Question about Minn Kota Maxxum 70 Freshwater Bow Mount Trolling Motor
My Minn Kota will only turn to the right and does not spin. Whats wrong. Connections have all been checked.
tbirdfan1
  • 3051 Answers
SOURCE: Where can I get installation manuel for Minn Kota bow mount maxx?
Hi there
if you go to the web site of the manufacture they havre a printable version of the manual there is even a phone number to call for help please try this ok and let me know how this works for you
best regards mike
Posted on Mar 06, 2009
SOURCE: the prop will turn on my minn kota endura 44 but
Odds are you have sheared the pin (slides through the prop shaft) holding the prop, or you have damaged the slot on the prop that the pin sits in.
Prop is secured to the shaft with a metal nut, or flat plastic wing nut. Remove the nut to remove the prop. You may have to pry, slightly, the prop from the motor housing. Removed, you will see a whole in the shaft where a pin should be located. If the pin broke, it probably hit the floor when the prop was loosened. If the pin is intact, examine the rear side of the prop and look for damage to the plastic slot where the pin would sit making contact.
If you've snapped the pin, you can make a replacement with a nail using a hacksaw. Replacement pins can also be ordered from Minn Kota. If the back side of the prop is damaged (recess for the pin to sit), the prop is toast. Replacement props are often carried by Walmart, and include a new pin.
If neither part is broken, perhaps the prop was just not seated on the pin correctly allowing the prop to freewheel.
Posted on May 13, 2009
SOURCE: I need Minn Kota Power Drive operators Manual
I'm installing a Minn Kota Power Drive 70# on my Crestliner Fishhawk. I understand the 24 volt system. however the boat has 2 black, an orange and a red wire running to the batteries. I know black to neg. but where do the orange and red wires go.
Posted on Jun 28, 2009
SOURCE: i have a minn kota deckhand 35 that wont wind up.
Solution- Take the cover off the Deckhand 35 by Minn Kota. Inside is a motor drive. Remove the cover plate held in place with 4 screws. inside are nylon gears, most likely broken. The gears can be replaced with a Minn-Kota Deckhand Gear Repair Kit.
I found mine on the web at Northland Marine.com it's about $24.00 for the kit, plus shipping.
Good Luck!
Posted on Jul 13, 2009
  • 122 Answers
SOURCE: How many amps does a minn kota 80lb thrust motor draw ?
max is 56amps on 24v system
Posted on Jan 31, 2010
Only have a model number and need to order a Minn Kota electric motor propellor
Minn Kota go by the thrust which is mentioned on the top plate. I got mine off Craigs List as well.
  • Minn Kota Prop Compatibility Chart - TrollingMotors.net https://www.trollingmotors.net/blogs/selection/86967623-minn-kota... Minn Kota Prop Compatibility Chart Minn Kota Prop Charts. ... Minn Kota with a serial number and they can recommend a compatible prop for your older Minn Kota motor. ...
  • Minn Kota Motors www.minnkotamotors.com Prop Selection & Part ... Electric Anchor Winches; Shop All; APPAREL. ... A combination of a Minn Kota motor and foot controlled rudder steering allow you truly ...
  • Trolling Motor Replacement Props - Minn Kota www.minnkotamotors.com/Accessories/Trolling-Motor-Accessories/... Minn Kota builds the world's toughest ... Electric Anchor Winches; Shop All; APPAREL. Mens; Ladies; Youth; Shop All; WHAT MOTOR DO I NEED? LET US HELP YOU ...
  • Minn Kota Replacement Propellers - www.fishntech https://www.fishntech.com/minn_kota_propellers.html ... Minn Kota Electric Trolling Motor Replacement Propellers & Nut Kits, ... Minn Kota Replacement Propellers . ... Minn Kota Electric Trolling Motor Replacement ...
  • Minn Kota props replacement props for Minn Kota www.minn-kota.com/minn-kota/minn-kota-propellor/page/2 Minn Kota Replacement Props for propellor Weedless Wedge 2 Props ... Minn Kota MKP 3 Prop 2061151 ... MinnKota Trolling Motor Power Center $57.58; DeckHand Electric ...
  • MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ' ... www.ebay.ca/sch/...nkw=MINNKOTA+MKP+37+2091170+TROLLING+MOTOR+P... Find best value and selection for your MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ... MINNKOTA MKP 37 2091170 TROLLING ... MINN KOTA ...
  • Jun 08, 2016 | Minn Kota Endura 30 Freshwater Transom...
    The trolling motor will just quit sometimes if I shake the handle several times it will start back up
    sounds like a loose or bad connection on the throttle switch will need to open the control tiller and check connections if you have a meter ohm out the wires at the connector and switch to make sure all connections are good this is a bit involved and I recommend doing on a bench not in the boat If you need more detail just ask You know this sucker comes with a 2 year warranty right !
    If you need further help, reach me via phone at https://www.6ya.com/expert/richard_b70d968cd1a1d293
    Apr 18, 2016 | Minn Kota Maxxum 80/BG/Hand Freshwater...
    WHO STOCKS A 2991251 CABLE FOR A MINN KOTA
    Sherry, I think there may be a new Minn Kota part # . Check the attached links. Good luck
    "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
    Minn Kota Power Drive Non Auto Pilot Coil Cord Assembly 2991283
    Minn Kota Trolling Motor Part COIL CORD STRN RLF PD48 54 2991283
    http://minnkota.com.au/wp-content/uploads/2014/07/55-PowerDrive.pdf
    Can get replacement parts for my Minn Kota trolling motor FAQs
    Apr 13, 2016 | Minn Kota Boating
    Minn Kota mk25 light will not move from yellow to green. I have moved the connections from one battery to another. I replaced a dead starter battery, and my trolling battery tested out at 100%. what could...
    Do you remove the trolling motor wires before charging..? ...If not.. try that......mine started taking a LONG time to charge.. after I remove the trolling motor cables.. it take less time and charges better!!!
    Feb 25, 2013 | Johnson Minn Kota Mk 25 & Mk 35 On Board...
    My minn kota 70lb thrust motor is 2 years old. Brand new batteries and it will turn left & right, but the prop will not work.????
    Minn kota 74 lbs. prop runs when head turns when rotating motor from centre to right, but stops when you turn motor from centre to left. The light on top stays on.
    Aug 30, 2010 | Minn Kota Maxxum 70 Freshwater Bow Mount...
    Have a 3 hp. minn kota, prop wont turn, hard to
    I have the same trolling motor and the same problem.
    It seems the factory grease gets hard inside the motor where the shaft spins and acts like glue. I removed the long screws, carefully pulled the case apart, cleaned out the old grease (which was more like hard plastic) and packed the bearing area with lithium grease. I also lubricated the "O" rings and they were not damaged or brittle so I re-used them and put the unit back together being careful to tighten the screws properly. I have had no problems since. Also be sure to check the connections to the battery, for some reason that motor is very sensitive and wants a really good connection to the battery posts and sometimes all you need to do is re-tighten the connection if the motor does not run at all.
    By the way, I contacted Minn Kota regarding the 3Hp and was told "hp" stands for high performance and the motor is not 3 Horsepower.
    Jan 19, 2010 | Minn Kota Boating
    Minn kota
    Hello bombiegano. I suggest you check you wiring terminals. They could be corroded. If you have good connections next would be fising line, string or weeds jammed in rotor of your prop motor. If these suggestions fail please inform me of Mgrf.,model & serial# & we can repair the unit. Good Fishing.
    Oct 02, 2008 | Minn Kota Endura 30 Freshwater Transom...
    Minn Kota Maxxum 70 Freshwater Bow Mount Trolling Motor Logo
    105 people viewed this question
    Top Minn Kota Boating Experts
    Mike Marcotte
    Mike Marcotte
    Andrew Taylor
    Andrew Taylor
    Colin Stickland
    Colin Stickland
    Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
