Question about Garden
Ryobi 700r 2 cycle gas trimmer: startin OK. but after run and warmed a few mintes and changing the shoke to the open fina positio ( C) the machine seens to work well. Problem is that has no thier usuan high speed and lose force when goes over a stron grass. Finally the engine stops . only eay to cut the grass: leaving the choke at position (B) how can I adjust the gas(air blend?? thanls ernesto.
    Scholar:
  • 71 Answers
Your carburetor needs to have a basic rebuild. You can attempt to adjust the 'H' (High Speed screw) by removing the plastic top of the screw with a pair of plyers - just pull off. This Ryobi model was built over several years with serveral different carburetor models. Some will be adjustable after removing the plastic top off the screw and some you will need a special tool.
Generally, no further adjustment is needed and the problem is more a result of one of the following:
1. Carburetor diaphragms need replacing as they become worn or more likely, stiff with age.
2. Exhaust or muffler becomes clogged with insect nests or carbon deposits.
3. Fuel line within the gas tank becomes cracked and starts pulling in air in addition to fuel.
This model's exhaust or muffler is not completely serviceable, but the carburetor rebuild kit and fuel line check is inexpensive and is a DIY project.
Posted on Sep 27, 2010
Need part for ryobi trimmer no.700r
There are parts and part number listed on page 20 of the manual. Here is the link for the Ryobi 700R trimmer manual.
Jan 07, 2013 | Ryobi Garden
Gas Trimmer will not stay started
Many times with a gas mix, after sitting for a while, the mix separates and gums up the carb. Taking the carb off and soaking it overnight in a parts or carb cleaner and running carb cleaner through the tank and gas lines will cure this.
Jul 02, 2008 | Ryobi 15" Electric Factory Reconditioned...
My Ryobi 700R "EZ" weedeater smokes excessively.
Check the fuel/oil mix ratio you are using. Some Ryobis use a 32:1 mix and some use a 40:1 mix. There isn't much difference there. To be on the safe side, if you machine is possibly running or tuned a little "lean" I would start off with about 4 oz/gallon oil to gas mix. Use synthetic 2-stroke oil also. Your machine will perform much better.
Nov 27, 2010 | Ryobi Garden
Ryobi 700r trimmer does not start. Changed spark
hve you checked the HT lead and the on/off switch i had the same model as this and i changed everthing but in the end t chucked the thing away and got a sthil modle
Jun 21, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Oil and gas mixture
Mixture is typically 40 or 50 to 1, gas to oil. The exact mix should be stamped on the gas cap.
Apr 10, 2010 | Ryobi 15" Electric Factory Reconditioned...
Hedge trimmer starts fine then stops after 5 minutes
Carburetor high speed adjustment ( screw nearest the filter ) open ( counterclockwise ) 1/2 turn.
Adjust again as needed to run when hot.
make sure the gas mixture ratio is as required.
Henry
Sep 20, 2009 | Ryobi Factory-Reconditioned 30cc 18" Gas...
Garden Logo
93 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
