Question about Frigidaire ATF6000ES Front Load Washer
Front gasket, and spring is off, and is there a n easy way to put it back on. Mechanically inclined!
    President:
  • 1,430 Answers
Here is a link that should help Replacing a door seal
Posted on Sep 27, 2010
How to change the torsion springs in my kitchenaid microwave oven KEMC308KSS01
Replacing the spring isn't very difficult if you're mechanically inclined.
You're basically removing a few screws, the front panel of the door is removed exposing only the glass part that's still hinged. The springs are exposed. Hopefully one spring is still in tack so you can see the orientation of how to put the replacement in. It's not very intuitive on how to do this part.
Check this link for more details:
Microwave Repair
Feb 12, 2015 | KitchenAid Microwave Ovens
How to change spark plugs on 2005 hunydai 350xg
  • I have a 2002 XG and they should be the same but the front 3 are easy but for the back 3 you'll need to take off the intake manifold so you will need a gasket kit for the manifold. if you are not that mechanically inclined u may want a mechanic to handle that. if u have a miss make sure it's not the ignition coils on top of the front 3 spark plugs. i made the mistake of replacing all of my spark plugs @180,000 miles to find out the miss was from one of my ignition coils.
  • good luck
Jul 12, 2014 | Hyundai Motor 2005 XG350
Amana tandem 7300 the seal in front came off. How do I get to it to put back on. Have wire that has come off? Help
The door gasket fits around and into a channel that's part of the front of the machine panel, the wire and spring then is placed in the gasket channel and stretched around. Not a very easy thing to do without prior experience. There is a spring expansion tool that Sensible Products has made to help in this installation. www.sensibleproducts.com. Pleazer Appliance...
May 20, 2014 | Washing Machines
My trigger on my DeWalt DW712 8.5" slide saw came apart, my fault. But springs and all shot out, how do i put it back together?
Hi Kacey
Carefully!
Being a mechanically inclined visual genius helps!
DeWalt has a great reputation as a tradesman's tool.
Hopefully their Warranty & Service centre can help!
May 20, 2014 | Saws
Door boot seal on a front load washer how to change
front gasket/door boot.... replacement isn't easy but do-able. first remove three screws that hold front lower panel on and remove panel (where lint filter is). then remove 3 screws that hold on top panel (screws located at rear of top of washer), next remove 3 screws on top front of washer, then remove 4 screws that secure the contol panel. you must remove the washer door at this point, just a few screws and pin hold the door on. now, remove control panel by gently pulling the top away from the washer, it's held by a few plastic snaps. then, remove three screws that secure front panel of washer. now you're ready to remove the old boot/gasket. first look toward lower right side of gasket and pull the spring and remove wire that secures front of gasket. next... at about 3 o'clock on the gasket you'll find a longer screw (about 3 inches) that secures the rear of the gasket. loosen this screw until you can remove the gasket. remove the water inlet and hose from the boot/gasket.... now remove gasket from washer. you're ready to install new boot/gasket. find the small triangle on the new gasket and line this up w/the triangel at the top of wash tub. begin working the gasket onto the lip of tub, make sure to align the triangle and water outlets of the gasket w/the triangle and outlets of the washer tub. once back of gasket is on install the rear wire holder and tighten screw to former tightness. now work front of gasket onto the lip of washer, install spring wire to secure the front. place water inlet and hose into respective holes on the gasket. put front panel back on, put door on, put control panel on, put top on... and wash. like i said, not easy but do-able... i completed it in 1.5 hrs w/no instruction.
Nov 11, 2009 | GE WSXH208A Front Load Washer
Install boot/gasket for whirlpool duet sport F/L washer
You will have to take the front off the unit. Just watch and remember how you do it. The hard part will be putting the snap spring back on. There is a special tool we use that make it alot easy.
Oct 27, 2009 | Whirlpool Washing Machines
97 4x4 honda 300 fourtrax shifter will not return after shifting.
Do you feel a spring back when pushing both up AND down on the shift lever? if not, your shift return spring(s) are not positioned correctly or missing.
Aug 18, 2009 | 1998 Honda XR 250 R
LG WM2032HW gasket replacement
I have changed these without disassembling the unit. Just remove the spring from the gasket, then peel back the gasket to remove the inner spring. This is the easy part, getting the inner spring back on is a pain in the neck, but it can be done. The spring will give you problems either way. Good Luck
Aug 14, 2008 | LG WM1814CW Front Load Washer
LG Washer gasket installation
You have to take off the front panel first. Un;lug unit, start with the lid, 2 screws at the back and push back.
Next uplug front console and remove (couple screws and snaps make sure you get the screws out of the dispenser)
Remove screws along top and down at the bottom where the drain is.
Oh the door lock too, you can unplug it or unscrew it, your choice.
remove the top weight to make it easy.
Put gasket on, then use a small vise grip and a long nose pliers to get the spring on.
Replace weight, panel etc.
No but the gasket on the front and then start at the bottom with the spring.
Work it all around and then use the smalll vise grip to open the spring. If you have an extra pair of hands that would help you.
There is a spring tool for it but it is in my tool box, sorry, but I hope this helps.
Be careful with the inside spring and wear safety glasses just to be safe.
Good luck
Sgt 48
Jun 13, 2008 | LG WM1814CW Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
48 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
