Refrigerators Logo
Posted on Sep 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a ge Profile (bottom freezer) refrigerator and the freezer is working but the fridge has now stopped working. Lights and controls seem to be working fine but fridge has not been cold now for two days. Any tips on what I can should do troubleshoot the problem?
Anonymous
Level 3:
  • GE Master 43,501 Answers
  • Posted on Sep 27, 2010
Anonymous
GE Master
Level 3:
Answers
43501
Questions
0
Helped
10842539
Points
101584
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
2 Related Answers
Anonymous
  • 263 Answers
  • Posted on Feb 06, 2010
SOURCE: my refrigerator is not getting cold but the
My bess guess is your main board went out.
GE refrigerator repair orange county, ca
Anonymous
  • 3773 Answers
  • Posted on Aug 19, 2011
SOURCE: Ge profile refrigerator with bottom
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If
you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
My ge profile bottom freezer refregrator is freezing everythin
is it freezing everything in the fridge as well? if so i had the same problem with my side by side fridge a while back. the appliance repair man told me to vaccuum the fridge underneath and all the other parts behind i did and it seemed to work well after that. also have you checked your temp controlls in the fridge.
I need to repair my GE profile refrigerator
The first thing you need to determine is if the compressor is coming on. If it isn't then the problem is in the lower section, PCB, start relay or capacitor or compressor. If the compressor does come on, then it sounds like your main board is the problem.
I have a GE Profile freezer on the bottom refrigerator model #PDS18SBMARBS. A fan was runnining on the inside of the fridge seemed to be between the fridge and freezer. It was very loud and now does not...
Could be a bad fan motor. A bad defrost part or a bad control board.
Check for ice buildup on the back wall of the freezer. If so you have bad defrost parts or a bad control board.
Enter your model number at www.appliancepartspros.com to find the exploded view to dis-assemble the freezer. You can also order parts from them.
Refrigerator and Freezer lights do not work and all display lights are not working either, but fridge and freezer are working.
Hi i'm sean I work for GE as an employee, this is a bad control board located in the rear of the refrigerator behind an access panel, you will want to change this as soon as possible it will possibly cause damaged to your sealed system on this model if prolonged in that condition. The board usually runs between 175.-200.
Sean
9helpful
3answers
GE Profile model PFS22MISBWW stopped working, panel problem?
Replace the main control board on the back of the refrig . PT# WR55X10656 . It's behind a panel about 10" x 6" .
Freezer works, but fridge doesn't
try checking the fan in the freezer at the top which pushes the coldness over to the freezer
GE Profile - Fridge Doesn't Cool But Freezer Works Fine
Had a similar problem with my Kenwood Fridge Freezer
If you're mechanically minded you could check if there's an opening and motorised flap (usually behind a cover) at the top of the fridge - Cold air from the freezer enters the fridge through this flap) The Sound you heard could have been the motor trying to open / close this flap. This flap can become frozen in the closed position - so cold air is unable to enter the fridge compartment) My fix was to thaw it with a hairdryer and reassemble. Another fix would be to empty the freezer and open the doors - it might take more than 24 hours but once completely defrosted if the flap is the issue it will have defrosted. Once plugged in again the door will open and cold air will start to flow into the fridge compartment. I had a quote for €195 for a call out / repair
I fixed it myself in an hour - Hope it works for you ...
Top Refrigerators Experts
vince
Johnny 1000
