Question about Toshiba Satellite M65-S821 Notebook
Lcd stripes how can i repair my laptop it has vertical stripes
  • 2 more comments
  • john navi May 24, 2008
  • dickon Jun 29, 2008
    I have a Toshiba Tecra 8200 P111 Laptop Computer and I have yellow vertical strips all of a sudden. Also DVD playback has intermittent black stripes on white backgrounds. Any suggestions as to fixing them?
    Mr MC Doherty
  • Anonymous Jan 31, 2009
    I have a white stripe on the left side of my Allienware LCD's laptop, it is about an inch thick, and five percent of the time it goes away, and then comes back. I did huck up an external monitor and the problem did go away. I am wondering if the problem could be caused by some of the drivers, because like I said before, the stripe goes away some times.
  • 502 Answers
I'm afraid that the red lines indicate that the screen needs to be replaced. As much as I would like to be able to tell you a quickfix that will solve the problem . I work for a Laptop Repair shop and if a solution popped up for removing this problem without having to replace the screen, we'd be very curious to find out about it. The reason is that the flexcable that leads the signals into the actual LCD panel came loose, it is not an external connector issue, but rather related to how the internal signal flow of the LCD panel. It is not a solderable connection that on that can otherwise be repaired.
Laptop Repair NYC.
Posted on Jan 04, 2009
I have got a White ******** the right hand side of the screen. This is a replacement LCD I bought as a second hand. What I have noticed there is a curcuit at the back of the LCD. Is thıs because of a chip in this curcuit not functioning. I keep the broken original lcd and try to replace the curcuit.
What do you suggest? What is the root cause?
Posted on Aug 21, 2008
  • 144 Answers
normally with vertical stripes it can happen due to
1.a bad LCD (small little chip inside LCD and can't manual repair)
2.a loose connection cable
so here what I do is first I try to tab at then back of the LCD and see that the problem goes away or not.If yes then a loose connection.
if no what I would do here ,coz I have a spare LCD I just exchange to test it...if the problem goes away then a BAD LCD.
Incase of verticle line due to bad LCD you can't repair it trust me.All the small IC chips are blended with board and can't really be repair.More quesiton feel free to post here.
Posted on May 24, 2008
2 Suggested Answers
  • 466 Answers
SOURCE: I have vertical stripes of different color on my
Looks like LCD problem. Try gently pressing the LCD frame near the hinge, where the stripes are. If they are caused by a bad contact in the LCD driver strip, this sometimes fixes the problem.
Posted on Oct 31, 2009
My screen has a thin, vertical, black stripe about one inch over from the right. It also has a tiny red vertical stripe next to the black one, as well a few blue ones.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Line faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD screen are similar, irrespective of its brand and screen size.
Mar 04, 2016 | Insignia Televison & Video
Rainbow stripes and color changing gradient box
Since this is a problem that obviously occured because the laptop fell and the LCD got damaged I suggest you take it to a repair shop, if it can even be repaired.
May 01, 2013 | ASUS Eee Computers & Internet
My Toshiba P105 has a vertical white stripe on its monitor. Any help is appreciated.
A vertical white stripe means a portion of the lcd has will continue to get worse as time progresses. The ONLY way to fix it is to swap the lcd out with a working one. It isn't a loose connection, etc.
Mar 18, 2011 | Toshiba Satellite P105-S6104 Notebook
Tripe on screen
if there is a stripe (vertical or horizontal lines) on the screen, please call immediately this tech support line 1-800-426-7378 for LCD repair...
May 20, 2010 | Lenovo ThinkPad® R50e (1842SRU) PC...
I have vertical stripes of different color on my laptop background? Is that graphic card problem or LCD problem?
Oct 31, 2009 | Dell Inspiron 1420 (dncwja1_1) Intel Core...
Dark vertical stripe on monitor
You screen "LCD" is broken , need new lcd panel. Very expensive
Feb 01, 2009 | Samsung T220HD LCD Monitor
Acer 5670 screen has dark transparent vertical stripe
you will need to check the display cable and if that is ok, you will need to replace the display panel... You're getting a short on the circuit board causing rows of pixels to be blocked out
Here's your display on ebay...
Jun 13, 2008 | Acer Aspire 5670 Notebook
Black Out
Hi Detrix, Check with if you want a repair. Something is wrong with your LCD controller and or GUI interface circuit or the circuit supplying power to it. If your technically endowed, you may want to open the monitor case and clean the dust and lint from around the circuits using a Small paint brush to sweep away any built up dust. These circuits take the Signal from the computer and controls the 2.5 million pixels on the LCD screen. Dsut can cause major problems with handling all that data. Give it a shot, what do you have to loose, its not dangerous if the monitor is unplugged.
Oct 09, 2007 | Samsung SyncMaster 193P 19" LCD Monitor
Toshiba Satellite M65-S821 Notebook Logo
1,535 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
