Question about Electrolux 37 in. Designer Series E36IC75FSS Electric Cooktop
My electrolux cooktop is not responding...it is stuck on...and there is an "E" error code on each of the burner digital displays...the power is on to the unit...but it will not respond...even to turn off
5 Suggested Answers
SOURCE: cooktop light stays on when cool
Please be more specific.
A.  What is the "plate cut-out"?
B.  How does one access it?
Posted on Oct 15, 2007
  • 619 Answers
SOURCE: Frigidaire Ceramic Cooktop PLEC36S9eca - Turns on but burners won't heat up
Check the power plug is their any separate plug on it / if none check the control panel some switch to power on .
Posted on Jan 05, 2008
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: electrolux cooktop was in use and suddenly tripped breaker. When reset, showed error code across control panel. tried sabbath mode unlock, but no success. suggestion?
    What was the error code?
    Posted on Jul 30, 2012
    chrispolkele
    • 4342 Answers
      Verified Fixya Pro
      SOURCE: Electrolux Induction Cooktop E36IC75FSS Error Code 41
      Hi Sue -- when you switched the breaker, how long did you leave it off before switching it back on? Generally, it's a good idea to leave the breaker off (or unplug the unit) for a full 30 seconds before switching the unit back on. If you did have it off for 30 seconds and the error code came on after that point, then it may possibly be a relay isse. That will more than likely require a visit from an authorized servicer to properly diagnose the cooktop. Hopefully the 30-second test prevails and the issue is resolved. Best of luck!
      Posted on Aug 29, 2012
      Power went out. reset circuit breaker and all the lights keep flashing 8.8 and won't stop
      Hello Heidi, thank you for your post!
      From my understanding your Electrolux cooktop is displaying an error code of 8.8. The error code of 8.8 means there is a shift register issue on the middle touch board. This could a possible issue with the control board or the middle touch board. You may need to have a professional technician out to your home for proper diagnosis. We hope this information is helpful to your repair. -Matt
      Jan 23, 2016 | Electrolux 36"" Induction Cooktop
      Model EI36EC45KB. What does flashing code E17 indicate?
      think I would call the place I bought it and request a serviceman come out .
      Sep 29, 2015 | Electrolux Cooktops
      Electralux Surface Cooktop, with code---E----40
      Hi Linda Wallman, thanks for your post!
      I see that your Electrolux cooktop is displaying an "E40" error code. Typically, the "E40" stands for no communications, shorted bus. This could be an internal communication error with your left control board, relay board, or filter board. I would recommend getting a technician out to your home for proper diagnosis and repair. I hope this is helpful. -Matt
      Oct 20, 2014 | Electrolux Cooktops
      Prestige induction cooktop showing error E4
      Good Afternoon friend, I appreciate your inquiry!
      Typically on an Electrolux induction cooktop the "E4" error code stands for key sensor for timer. Which means you could be experiencing an issue with the right board, center board, or left board. I would perform a reset on your cooktop and you can do that by flipping the household circuit breaker off for ten minutes.
      If that does not assist with clearing any false error codes or the error "E4" continues to display I would suggest seeking assistance from a professional for proper diagnosis and repair. Hopefully this helps. -Matt
      Oct 18, 2014 | Electrolux 36" Electric Hybrid Induction...
      What do error codes E51, E52, and E53 indicate?
      This link lists the error codes for your cooktop: Needapplianceparts com
      Specifically, it's a "sensor break" in your front and center burners.
      The solutions they recommend:
      * Verify element temperature sensor is correctly connected to the generator circuit board
      * Replace element if temperature sensor resistor value is not approximately 1000 ohms (blue wires) at room temperature
      * Replace associated generator circuit board
      Jan 12, 2014 | Electrolux 30" Electric Hybrid...
      I was boiling water for potatoes on the Electrolux induction cooktop last night. Only using one of the five burners when I heard a "pop" sound and possibly a flash of light. Error code we have is EO
      Hi Gail, I am happy to assist you!
      It appears the main control has detected a faulty or error condition. "E0" should be followed by two more digits to indicate which error has occurred. Let's try turning electrical power supply off. It is necessary to wait roughly ten minutes to reset cook-top main controls. If resetting the power does not correct the issue or provides a new error code, at this point, I would recommend having a service technician to diagnose the problem before investing in unnecessary parts.
      Dec 20, 2013 | Electrolux 36" Electric Hybrid Induction...
      Error message on my electrolux INDUCTION STOVE TOP
      Hello - Typically error code E on Electrolux induction cook top indicates an error with the user interface board/control board. Contact a professional to move forward accurately and properly diagnose/repair the unit.
      Oct 30, 2012 | Electrolux ICON Designer Series E36IC80ISS...
      My electrolux iduction cook top sends error across the whole bord when I put anythng on the inductoin burner
      You may try and reset the induction cook top by disconnecting the power to the unit for up to 30 seconds. This will clear most false error codes. You can disconnect power by flipping the circuit breaker off and back on. If the error code does not clear, then the unit more than likely can be experiencing an issue with the EOC and user interface board. This is not a typical do it yourself job; please consult a professional or your manufacturer.
      Sep 11, 2012 | Electrolux 36" Electric Hybrid Induction...
      Kenmore Elite Induction Cooktop Error Code 41
      I realize this is over a year old. I have the same unit with the same error code. Last night, mine made a popping noise followed by smoke and then displayed the 41 and all E's. I pulled the breaker immediately. I'm sure that at least one controller board is toast.
      I called Sears and it is under warranty but for parts only, so I guess I will give them a call and schedule the repairman. This should be fun.
      Anyone else experienced this failure??
      Feb 01, 2009 | Kenmore 42800 Stainless SteelCooktop
      Electrolux 37 in. Designer Series E36IC75FSS Electric Cooktop Logo
      97 people viewed this question
      Top Electrolux Cooktops Experts
      Paul Carew
      Lawrence Oravetz
      gbob59
      Are you an Electrolux Cooktop Expert? Answer questions, earn points and help others
