Question about Dell 3100MP Multimedia Projector
I am trying to connect a macbook to the dell 3100mp. it does not detect signal Can you help
3 Suggested Answers
pgh_pa_guy
  • 2992 Answers
SOURCE: Dell 3100MP Projector - No Signal Check Cable
Make sure you have the right input source selected. It may be looking for a signal from some input other than the one you're connected to. Beyond that, if it truly isn't seeing the input then you'll need to have the projector serviced.
Posted on Dec 17, 2008
  • 55 Answers
SOURCE: Hi, is Dell 3100MP Projector
In most cases this problem is cured by enabling the external VGA (or monitor) ouput on the laptop. The quickest way is to reboot the laptop with the projector turned on and connected. Usually the laptop will detect an external display is attached and enable the port.
It is also possible to manually enable the external display port. It varies from laptop to laptop but look for the "Fn" key at the bottom left of the keyboard, usually coloured green or blue. You should see a row of icons on the top row of "F" keys which is in the same colour. Look for the one which is either a monitor, or possibly says LCD or CRT.
Hold down the Fn key and press the key you located in the last step. There is usually a delay of a few seconds and then you'll find something may happen. Usually the external output will be turned on alongside the local (laptop) display. Repeatedly following the last step cycles through all available configuration options, including both on, local on, local off, external on, and external off.
This should fix it. Make sure that the correct input is selected on the projector whilst doing this. It will be labelled on the projector and it should display the same input message on screen.
Posted on Feb 21, 2011
I am trying to connect a MacBook AIR to a Dell 3400 MP and all I get is searching for signal... I have the USB cable connected..
Dell projectors work best with windows operating system. Replacing the projector would still not resolve the problem since it is not compatible with Macintosh computers. I recommend that you contact Macintosh and ask if there is an available patch to resolve the issue.
Jul 25, 2011 | Apple MacBook Pro Notebook
Hi, is Dell 3100MP Projector is compatible with windows 7 laptop. I am Having message " NO SIGNAL, CHECK VIDEO CABLE" with Windows 7 but with Windows xp, the same projector works fine. Can anyone...
Feb 21, 2011 | Dell 3100MP Multimedia Projector
Macbook Pro wont connect to Vizio tv
disconnect hdmi cable and shutdown pc, completely power it off. plug your hdmi cable back in to your pc and power it up. it should properly detect your tv. i use projector mode. tv must stay on while performing this procedure.
Feb 11, 2010 | Apple MacBook Pro Laptop Computer with...
Dell 3400mp not getting signal from Macbook
If you were using the Apple S-video adapter to connect to your Dell projector, please realize that MacBook models with NVIDIA graphics cards do not support this adapter. Otherwise, please be more specific about what model Mac you have and what adapter cable you are using.
Aug 24, 2009 | Apple MacBook Pro Notebook
Dell 1209S Projector "Searching for Signal" with Laptop
Try fn + f8, then wait and see if the projector detects the port (15 seconds or so) if no change, try Fn+F8 a 2nd time
Jul 28, 2009 | Dell Latitude D800 Notebook
Dell 3100MP just powers off
check the heating of your laptop. it more heat chek your fan or cfu fan, if work properly.. shuting down is a lot of cause. over heating, fan not work properly case over heating... processor.. or board..
Jun 19, 2009 | Dell 3100MP Multimedia Projector
TV won't recognize signal from a DVI to HDMI input adapter
I had a similar problem with a Mac Mini.  The problem was caused by a mix-matched resolution (the Mac tries to use 75Hz refresh rate, TV expects 60Hz).  The best solution I found was to remote into the Mac (I used LogMeIn.com) and change the resolution on the Mac from a remote computer until the image appears on screen.
Process: 1) Connect Mac to a normal monitor and install the LogMeIn server (or other VNC type application) 2) Connect the Mac to the TV 3) Connect to LogMeIn from another computer (preferrably one where you can see the TV) 4) Go to Applications / System Preferences / Display 5) Change the resolution to your TVs native resolution, and change the refresh rate to 60Hz
Apr 08, 2009 | Westinghouse Televison & Video
Dec 17, 2008 | Dell 3100MP Multimedia Projector
Help!
Try going to system preferences - displays and see if your macbook is detecting an additional display.
Nov 16, 2007 | IBM E400 Multimedia Projector
Dell 3100MP Multimedia Projector Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
