Outside unit won't come on is there a reset button
  • 43,501 Answers
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
Posted on Sep 27, 2010
Where is reset button on my outside a/c unit
If you are talking about the condensor that sits outside,there are high pressure and low pressure devices that have a red button on the top of them, turn off power and push the button. They are sometines located inside the unit under the fan. Generally there are none and the unit has internal overloads that kick it out. they reset themselves after the compressor cools down. If it resets after cooling down then ask yourself why it got hot. use a hose and clean the coils around the unit.sometimes helps. make sure fan is running on the condensor outside. It should come on first.
Aug 13, 2014 | Heating & Cooling
Weather station won't work
i have the same problem and have had 2 of these now. outside unit blinks like it is transmitting but nothing on base. SYNC per manual does not fix it.
Jan 29, 2013 | Brookstone Wireless Weather Forecaster
I have an intertherm a/c outside unit. I cut a small brown wire weed eating. I spliced the wire, but the unit won't turn back on. Is there a reset button?
Check the wire carefully as it is most likely broken where you can't see it. or you have more thatn one wire broken.. this is very stiif wire and often break behind the insulation .
Jul 17, 2011 | Heating & Cooling
My fridgedaire window unit A/C and heat won't come on. I had replaced an outside light fixture a couple of weeks ago and had turned off the circuit breaker that affected this unit too. Now the unit...
Plug a light into the outlet used for the A/C, if the light does not come on when reset then the circuit breaker that provided the power to the outlet need to be reset or replaced.
May 22, 2011 | Frigidaire FAS257S2A WallWindow Air...
My outside fan will not run and the inside unit runs constantly. can't push the reset button on unit outside
Your out door unit fan motor not runs due to pressure not build up at Heat mode. If its cool mode only fan runs with compressor when thermostat calls for it.
Without having technical knowledge, don't press any reset button. Hope it's helpful?
Dec 09, 2010 | Ruud Central System Air Conditioner
Can i run the fan on my inside unit if the outside unit is not working
You should be able to run the fan on the inside unit if the outside one isn't working. If you're worried, turn off the circuit breaker for the outside unit. If you don't know why the outside unit isn't working, check the circuit breaker at the breaker panel, check the breaker inside the box that electrically connects to the outside unit, and check the outside unit for a reset button.
Oct 15, 2009 | Heating & Cooling
Where is the reset button on the Comfortmaker AC-model number NAC048AKC3? Thank you!
if it is a split system that is permanently installed in your house the reset button will always be near the compressor so that means on the outside unit somewhere, you probably wont need to remove any screws to get to it. but before you press that button and think all is well, why did the reset button trip? answer> because it is a high pressure cut off. your unit probably reached over 350psi on the high side line or possibly even higher. that is not good. you may have a dirty condenser coil (outside) and you can just hose that out with a garden hose (pull the disconnect first). or you may have a rotting out coil if your unit is old or you live less than 5 miles from the ocean. Or you may have a bad condenser (outside) fan motor. check that out. if it overloads again after hitting the reset (which this unit may not even have, not all units have these just the higher end ones) well if it does overload again call a licensed ac guy trust me it will cost you less in the long run.
Oct 09, 2009 | Heating & Cooling
Our dog chewed on some of the wires, which I've reattached before and had the thing work. This time they won't reconnect, though the unit itself can be run by pushing a button in the unit.
if this is a central unit and the button you refer to is on the outside condensing unit, the wiring is propbably not the issue, the manual reset button is generally a high pressure safety switch, when you reset it if it runs for a few minutes then shuts off again unit you can reset it, you probably need to wash your outdoor coil. (it may look clean from the outside and still be blocked from the inside) shut off the power, verify that power is off, remoave the top of the unit and wash with a hose from the inside of the coil to the outside, make sure you clean all ares of the coil, use the hose pressure to "push' any debris through the coil then rinse the outside, reassemble, let dry completely and then start the system
Jul 19, 2009 | Heating & Cooling
A/C Stopped Working
outside fuses are blown on condensor unit at dissconect
Jul 13, 2009 | Heating & Cooling
Do rheem air conditoner hair a reset button
The older unit have a High pressure reset at the outside unit, About center bottom by the copper lines. Push to see if it starts. If it resets you may have a dirty condensor coil. Wash good with water hose. Turn power to outside unit of first.
Jun 06, 2009 | Ruud UAKA037 Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
