Can't linksys router wrt160n v2 to linksys modem ap103j400827 & vonage router vdv21-vd
  • 12,061 Answers
Whenever you connect two router together in any system, first one must set to OFF one units DHCP, otherwise both will be distributing addresses. So that's what you need to do, go into settings on one of the routers and turn off DHCP, on the other router simply leave that one as is. This then will make it so you only have One address server, and now it should all talk to each other properly. Also make sure they are all on the same network.
Get it working with the modem & router with DHCP ENABLED, working first, then add the other router with DHCP turned OFF.
Posted on Sep 27, 2010
Hi I configured wrt160n v2 linksys router well but when the power goes down and restart it again it stop working for more than 1 hr? any solution for it? Noor Muhammad ISP Engineer Multinet Kabul...
your ISP is a cable or DSL...??? if it is a cable then you should do a mac clone... if your ISP is dsl, then check with the direct connection from modem....Make sure the direct connection with modem is working good when the modem is restarted and connect the router...
Aug 10, 2010 | Linksys WRT160N Wireless Router
Problem with GE 29875 ANSWERING MACHINE
My reliable GE 29897GE2-A speakerphone w/ digital answering machine works perfect on my AT&T landline, BUT the answering machine does NOT work when connected to my Vonage VDV21-VD line (w/ voicemail and call forwarding disabled). I called Vonage Customer Support to inquire about this from their website:
"Can I use my own answering machine instead of Vonage server based voice mail?
If you wish, you CAN use your existing answering machine with Vonage. All you need to do is DISABLE Vonage’s server based voicemail system by logging into your account at www.vonage.com, and clicking on features. The voicemail menu will allow you to disable the entire Vonage voicemail system."
Vonage Customer Support was clueless. The only resolution offered was their suggestion that I might contact the manufacturer (GE-licensed Atlinks USA, Thomson)... lol, good luck with that!
So I installed a GE in-line "DSL Phone Line Filter" between the Vonage VDV21-VD and the GE 29897GE2-A, BUT the answering machine still does NOT work. It appears that Vonage is simply incompatible with the answering machine despite Vonage's bold claims to the contrary.
Apr 21, 2010 | GE 29875GE Digital Answering Machine
Compatibility with high speed ADSL2 Broadband
Yes, Linksys WRT160N is 100% compatible with ADSL2. Linksys WRT160N is a Broadband router.
you will not be able to use the linksys WRT160N, as an ADSL2 modem router. you should be using an ADSL2 Modem separately and connect the cable from the modem to the Linksys WRT160N. Hope this clarify the doubt.
Apr 02, 2010 | Linksys WRT160N Wireless Router
Linksys WRT16n V2 message "router not connected properly"
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Mar 03, 2010 | Linksys WRT160N Wireless Router
I need to set a passowrd for my wireless router.
The default username and password is "user". For the security settings, you need to setup WEP/WPA-PSK etc. Steps are outlined in the manual.
Link to the manual:
http://www.abadss.com/forum/attachments/1037-router-users-manual/19159d1248742164-user-manual-d-link-vonage-model-vwr-vd-router-vwr_userguide-1-.pdf
Sep 10, 2009 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
How to connect Wireless router to Cabel Modem and Vonage Modem?
First of all: it would be good to know which devices you are using. This would help to be more specific.
But anyways:
  1. Connect a normal Ethernet cable from your DSL or Cable modem to the Internet (or WAN) port of your vonage router.
  2. Then connect another Ethernet cable from one of theLAN ports of the vonage device to the Internet (or WAN) port of your Linksys (The one that is separated from the 4 LAN ports.)
  3. Make sure that the Linksys is set to DHCP (Dynamic IP Address), soit can get it's IP address from the vonage router! (Look at your manual. If you don't have one, you can get it here. Choose the right version number - you can find that on a sticker at the bottom of the router - and download the user guide)
  4. Connect your computer to one of the LAN ports on the Linksys.
If you have any more questions or this desciption is not clear to you,just come back here and leave a comment - I'm happy to help.
May 22, 2009 | Linksys Wireless-G WRT54G Router
LInksys wrt160n v2 wireless router not connecting to internet
Most cable companies will only allow 1 active device at a time conneceted to the cable modem. When ever you change what is connected to the cable modem you must always cycle the power/reset your cable modem.
When you are reseting the units, always rset the cable modem first, wait until it boots back up then reset the router. If that doesn't fix the poblem then it may be a configuration problem.
I forgot to ask if you are cable or DSL.
Hope this helps
Apr 09, 2009 | Linksys WRT160N Wireless Router
Vonage Phone Adapter and Motorola DSL Modem and Linksys NUltra
Your connection should be from DSL modem > internet port of Linksys router > Vonage phone adapter to port 1 of the router.
Nov 01, 2008 | Linksys WRT160N Wireless Router
Computers & Internet Logo
David Payne
David Payne
