Question about Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
No picture I hooked up my new sony bravia adn have been watching it a couple weeks now. tonight we finally had time to watch a dvd adn we have no picture. I guess something is hooked up wrong but have no idea where to start
    An expert who has written 200 answers of more than 400 characters.
  • 265 Answers
Hey motherann,
If your TV has only been having problems displaying a picture when using the DVD player (and normal TV stations are unaffected), you may only need to check the connections between your TV and DVD player to resolve the issue.
Most DVD players will connect to a TV using component video cables, an HDMI cable, a composite video cable, or an S-Video cable. HDMI and S-Video ports generally have a unique enough shape that the cables used to make those connections cannot be used anywhere else, but the same unfortunately does not apply to component and composite cables. Component and composite video cables share a similar shape, and can often be confused if the identifying marks on the cable itself, TV or DVD player have been removed. Composite video cables are traditionally a single connection that transmits the entire video signal from the DVD player to the TV, while component cables are a series of three cables that each transmit a portion of the same image.
The first thing I would suggest checking is that each cable is correctly connected to both the DVD player and your TV. Make sure that the cable(s) connected to your DVD player is plugged into the appropriate "Video Out" port, and attached to the TV at the corresponding "Video In" port. These ports should be labeled on both the TV and DVD player for easy identification, regardless of where the connections are located. Additionally, many manufacturers will even color-code both the connection ports and the cables themselves, to ensure that the right cable is used at any given time.
In the event that everything has been set up correctly but the TV still does not pick up a video signal from the DVD player, there could be a number of other potential problems: the cable being used could be defective, one of the connection ports used (on either the DVD player or TV) could be defective, or they may even be a loose connection inside the TV or DVD player.
Replacing a defective cable is generally the easist possible solution to this type of scenario, but if the problem still persists after doing so, you may wish to consult a repair technician to determine the cause of the problem.
Hope this helps you out.
Go Ahead. Use Us.
Posted on May 28, 2008
Sony flat-screen bravia tv picture goes black but keeps playing audio when playing Netflix or DVDs.
your dvd player needs its own connection as does netflix and cable,get a new hdmi cable for each
Jul 11, 2015 | Samsung Audio Players & Recorders
My brand new 40" SONY Bravia LCD TV picture goes darker or brighter while watching DVD movie automatically. It does not happen while watching regular TV. What setting should I turn off ?
This is a characteristic of the dynamic backlight used on this set.Turn off the dynamic contrast in the customer menu this should solve your problem.
Oct 15, 2009 | Sony BRAVIA KDL-40SL14098 40 in. HDTV LCD...
Screen periodically going black
try dvd if that doesnt go in and out try a new cable box or ddish receiver
Jun 03, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Unable to control audio after playing a DVD using HDMI
you may have a damaged remote circit or reciver on the dvd player or tv, look for a phone number on the instructions book to call and see if you can send it in to have it checked out
Jun 02, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
Sony Bravia KDL-40V2500
The panel or TCON board has failed, the solution is the same replace the panel. Not worth the cost, get a new TV
Sep 28, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony KV-24FV12 Image intermittant Blackout
Hello Robert, the picture tube on your TV set is exausted. Please contact your nearest Authorized Sony Service for further help/advice. After all, Sony is a good choice. The next TV set you buy could be one of Sony-s Bravia LCD. Kind regards, Arpad
Dec 20, 2006 | Sony KV-24FV12 24" TV
Sony BRAVIA KDL-40V2500 40 in. LCD HDTV Logo
261 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
