Question about EliteGroup ECS GeForce6100SM-M (1.0) Socket AM2/ MCP61S/ SATA2/ A&V&L/ MATX Motherboard
Video Card Chnage
I have just bought a new PCI Express video card & installed it. However I get no picture from it. Everything still uses the onboard only. Is there a switch I am mising?
  • wayne1009 May 31, 2008
    I installed a geforce 7300 into this mobo. I changed the bios setting to "enable if no GPU", disabled the onboard video, then enabled the 7300. I plugged it up and got 1/2 blue screen. while it was still on I switched to the on board video and it was still on. I tried to change the frame buffer size to 0 but the lowest value was 16. I still got 1/2 blue screen.
  • Arnold H Jan 23, 2012
    i was wondering if you got this fixed i am also having this issue i tried doing the bios change but it only gives me the option to "always enable" or to "enable if no ext gpu" i also changed it so it can start on the pciex and i still get a black screen when i connect the monitor to my videocard
    President:
  • 2,351 Answers
Hi Rick, you need to disable the onboard video from within you're bios. Please go to page 28 in you're manual. This will show you how to enter the bios menu. Once there go to page 26, where you will find. Onboard GPU (Enable If No Ext GPU) set this to Disable. Save & exit you're bios. You're system will auto restart. Once windows has finished loading, install the driver software for you're PCIE card. Suggest you check for updated driver software for you're PCIE video card.
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Mike
Posted on May 24, 2008
I want to install my palit geforce 210 1gb ddr3 on my desktop with win7 & 3gb ram, model of cpu is aspireM5600. The problem is, when I installed the vdeo card driver and it requires to restart the
Using onboard graphics enter into the BIOS and set the setting to display to PCI-Express first then onboard if noexist PCI-E graphics.
Save and exit.
This will allow you to install your new graphics card to your monitor.
Take care!
damnor01
Sep 11, 2012 | Palit Microsystems Palit nVidia GeForce...
I just bought VTX ATi Radeon 5670 1GB GDDR 5 and i put it in my computer. I did everything..uninstaled old driver and instaled new drivers..But i cant get the picture on my monitor.
you may need to change some bios settings i don't know what type of BIos you have but the setting would read something like: initial display on boot...and the options would be onboard or pci make sue its pci
^but befor you try that try booting up your pc with the graphics card plugged in (if you haven't already tried)
Apr 01, 2011 | ASUS Video Card ATI RADEON HD 5670, (1 GB)...
Diablle Vostro 220 onboard video card
Installation of a PCI-Express 16 video card in the motherboard will automatically disable the on-board video.
I'll you should need to do is connect the video to the new card and load the drivers
Dec 05, 2009 | Computers & Internet
My biostar g31 -m7 te motherboard does not boot when i try to add a msi rx800 pcie video card,,sometimes i get a overclock fail message after i remove the card and reboot,,,how do i get this card to work...
Turn the computer off.
Remove the PCI-E video-card.
Boot the computer.
Press DEL to "enter BIOS setup".
Disable the "onboard video" adapter,
or set the highest video-priority to be the PCI-E slot.
Save settings, but do not "exit" from BIOS setup.
Install the PCI-E video-card.
Disconnect the video-cable from the onboard VGA-port,
and connect the video-cable to the new video-card.
Turn the computer on, and the video-output through the new video-card should be displayed on your monitor.
Nov 05, 2009 | Biostar G31-M7 TE Motherboard
Best video card upgrade for Gateway GT4024???? Stock computer....except ram upgrade to 2x1gb....want to increase the video handling from the slow onboard video
Your upgrade options for a better video card are really dependent on how much you want to spend.  You have a PCI express x16 slot which is what your are going to use.  Visit www.newegg.com and you can look up video cards by manufacturer, memory amount, and even filter it by how much you are willing to spend.  Here's a link at newegg for "the best video card upgrade":
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161203
Since there is a newer PCI 2.0 Express connection on newer computers, you can get your video cards cheaper now.  You will notice a huge improvement with any video card you choose since onboard video is about the worst.  Just remember to go into the device manager and disable onboard video card after you install the new video card.
Good Luck
Jun 10, 2009 | Gateway GT4024 PC Desktop
Can't get Picture on Monitor, replaced video card
Boot up into the setup, usually F2- in the video section look to be able to make a change from Onboard to PCI ...apply-save change and exit ...also make sure you have connected the monitor to the correct area...I , like a big dummy, have often just hooked it up to the first blue socket i saw and of course...not much happens.
I hope this helps you Fred, (if it came with drivers install them)
please leave rating, thank you kindly
May 04, 2009 | HP Compaq Presario Media Center SR1750NX...
Dell Dimension 5100 won't start with new FireMV 2400 PCI Express video card
Did you check to make sure the video card is installed in the right spot? Has the onboard video card been disabled in Windows - and when you say it will not boot, do you mean physically no POST. Do you get any error codes? If you can get into the CMOS (Bios) Setup screen - change the primary display adapter from the onboard to AGP, PCI, or PCI-E depending on which card that is. Use this information at your own risk - hope it helps.
Aug 05, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Need help disableing onboard video, and installing PCIe video card.
Hi rebelel1271, I do have the manual for you're Intel motherboard. You can have it as well. Click on the link below to download you're manual. document.write("D101GGC Product Documentation & Manuals") D101GGC Product Documentation & Manuals
Intel states you do not need to make any bios changes when you add a PCI-Express video card. See this on page 17, PCI and PCI Express Auto Configuration. Before installing you're PCI-E video card, open windows controll panel. Than open add/remove programs. Look for the driver software for you're onboard ATI Radeon X200. Uninstall that software. (If listed). Close all opened windows & shut down windows. Unplug the power cord from the PC. Open the case. Install you're new ATI Radeon X800 PCI-E video card. Double check all internal connections, (In case you may have bumped loose any cables). You're X800 may also have a 3-pin or 4-pin male power connector built on the card. If so, plug power to the X800.
Intel D101GGC driver page.
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=2229&OSFullName=Windows*+XP+Professional&lang=eng&strOSs=44&submit=Go%21#DOC
ATI's web site for the latest driver's.
http://game.amd.com/us-en/drivers_catalyst.aspx?p=xp/radeonx-xp
A little information. Once you're PCI-E has been installed. You're system memory will increase.
Good Luck!
If I can help you further, feel free to post here.
Mike
Jun 01, 2008 | Intel D101GGC Motherboard
Can I install a PCI video card on my D915GAG?
Are you sure it's a PCI slot you are putting it into, and not a PCIe slot? If so, check your BIOS is set to allow PCI graphics.
May 26, 2008 | Intel D915GAG Socket 775 Motherboard -...
Monitor is blank when plugged into Nvidia Geforce 8600GT
is video card pluged in tell bios pci express video snaped down good
Jan 19, 2008 | Dell Dimension E520 PC Desktop
EliteGroup ECS GeForce6100SM-M (1.0) Socket AM2/ MCP61S/ SATA2/ A&V&L/ MATX Motherboard Logo
110 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
