Question about Nokia 6210 Navigator Cell Phone
My nokia 6210 nav fell into water and i dried it off. now the problem is that i cannot see the backlight even though the phone is working fine. the display is therefore dark, and i'm able to see anything when it's dark.
  • 358 Answers
Hi, sorry about the water problem with your phone, Since you said the phone is already coming on but the display is still dark, What makes the display still dark is because the water it fell into has damaged an IC inside the phone,The IC makes the phone display.
So when you replace the phone IC that got damaged,the phone will display again,.
It was caused by water.
Take care.
Posted on Sep 27, 2010
  • Jesus Gonzalez Jun 03, 2013
    Where is the IC located in the phone, please?
My nokia e7 fell into water and won't turn on
Wet Cell Phone
Immediately remove the phone from the water, turn off the cell phone, remove the battery and SIM card. To dry out the cell phone put it in a large plastic bag with silica gel drying crystals then put it in a warm sunny place for several days or in front of a warm fan heater for several hours. Reassemble the phone and hope it will work properly again, but if does not work then it is faulty and you need a new cell phone.
Dec 26, 2012 | Nokia E7 (16 GB) Smartphone
My xperia x10i fell in water i have dried it 4 about 60 hours everything is working fine else than its backlight
The water that remained on the backlight section conducted as this section had voltage for the back light LED's resulting in failure of a track or a fusible resisitor on the board.
You need to use a good magnification glass or inspection lens with a desolderring station to touch up the cracked or damaged area to restore the connection to the backlight LED.
Jul 26, 2011 | Sony Ericsson XPERIA X10 Cell Phone
My E63 cell fell in the water and it is not responding what can be done to it?
hi....
please remove the panel and make it dry,there should not be any water left in it,try to switch ON it.
DONOT charge the mobile even though it works fine there wil some water log stil present in it which may cause the circuit board to shortcircuit or it may cause shock to the person having it.
so please give it to the service centre to remove the water logs so that furthur risk are eliminated.
thanx
Jul 19, 2010 | Nokia E63 Cell Phone
Nokia 75 fell into water and does not work - any suggestions
You could try drying it out. Strip it down (even as far as sim out) and leave somewhere warm overnight, on top of a radiator is such a place. If that doesn't work be more careful with your new phone
Nov 17, 2009 | Nokia Cell Phones
I want my maps 2.0 restored ovi maps don't work Nokia 6210 nav
sir updating your phone software may fix this problem or just hard reset your phone hard reseting code is *#7780# put this code on your phone`s keypad.if this doesnt works try this format code *#7370# put this on your keypad it will format your phone........and your phone work good......
Sep 10, 2009 | Nokia 6210 Navigator Cell Phone
Nokia 6210 Nav new screen just flashing white
These models 5110,6110,6150,6210
Are very sensitive in display contact.
Sometimes if u just dropp the phone The screen can start to fade.
take the phone apart again and dlean all the gold-plated connectors on the screen and contact areas on the mainboard with a cotton stick soaked in
isoprophanol. Let it dry avoid fingering on the cleaned surfaces.
mount the screen carefully to the mainboard tighten the skrews from left to right to finally tighten the skrews carefully.
This should do it! Please vote!
Jun 06, 2009 | Nokia 6210 Cellular Phone
The screen of my nokia e66 does not light up
The problem is inside your phone inside your phone The wire may be damage by falling
May 27, 2009 | Nokia E66 Smartphone
Solutions for nokia 2310 backlight
good day,
i suggest that you don't turn on the phone if it is not yet thoroughly dried, this might cause some short circuit on the system. you can use a hair drying in doing this.
however, if you're certain that your phone is already dry, try turning it on and check for errors. in the case that you stated, it seems that your phone has been damaged due to being submerged in water. if the backlight will not turn on again after making sure that your phone is thoroughly dried, have it checked by a competent technician and prevent further damage to your phone.
i hope this will help
Oct 13, 2008 | Nokia 2310 Cellular Phone
Nokia 6210 Navigator Cell Phone Logo
201 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
