Question about Garden
Stiff operation on valve handle - Garden
  • 10,865 Answers
Hello. Try loosening the nut below the handle just a wee bit. This will usually solve the stiff problem. J.
Posted on Sep 27, 2010
How do i unlock the door in a 2001 buick century
Most auto shops use a wedge type tool to spread the door frame away from the car enough to get a long stiff rod that is bent on the end through the crack to either operate the electric lock switch or pull on the door handle. Don't think a coat hanger will be stiff enough but you can try.
Jun 04, 2018 | Buick Cars & Trucks
Why are my gear controlls on my handle bars stiff and hard to move
COULD BE RUST IN THE CABKLE, OR A FRAYED WIRE
Mar 20, 2015 | Cycling
What would be the problem if powersteering is very stiff. Have drained and replaced with new ATF, but still stiff?
Check the drive belt for condition and tension. Have a pressure test done on the pump to ensure that there is no internal problems . Check for relief valve operation . Check that the valves in the box/rack are operational and not stuck. Most of these suggestion will have to carried out by an accredited steering repair shop. If you have an electric driven pump check that the motor is getting current and is operational.
May 12, 2014 | 2005 Ford Fiesta ST
Toilet handle sticks
It sounds like the nylon nut which holds the handle in place is too tight. Try loosening that nylon nut just a little to see if the handle moves easier. Sometimes if they are over-tightened, the handle will be stiff and hard to operate.
Apr 10, 2014 | Home
Stiff handle
using your finger apply STEM GREASE to valve. spin valve on an off several times . will be like new.
Dec 15, 2012 | Moen Plumbing
Handle is stiff to operate
remove trim to expose valve, apply stem-grease to valve with fingers and re-assemble. turn valve on and off several times. like new
Dec 12, 2012 | Hamat 3-2810PC Everest Pull-Out Kitchen...
The handle function is stiff. Does not move smoothly and easily. How to lubricate?
You need to take the handle off and remove the cariridge and then place a food grade lube on all the moving parts. The replace the parts as you took them off.
You may fine your going to have to replace the cartridge after you remove the old one. So just dont do it at a time when the store are not open. Unless you have valves under the sink faucet
Best of luck
RJ
Sep 04, 2011 | Kohler K-12176-CP Fairfax Single Handle...
Really stiff turning. I am looking at a 2008 CBR 600 on craigslist and when I took it for a ride, the handlebars were extremely stiff. It's hard to describe, but when doing a tight turn the handlebars...
take a riding course... the instructor will tell you to push the handle bar to the opposite side you are turning when running about 30mph and you really dont turn the handle bar when turning at a high speed. in low speed, handle bars should not be very stiff. maybe check tire pressure.
Jan 15, 2011 | 2008 Honda CBR 600 RR
Garden Logo
20 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
