Question about SimpleTech 100GB SimpleDrive portable USB - black Hard Drive
I have a SimpleTech Portable Drive (back-up)
How do I download just the new info that is on my computer? Everytime I go to update the portable it downloads EVERYTHING on my computer again and takes so long. I would like to be able to back-up my files on a regular basis but am having problems doing that as it takes hours each time.
Thanx
Richard
I assume you're using the StorageSync software. Go here to make sure you have the latest version:
http://www.simpletech.com/support/support_downloads_storagesync1.42.php
Since I don't know what you're clicking, I can only tell you that you need to choose the "Incremental Backup" radio button at the bottom left of the Backup Window, then click the "Backup" button.
g
Posted on May 27, 2008
Can I retrieve info,documents etc. from these old bkf. files on my simpletech 160gb usb 2.0 portable drive
The BKF file is only a reference to allow the XP os to know what program opens which file. It doesn't contain photos or music or documents.
Jul 09, 2013 | Computers & Internet
I have a SimpleTech backup drive, model 96300 40001 001. this Simple Tech tells me there's nothing new on my computer when I want to backup new files. I have all the proper directories checked and
in XP click start all programs accessories system tools you should see back up after the back up finishes windows will tell you your computer back up was successfull
also you could right click on the back up file select properties this will tell you how many GB were used
also you might use the easy transfer
http://windows.microsoft.com/en-US/windows7/products/features/windows-easy-transfer Windows Easy Transfer
hope this helps
Nov 13, 2011 | SimpleTech SimpleDrive Portable USB 2.0...
I made a mistake and reformatted my SimpleTech Signature mini portable hard drive without first downloading the software to my desktop first before formatting..??and now I do not have the software that...
I don't quite understand what you're trying to accomplish. Do you want to try and restore the data that was formatted on the Simpletech drive? If so, follow the link and get a software program called recuva http://www.filehippo.com/download_recuva/ It's freeware. If you can't get it with that then there's another software program that I use quite often called Easy Recovery Professional. It's not free, but it's saved me quite a bit of time recovering lost files that I forgot to back-up.
Apr 30, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
SimpleTech portable hard drive 250gb
are you using a power source for the unit, it has to have its own power supply to work. if you have the cable connected for the power and the usb connected to the laptop/pc, go to the windows log and right click on the logo, a menu will pop up. click on device manager on the device manager settings you should see your drive probably with an x on it, click on the drive and go to the update drivers and make sure you're on the internet. and click update drivers, if there is a driver that windows can use it will install the driver if not, then windows will not load a driver. if still not working try this web site Solvusoft Microsoft Gold Certified Company and download the drivers from them. if this still does not work then replace the usb cable as it may be faulty.
Aug 08, 2017 | SimpleTech 250GB USB2.0 7200 RPM External...
SimpleTech 80 GB Portable HD Won't Read
It sounds like a problem with the board inside the case,- the actual hard drive is probably OK. Opening the case will void any warranty but there may not be much left anyway. There should be 4 screws in the bottom of the drive,- front 2 may be hidden under a sticker. Try installing the drive in your new case or an empty drive bay inside your computer. I have had external hard drive cases fail before and the actual hard drive was ok.
Jan 23, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Sounds like the file system on the disk is now corrupt. You may need to use a recovery programme to get your files back but nothing is for free.
Jun 17, 2017 | SimpleTech 100GB SimpleDrive portable USB...
Simpletech 160 Portable doesn't show up
go into the control panel and click add/remove hardware... and manually add the device and then use the auto update to download the drivers
Jan 22, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
SimpleTech 100GB SimpleDrive portable USB - black Hard Drive Logo
148 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
