Question about Sony Computers & Internet
How to open the case of rz 32g
What type of screw driver bit is needed?
    Sergeant:
  • 458 Answers
Phillips if it is like any other case. Look at the screw and compare to you screw drivers.
Posted on May 29, 2008
I need audio driver for gigabyte 8S651MP-RZ for xp 32 bits
The Gigabyte GA-8S651MP-RZ motherboard uses a Realtek ALC655 audio chipset,
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128258R
Scroll down;
OnBoard Audio / Audio Chipset / Realtek ALC655
Realtek Support,
http://www.realtek.com/downloads/
Click on High Definition Audio Codecs (Software)
Click in the empty square box to the left of -
I accept to the above
Now click on Next
Under the Description heading go down to the green -
Windows 2000 / Windows XP/2003 (32/64bits) Driver only
(Executable file)
Go to the right, and click on the country abbreviation that is closest to your country.
[United States 2, United Kingdom 1, Canada, United States 1, Hong Kong 1, United States 3 ]
A small window will come up on the right -
Opening WDM_R270.exe
Click on Save File.
A small window will come up on the left.
Allow the file to fully download, then DOUBLE-click right on the file name.
Follow the easy instructions.
[If a Microsoft 'Squawk Box' opens up, ignore it. Click on OK ]
Regards,
joecoolvette
Oct 04, 2012 | Gigabyte 8S651MP-RZ (GA-8S651MP-RZ)...
Opening a Toshiba MK8010GAH drive case - what size Torx bit?
I've had luck using a T4 Torx precision driver. Sometimes I strip one of the 5 screws out in opening it but you are right that the T5 is too big. I just put a lot of pressure on the screw.
May 07, 2012 | Apple iPod nano 5th Generation
I want motherboard drivers for GA 81845GVM-RZ
Driver download page for the Gigabyte GA-81845GVM-RZ motherboard,
http://www.gigabyte.com/products/product-page.aspx?pid=1767&dl=1#driver
Choose your Operating System.
I'm going to choose Windows XP 32-bit as an example;
The audio driver is a RealTek AC '97
For additional questions please post in a Comment.
Regards,
joecoolvette
[ When Downloading, SAVE the file. Now look in the top of the second window. Write it down if you need to. This is where the file will download to. When you see the file name, DOUBLE-click on it. Follow the easy instructions. After it's finished installing, close all windows, go back to your Desktop screen. Restart your computer ]
Sep 24, 2011 | Gigabyte GA-8I845GVM-RZ Motherboard
On the rz twenty one 2( 3 weeks old ) i need to adjust my brakes i can take them down to the grips before they engage
Wind you barrel adjuster out a bit by screwing the knob on the brake handle out. Then screw the little ring Back up to the brake handle.
Jul 06, 2011 | Cannondale RZ One Twenty 3
Where do I find a screwdriver to open up the case? The scews that hold it together have a raised part in the middle of the screw head so a regular screw driver does not work.
Hi there
Most decent tool suppliers will sell you a kit of bits that are interchangeable with most battery drill/drivers.
Loads of manufacturers fit these raised center screws either hex or torx driver to reduce the number of people who can repair their equipment.
Regards
Gordon
Apr 17, 2011 | Soleus Air 25-pint Dehumidifier
Reset time and date on cold start, battery problem?
find the disc type battery and remove it replace with the same model of battery.
Mar 08, 2010 | Gigabyte 7VM333M-RZ (GA-7VM333M-RZ)...
I wanna change my onboard vga with new AGP vga ,,,
Thats easy when your looking at the front of the case unscrew the left hand panel.(2 screws on the back) Now look at the agp slot its the one closest to the power supply. Punch out or unscrew back back blocking plate where the card pokes out. (Great cut warning on that if its the punchout type never use your hands! Always use a tool! They cut real bad!)
Now earth youself on the case by touching it before touching the card. Slip the card into the slot and screw it into the back plane on the top. Once the card is installed fit the side cover back on. Now plug the VGA D shaped connector (15 pin) into the back of the new video card. Now your ready to start up the machine. While the computer is booting with the new card insert the driver cd that has come with the card. When windows boots just follow the prompts and it will install the drivers. Its as simple as that. When you install a new card you don't need to remove the old one because its a part of the motherboard. The motherboard realises that you have a new card in and it uses that instead.
Don't forget to rate me!
Cheers
Apr 06, 2009 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
Computers & Internet Logo
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
