It has come up drum error, i have cleaned the laser pinter window screen as well as the cornora wire yet it still comes up with drum error? help me please
  • 240 Answers
Your drum has reached the end of its life. You either need to reset the drum or buy a new one. If you reset the drum (you can find instructions on the web) and then notice poor print quality you need to replace the drum to correct the print quality.
Posted on Sep 28, 2010
I have a SCANNER ERROR lamp error message on my Konica Minolta 1380mf page pro pinter, do you know how I can fix it please?
You have a bad drum unit, you will need to replace your drum (dr310) along with the developer (dr310) it's not all that difficult but requires several step to reset the error code, clear the counters and calibrate.
Sep 19, 2011 | Konica Minolta PagePro 1380 MF Laser...
Drum Error - see routine maintenance chapter in user guide. Do not have user guide
I tried everything and then decided to slightly change the above instructions to:
Open the front cover
press Clear/Back
Replace New Drum - select "Yes"
after the screen will show "accepted"
close the front cover and you are good to go
and WA LA it worked!!
Apr 19, 2011 | Brother MFC-7340 All-In-One Laser Printer
Drum error light is on
For the error you described however you would need to check and clean the contacts for the drum on the left side of the inside of the machine.
if it's a drum life error then you either need to replace it and/or reset the counter.
to reset the drum counter, open the front cover, hold down the start button until all lights come on, then release the button and shut the front cover.
Pull the drum cartridge apart to clean the charge assembly properly, it's very easy to pull apart. just make sure you don't break the corona wire in the process.
The printer has a light sensor on the drum/cartridge in the middle of the right hand side (assuming your facing the printer) - its a little circle /window that it uses to check for light. If you cover that with something that doesn't let light in (A small piec of cardboard etc) then you wont get that error anymore and you'll print happily ever.
Feb 23, 2011 | Brother HL 2140 Laser Printer
My machine says Drum Error, refer to trouble shooting for maintenance?
Drum Error:
The corona wire on the drum unit
needs to be cleaned.
Clean the corona wire on the drum unit.
(See Cleaning the corona wire on page 122.)
or
The drum unit has reached the
end of its life.
Replace the drum unit.
(See Replacing the drum unit on page 130.)
and/or
press Clear/Back
Press Start, then 00
after the screen show "accepted"
close the front cover and you are good to go.
Feb 03, 2011 | Brother MFC-7340 All-In-One Laser Printer
Printer says drum error see trouble shooting and maintenence care in manual. I have replace toner and drum
Drum Error:
or
end of its life.
and/or
press Clear/Back
Oct 27, 2010 | Brother Tn650 AllInOne Laser Printer
I m using samsung ScX4521f . pls tell me how i remove lsu error
Laser beam Scanning unit window (thru which the beam travels from the laser unit to the drum in the cartridge) be cleaned. If error persists the LSU assy needs replacement if the wiring harness is not damaged.
Oct 19, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Pls Clean Drum
The drum is the larger plastic unit that slides out an the toner cartridge fits into it. The corona wire is the very fine wire at the front top of the drum. Just slide the little cleaning tab back and forth.
Aug 03, 2008 | Brother MFC-8440 All-In-One Laser Printer
WEAK COPIES ON XEROX COPIER
You need to 1 remove the glass and clean the mirrors, lens and bottom side of the glass.
Also, remove the toner and drum cartridge, use a flash light. On the left side you will see a "window" about 5/16th of an inch in height, and probably 5 or 6 inches wide. That is the laser window, it is probably pretty dirty. You may have to use a Q tip or a soft cloth, dampened with some glass cleaner, and clean that window well.
If the optics, and laser are dirty , hazy, the copies will be light and streaky. The drum may be bad. Also, on the right hand door, Look just above the rollers, there will be an opening, it has a small clear plastic guide, then open with a hair fine wire running through it. Take a Q tip dampened with some alcohol, and carefully clean that wire. You can apply light pressure to clean it, just don't get forceful, it does not take a lot of pressure to clean that wire. That wire is responsible for "transferring" the ink from the drum to the paper.
If you clean all 3, Optics, Laser window and transfer wire, I think you will be very very pleased with your copy and or print quality. That should restore it very well.
Apr 02, 2008 | Xerox WorkCentre XD125F All-In-One Laser...
166 people viewed this question
k24674
jasbo
jasbo
