Question about Garden
I am looking for table mounts for an Alltrade Professional Bandsaw Model#1995-B-14S. The mounts that allow the table to tilt, have broken.
  • 10,865 Answers
Call the parts department at alltrade directly Phone: 800-423-3598
J.
Posted on Sep 27, 2010
I need to find the size and length of a powermatic bandsaw blade. Model PWBS-14
93.5 inches
Do you not have internet? I found the specs for your model instantly on Powermatic's web site. Don't be so lazy!!
Feb 27, 2015 | Powermatic 14" Bandsaw Model PWBS-14CS
I want a manual for a sears 12in. Tilt head cabinetmakes Bandsaw, Model 113.247311c
you can get it directly from www.sears.com and click on live person. they will look it up for you and ordered it for you.
Nov 03, 2014 | Saws
10 inch lest tilt Unisaw will not tilt to complete verticle --only goes to 88.5.
There is an adjustment under the table top. It usually is a bolt with a lock nut that allows you to adjust the table to a predetermined angle every time. You can adjust the amount that the table will go by unlocking the lock nut and then turning the bolt the correct direction allowing the table to come to a full 90 degrees. Once you have the table a 90 degrees lock the bolt down with the lock nut. This will aloow you to change the tilt of the table to something other than 90 degrees and then come back to the 90 degrees by turning the adjusting wheel until it bottoms out against the locked doen adjusting bolt.
Mar 17, 2011 | Delta 36-979 10" Left-Tilt Contractor's...
Need a manual for a sears/craftsman model #103.24300 bandsaw
Any particular reason? If general settings problem, please follow this advice:
Brand of bandsaw is of no importance, problem is... I assume that problem is with regulation of the blade motion. Please follow these instructions, I posted them previously for another member, they apply to any bandsaw in existence, regardless of brand, manufacture, age or look...
I love bandsaws, they are one of best and most universal woodworking machines, used as well in food and metal industries.
Now, what you should know about bandsaw that it have several points of regulations and all of them must be adjusted correctly. Basic "anatomy" of bandsaw is that it have body, in it there is housed driving wheel (bottom) and tension wheel (top), both of these are protected by rubber "tyre" usually crowned, that allow for better self adjustment and protect teeth on the band.
Switch machine off and remove power plug from the socket.
Start with tension, open covers, retract top (above the table) and bottom (below the table) guides so blade is not touching the rear bearing or side slides.
1. rotate top wheel and see where blade is wandering, regulate tension and tilt on the wheel till band position itself on the centre of the top wheel, is rotating freely without wandering, and cuttin edge is off the wheel or rubber and do not touch the wheel or raiser.
2. cut strip of paper and slide top guide towards the blade till bearing touch blade through the paper (paper thickness is about correct distance of bearing to the blade), allowing paper to be slided out without tension. lock bearing guide in.
3. insert paper on internal side of the blade and slide internal slide guide block till you can only pull the paper out, lock the slider.
4. repeat previous (3) operation on external guide block and after you slide paper out, lock it in position as well.
5. manually rotate the tension wheel, should operate freely, without wandering, without touching bearing or side slides.
6. repeat step 2 to 5 on the bottom guide
7. close the covers
8. adjust hight of the top guide suitable to cut , allowing about 2 finger breaths above the cut piece.
9. connect power, switch on the bandsaw and switch off, after it stop, check for tension, switch on and make test cut.
This general rule applies to all bandsaw, regardless of brand, make, vintage. Do remember that this is not a toy, it will cut through, wood, metal and your fingers...
Do remember, that these operations must be performed every time when you change the blade, do not forget to use bit of silicone or teflon spray if you cut very sappy or green wood, do not press and force, allow blade to slide and cut, use protection screen and googles, you have only two eyes and there are no spares...
If you have problem with your bandsaw, not related to adjustments, please do not hesitate to ask further questions, let us know how you get along with this info.
Aug 15, 2010 | Craftsman Saws
Sorry as i have extremely little amount of info on this machine (not mine ) i said i would fix it for her it is a 3 wheeled machiene made by rexon i asked for the model & was told all she could find...
Brand of bandsaw is of no importance, problem is... You did not stated what is exactly the problem, I assume therefore tha tproblem is with regulation of the blade motion. Please follow these instructions, I posted them previously for another member, they apply to any bandsaw in existence, regardless of brand, manufacture, age or look...
Now, what you should know about bandsaw that it have several points of regulations and all of them must be adjusted correctly. Basic "anatomy" of bandsaw is that it have body, in it there is driving wheel (bottom) and tension wheel (top), both of these are protected by rubber "tyre" usually crowned, that allow for better self adjustment and protect teeth on the band.
7. close the covers
If you still have some trouble with your bandsaw, please do not hesitate to ask further questions, let us know how you get along with this info.
Aug 13, 2010 | Saws
I cannot get the blade to track correctly on my JET 12" band saw. What could be wrong? I have done exactly what the manual says to do. I am not sure the square box on the outside is fitting. The little arm...
i love bandsaws, they are one of best and most universal woodworking machines, used as well in food and metal industries.
now, what you should know about bandsaw that it have several points of regulations and all of them must be adjusted correctly. basic "anatomy" of bandsaw is that it have body, in it there is driving wheel (bottom) and tension wheel (top), both of these are protected by rubber "tyre" usually crowned, that allow for bette adjustment and protect teeth on the band.
start with tension, open covers, retract top (above the table) and bottom (below the table) guides so blade is not touching the rear bearing or side slides.
1. rotate top wheel and see where blade is wandering, regulate tension and tilt on the wheel till band position itself on the centre of the top wheel and cuttin edge is off the wheel or rubber and do not touch the wheel or raiser.
2. cut strip of paper and slide top guide towards the blade till bearing touch blade through the paper (paper thickness is about correct distance of bearing to the blade), allowing paper to be slided out without tension. lock it in.
4. repeat previous operation on external guide block and after you slide paper out, lock it in position.
7. close the covers
8. adjust hight of the guide suitable to cut , allowing about 2 finger breaths above the cut piece.
9. switch on the bandsaw and switch off, after it stop, check for tension, switch on and make test cut.
this general rule applies to all bandsaw, regardless of brand, make, vintage. do remember that this is not a toy, it will cut through, wood, metal and your fingers...
do remember, that these operations must be performed every time when you change the blade, to not forget to use bit of silicone or teflon spray if you cut very sappy or green wood, do not press and force, use protection screen and googles, you have only two eyes and there are no spares...
Jul 30, 2010 | Jet JWBS-16B 708749B 16-inch Bandsaw
I have a 23" LG monitor W2343T PF. I have taken off the oval base, but I need to get rid of the stump that connects the monitor itself to the oval base that sits on the table. I have been to two Best Buy...
I have checked with LG and unfortunately there is no option of taking out the stump as the monito was meant to be kept on the table over the stand which came along with it.
Bur we do have a option of all mounting the monitor as well for which you will have to separately purchase the wall mount plate.
Please call the customer services at 1300 54 2273.
According to your monitor size, you should choose the right mount fits your monitor size. Also pay attention to the mount max loading weight.
The wall mounts have various kinds of format. Such as tilt mount format, flat mount format, swivel/tilt format what you like to mount it.
You can visit the professional monitor mount store www.mount4less.com.
Feb 18, 2010 | LG Computers & Internet
Manual Craftman professional router table model
I have a Craftsman professional router table, laminated model 26608. I can not find a parts manual for this item. I tried a number of way to find parts for this item. I believe this was made by Bosch. I can not purchase a Router table mounting plate for this item. it measures 7" x 8". with a center hole of 3". also 3" insert rings. Bosch and Sears makes items for a professional router but the center hole is 3 3/4 inches and the plate is a lot larger in width and length. I have gone to Bosch on the internet and came up with a model RA1171. This is a model like the one I purchased; however, they have changed the size of the adapter plate and the center rings. the model no. they show is 29LCN1428.
Dec 31, 2009 | Craftsman Milescraft 1207 Turnlock Wood...
Garden Logo
47 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
