Question about GE Heating & Cooling
Too Hot to bare!
Does anyone know where I can get a copy of a wiring diagram? I am needing a wiring diagram for GE room air cooler AJJ09DVF1. If you have one, can you e-mail it to me at . It is an appliance emergency. Thanks!
My Kenmore AC - #106-9752570 is also blowing out black particles that resemples felt. I put a new filter in a month ago. The button just above the on/off switch on the left front of unit has 3 settings (to the left/Fresh Air---to the right/Exhaust---and to the Top/Closed) The button is set on Closed & I can't move it to the 2 other settings. Could that be the problem?
My e-mail address: Sherri Carr, Jenks, OK
Posted on May 24, 2008
Remove exhaust hose
U need that hose to direct the warm air outside the area to be cooled. If you remove it, the hot exhaust will stay in the room being cooled and negate the cold air being directed into the room.
That is why regular room AC units are mounted on window sill. Cold air in, hot air out.
Oct 08, 2015 | Haier Commercial Cool 8,000 BTU Portable...
How do I replace a power cord on a GE Window unit Air Conditioner?
the best thing is take one wire off at one time black to black white to white red to red thats the best i can do
Jun 24, 2014 | GE Electronic Room Air Conditioner AGW12AH
Wantneed diagram for G.E. TL412CP sub panel
Do you have any wiring in the panel already? The green or bare copper wires will go the ground bar which will be screwed directly on to the inside of the box. The ground bar will be in contact with the box. If the mains are wired into the main lugs the main ground will have a green stripe or it may be bare multi strand aluminum. All ground wires go under screws individually on the ground bar. The white wires go onto the neutral bar. The neutral bar will be affixed to the inside of the box on plastic isolators that do not allow contact with the metal panel. The main neutral will have a white stripe or it may be solid white. The neutrals will go under individual screws. The hot wires will now go under the screws of the breakers. All screws must be tightned firmly but not as tight as you possibly can. The hots will be black or red. The wires should alternate black, red, black, red. Begin with black on the top two breakers the one left and the one on the right. The hot wires will be either black or red.
Feb 27, 2012 | General Electric GE 125 Amp Indoor Main...
Cool air coming from the vents in the front but hot air coming from the back. What do I do to stop the hot air so that the room will cool down?
The hot air is a product of the cooling.... if you stop that then the unit will not cool!!!
You need to buy an exhaust kit to vent the hot air outside so that it will cool the room.
Otherwise it is just what is called a spot cooler or in other words you are cool if you sit in front of it, but it actually will make the overall room temp. hotter!!
Jul 04, 2011 | Haier CPRB09XC7 Portable Air Conditioner
How to wire recepticle for pump 240v, 2-speed fan motor 240v, purge pump 240v
If you are asking how to wire up a receptacle to run a 240 volt pump, you need to have a box on the roof first of all. You will need a 20 amp double pole breaker for this. You will need to pull 2- hot wires from the breaker box, 1- neutral, and a bare ground wire. Size of wire would be # 12 THHN stranded wire. A total of 4 wires. This would be to code. Or, buy enough Romex wire, #12 with ground wire and red, black, and white in side, tie into the breaker that way. Red and black will be your hot wires to pump, if it has no neutral you can use both the white and bare to ground, very easy to do.I hope this is what you wanted to know.
Apr 23, 2011 | Mastercool 67680 Evaporative Cooler Air...
Show wiring diagram for 274w combo
1) A wiring diagram can be mistaken because wire colors vary.
That's why electricians don't guess, they test.
2) Look at device to be replaced and note what color screw each wire goes to before disconnecting wires.
If old device is single pole switch, then there are 2 brass screws, and one of these screws is connected to Hot wire, and the other screw is connected to Load wire (light, fan, motor, pump)
3) Separate wires inside box for testing.
Do not untwist any wires.
Tape tester leads to wood sticks to keep hands away from power.
Turn power ON.
Test each wire to bare ground wire.
Tester lights up on Hot. Hot wire connects to dark-colored screw on combo device.
4) Hot is identified.
Test Hot to all other wires, except bare ground wire.
Tester lights up on Neutral wire. In a single-pole switch box Neutral wires are usually twisted together and covered with wire nut. Neutral wire connects to silver screw on new device.
5) Load wire that goes to light,fan, motor, pump connects to brass screw on new combo device.
6) If you do not have a Neutral wire in your switch box, then outlet will not work.
You can connect bare ground wire to silver screw and have outlet work, but this is not code, and definitely not recommended for a child's room or any room near water pipes or faucets or metal pipes of any kind. You need to add a Neutral wire and/or install GFCI protected device for any bathroom area.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on circuit or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 05, 2011 | Cooper Industries Cooper Wiring 274W...
I am replacing an old intermatic model EJ341 spring wound timer with a GE15086 digital in wall timer. The old intermatic timer has two black wires from each side (I dont know which one is hot). Each of the...
GE 15086 is a 7-day programmable timer. It has more wires than spring-wound timer because clock motor runs on 120V circuit, just like ordinary electric clock. The clock on spring wound timer operated by a spring.
If I understand correctly, the old timer has 2 wires. One of these wires is the Hot wire ... and that wire will connect to GE timer black wire.
The other wire from old timer goes to Load ... and that wire will go to GE timer red wire.
Instructions on a lot of these timers say, it timer doesn't work, then reverse the two wires described above ... this is because timer only works when Timer black connects to Hot.
You can also turn on power and test each wire that came off old switch to bare ground wire. When tester lights up, that is Hot wire.
GE timer Green wire connects to bare ground wire.
Moving on to GE timer white wire. This wire is necessary for the clock to run. This wire connects to Neutral wire which is usually white. You can test for Neutral by testing Hot wire to each white wire in box ... when tester comes on, that is Neutral.
If you do not have a white Neutral wire, then connect GE timer white wire to bare ground wire. This is not code, but it will work fine until you hire electrician to run Neutral into box.
Oct 03, 2010 | GE Electrical Supplies
Need wiring diagram or schematic for GE refrigerator
if you look on the back there should be one stuck to the inside of the case near the compressor. if not go here:
Aug 14, 2009 | Refrigerators
Fan blower coleman electric cooler
The fan should blow air into the heat sink. The warm air exits the heat sink at both ends. (It might work the other way, haven't tried it.)
When you have ice in your cooler, you know the thermo-electric element is working well--it's below freezing!
Ice builds up because there is water in the cooler. For example, in humid weather, you open the cooler, some humid air gets in, and the cooler temperature condenses the water. You have to empty this water, either by tipping the cooler, or using a sponge.
You can easily defrost the cooler by unplugging it for an hour or so. You know it's time to defrost when you hear the fan blades making a racket because they're hitting something--a thick buildup of ice.
Aug 10, 2008 | Coleman Electric Cooler 40 Beverage Cooler
Heating & Cooling Logo
126 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
