Question about Black & Decker BL9000 Blender
I was grinding rice......after that fumes came out and its not working now
  • Black & Decker Master
  • 43,501 Answers
The motor has burnt up... you will need to replace the blender.
There is an old saying that motors run on smoke...once the smoke comes out of the motor the motor will no longer run... :-)
heatman101
Posted on Sep 27, 2010
Tip
Failure of grinding, blending, or mixing kitchen appliances
Generally, a blade or grinding or blending/mixing part that is permanently attached to a metal shaft from the appliance motor is held on that shaft by a 'shear pin'. This pin breaks when something is put in the appliance that the grinder, mixer, blender can't gring, mix, or blend. This is to protect the motor from overload. Afterwards, The motor will continue to turn, but the blade or paddle, or whatever will not turn.
The shear pin needs to be replaced.
The shear pin passes through one side of the base of the bade/grinder/paddle assembly, through the motor shaft, and out the other side of the blade/grinder/paddle.
The piece of the pin must be removed from the shaft, and from the two sides of the blending/grinding part. This is generally a press-fit, and some effort may be required to accomplish this.
When the pieces have been removed, a common 'roll pin' of the appropriate diameter should be inserted to hol the turning part on the shaft. It must fit tightly, and some effort should be required to insert the new pin.
on Feb 07, 2010 | Blenders
Cuisinart stand mixer making grinding noise. What is it and are there directions for fixing/replacing it?
inside those mixtures there is grease or oil to keep the gears running smoothly. look on your counter or where it is stored and look for grease or oil. if there is then your best bet is to find a repair shop. ask where you got it from, they should be able to hlp.
Oct 29, 2014 | Cuisinart 5.5-Quart Stand Mixer SM-55-...
GRINDING COFFEE BEANS
Grinding beans is a personal preference job. The finer the grind, the stronger the flavor. You get more surface area contact with the water. Pulse, don't just hold it on. Pulsing prevents heating up the beans and making the oils bitter.
Feb 03, 2012 | Blendtec Blenders
Hi, Oh no!!!!!!, my blade has seized up and left little black bits of the gasket right under the blade in the jar. Can I get this gasket? We bought this absolute AWESOME Blender at the Home Show here in...
The bearing and seal are not replaceable. The bearing is sonically welded into thte base of the jar. The K-Tec is made by Blend-Tec, and any of the Blend-Tec jars will work as a direct replacement.
Sep 11, 2011 | K-Tec Champ HP3 Work Top Blender
My magic bullet express blender just stopped working while i was grinding soaked rice . will it work after a few hours when the motor cools down?
Most probaqbly not wet rice is possssibly too heavy for this littel motor to handle. The instryuctions say short bursts of grinbding. If the motor overheated it is possible the winding are now burnt and the unit is not repairable.
These cost 29,99 total in most discount online stores and a repair to the motor $99.00
Please rate my help++++Thanks for using FIXYA
Jun 25, 2010 | Emson Magic Bullet Express Blender
Black & Decker BL9000 Blender Logo
425 people viewed this question
Top Black & Decker Blenders Experts
john h
Are you a Black & Decker Blender Expert? Answer questions, earn points and help others
