Question about Canon ZR70MC Mini DV Digital Camcorder
I have a Canon ZR79 MC Camcorder. When I record on MiniDV, and I then go to Play (VCR) and try to play it back, I just get a blue screen with a video reel. Anyone know whats wrong?
    Genius:
  • 1,812 Answers
This is usually caused by an oxidized or defective Audio/Video drum. Try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Sep 27, 2010
Blue screen on lcd screen
The playback head is probably dirty and cannot show the picture - the screen is blue. Run a blank tape in the tape drive and execute a record all the way through the tape. Then play back a pre-recorded tape to verify it plays back ok.
Nov 11, 2010 | Sony DCR-HC30E MiniDV Camcorder
How play the recorded video?
The controls for playback are on the touch screen once the camera is switched from record mode to playback mode, if the camcorder isnt playing back then you might ned to have the unit serviced, could be a bad video head assy. I hope this helps.
Sep 05, 2010 | Sony DCR-HC30E MiniDV Camcorder
I recorded a MiniDV with a HD camera the Canon HV30 to be specific. When trying to play it back on my Canon zr950 i get an error message. Will my tape only playback on an HD video camera? What do I do?
Canon ZR950 is an older Standard Definition camera that records in DV format, and does not recognize HDV format recorded by HV30.
HV30 can be switched to DV format, which should be playable on ZR950.
Dec 10, 2009 | Canon VIXIA HV30 DV Camcorder
Playing DV footage that was recorded on a different camera
Canon camcorders have a non-standard head position. Borrow a panasonic or samsung camcorder (those two are compatible) and backup your casettes on dvds. If you want them to be on minidv readable on canon camcorder, connect it afterwards and send video to minidv through your camcorder. It will then be alligned the way that suites your gear.
Either that or go to the professional service that does conversion from minidv tapes. That usually costs around 15$ per hour, so if you have 10 or more hours of video, the less expensive way is buying an entry model of panasonic camcorder.
Jan 03, 2008 | Video Cameras
Canon ZR10 not displaying recorde image.
PLEASE USE VIDEO HEAD CLEANING CASSETTE & TRY ONCE AGAIN
Jan 02, 2008 | Canon ZR100 Mini DV Digital Camcorder
Convert miniDV to VHS
You use the mini to triple RCA cable with the camera and go into the menu and make sure you are on A/v out instead of headphones. You just hit play on the camera and record on the VCR and Whala, it's done.
Videoteacher
Nov 26, 2007 | Canon ZR70MC Mini DV Digital Camcorder
How to record from a VCR onto a canon mv530i
OK get a set of cord that can be used, on the back of most VCR's there is RCA Sockets for Video & Audio out... generally Red & White & Yellow these go to the corresponding inputs on the camera's Video & Audio inputs, OR Correct adapter. The camera must have the correct A/V INPUT selected. Then start the VCR to "Play" the tape, and set the Camera to "Record" this will/should then record the output from the VCR to the memory in the Camera.
Aug 21, 2007 | Canon MV530i Mini DV Digital Camcorder
Adapter question
There are no such adapters that would allow 8mm, Hi8 and Mini DV tapes to be played in a VHS VCR. Only the old VHS-C tapes can fit and play in an adapter. There are several reasons why 8mm (or Hi8 and miniDV tapes) cannot be physically played in a VHS VCR: 1. 8mm (Hi8, miniDV) is a different format with different technical characteristics than VHS. These formats were never developed with the intention to be mechanically compatible with current VHS technology. 2. 8mm/Hi8 tapes are 8mm wide (miniDV is 6mm wide), while VHS tape is 1/2" wide, making it impossible for a VHS video head to read the taped information correctly. 3. 8mm/Hi8/miniDV tapes are recorded and played at different speeds than VHS, so even if the tapes could physically fit into a standard VHS VCR, the VCR still couldn't play back the tapes at their correct speeds. 4. 8mm/Hi8/minDV audio is recorded differently than VHS. 8mm/Hi8 audio is recorded in AFM HiFi mode, while miniDV audio is recording in 12-Bit or 16-Bit PCM digital audio format. So, even if the video could be played back in a VHS VCR, the audio could not be read properly. 5. 8mm/Hi8 video is of higher resolution than VHS and is recorded in a different bandwidth length (miniDV video is recorded digitally), so once again, a standard VCR still could not read the information correctly, even if the tape could fit into a VCR.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Canon ZR70MC Mini DV Digital Camcorder Logo
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
