually lamp details given on projectors about hours of use are seldom less accurate. Why the lamp replacement light has not come on i cant tell until i examine it. But if the lamp has been replaced at anytime after the initial purchase of the projector then there is a probability that it was replaced with a sub-standard lamp. Try to ensure that when you are getting the lamp replaced again it should be done by a trusted expert.
    Hope this solution is helpful? Please rate
  • 944 Answers
This is symptoms of your projector lamp going to die.
It will not die soon.It will still work for more 50-100 hours and
then only it will die.
Mostly all lamps will work for 400-500 hours then it will die.This
timings will change based on the brand.
Note:This is the starting symptoms of weak lamp.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 28, 2010
HOW TO GET A FULL PICTURE WITH OUT BORDERS ON EACH SIDE
It depends what you're watching: For regular TV, cable, satellite and DVD then you just need to use the Aspect ratio button. It is the PIX SHAPE button. Make sure all your source boxes have their picture menus set for a 16:9 (widescreen) TV.
If you are watching Blu-ray, then the situation is different. Blu-ray expects that you have a 16:9 TV. If you use a Blu-ray player to watch a DVD, and that DVD is an older 4:3 shape movie, then you'll be stuck with the bars left and right. It's the player that formats the picture in that way. There's nothing you can do with the TV controls because they'll be locked to 16:9 mode.
Sep 14, 2014 | Sanyo PLV-55WM1 55" HDTV-Ready LCD TV
Sanyo PLV-55WHD1 picture too dark
It may be the lamp itself, some will dim just before failing.
Average life is 2000 hours or two years for OEM lamps and much less for generic ones.
Dec 22, 2012 | Sanyo PLV-55WHD1, PLV-65WHD1 Projection TV...
Sanyo PLV 60 HT keeps on overheating even after I cleaned the
hi dear plz check the projectors fan. It is working properly or not
Jan 31, 2010 | Sanyo PLV 60HT Multimedia Projector
Sanyo Television PLV-55WHD1
i heard same popping sound and my power button flashed red and will not turn back on.?
Sep 15, 2008 | Sanyo PLV-55WM1 55" HDTV-Ready LCD TV
Pixelated screen on sanyo plvz2
Hi focushere
This could only be one of two things - either the cable that will need replacement or the Mainboard of the Projector.
Try using a different cable first , in other words a new DVI cable.
If this doesn't fix the problem ( which I'm sure is going to ) you will have to get the Mainboard repaired at a Service Provider.
May 18, 2008 | Sanyo PLV-Z2 Multimedia Projector
Sanyo plv-z1 wont turn on
Hi
This is normally a clear indication that the lamp is in need of replacement.
Take out the lamp and check for any damage like discolouration or bubbles just to make sure before you invest in a new lamp.
Apr 19, 2008 | Sanyo PLV Z1 Multimedia Projector
Sanyo plv z4
look in the projector menu ( should not be backwards) and switch the view to front projection. It might be set in rear projection. That is what my viewsonic PJ-558 projector can do sometimes
Jan 26, 2008 | Sanyo PLV-Z4 Multimedia Projectors
Sanyo Z3 "Predator effect" problem
Hi there, Ive recently FGixed a PLV-Z3 was as chas said, Filters needed to be re-aligned.
Ive posted the schematics I used on my site.
http://www.entwan.netau.net/1_2_Repair-schematics.html
Jan 16, 2008 | Sanyo PLV-Z3 Multimedia Projector
PLV-Z1 no longer powering up - Ready light is green and the Lamp light is red
I have a Sanyo XU35. Mine was starting up and showed a picture for about 15 - 30 seconds then shutting down. My lamp warning light was not coming on. When I put it in for repairs it turned out to be the lamp that needed replacing. The technician said it is not uncomman for the lamp to be gone and the lamp warning light not to come on. I got my lamp on e-bay from ping_ngo for a great price.
Aug 11, 2007 | Sanyo PLV Z1 Multimedia Projector
Sanyo PLV Z1 Multimedia Projector Logo
173 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
