Can pilot light be turned down lower on intertherm mgh-055aa
  • 659 Answers
SOURCE: Gas Valve is leaking
I am a Nordyne dealer and you can replace your gas valve with a generic valve of your choice. You can try and find a supply house in your area that sells them or you can visit www.myhvacparts.com to find one.
Posted on Apr 05, 2009
  • 89 Answers
SOURCE: Intertherm MGH-056ABFC-91 won't kick on. Just
There is probably more than one limit switch. I'll have to get a wiring diagram of this unit. See if you can follow the wires from the wires from the limit switch and see if they go to another limit switch. Also you can put a jumper wire on the red wire and white wire on the unit outside and see if ti comes on.
Posted on Nov 03, 2009
koolbreezes
  • 540 Answers
SOURCE: Intertherm furnace pilot won't light
There should be a reset button in the upper chamer next to the fan motor. In the middle ,push in on the center red button to reset it, this tripps because it says I,m not gettig enough air flow due to a plugged or dirty fliter located on the front cover or door.
Posted on Dec 18, 2009
mpcheeseman1
  • 1400 Answers
SOURCE: pilot light won't stay lit
possible bad thermocouple.
Posted on Jan 14, 2010
SOURCE: 1990 Triple E mobile home
I've a similar problem and a new thermocouple solved it
J. N. Millet, Alberta
Posted on Jan 14, 2011
I have a Intertherm model MGH-075-ABWN-05 and the A/C stopped working. someelectrical problem i'm guess.neither the blower fan nor the outside unit are running at all
Check the drain line for a float switch. Remove float and check for water. Do not leave float out, you must clear the drain. Good Luck
May 10, 2017 | Intertherm Heating & Cooling
Model mgh-055 furnace. Why won't it light?
Pushing down the button causes enough gas to be fed to the pilot to allow it to be lit and remain burning. If nothing happened, the gas valve could be at fault.
Sep 20, 2015 | Heating & Cooling
Got Intertherm Model # MGH-055AB.. It lights for ap 10 seconds goes out then goes out... Over and over again does not stay lit long enough for the blower to start running?? ANY IDEAS HOW TO FIX IT ?
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset. If the s3 comes on then you have an issue with the unit and i would get a professional to help.
Air Conditioning Boca Raton
Apr 10, 2015 | Intertherm Heating & Cooling
I HAVE AN INTERTHERM MODEL MG-055AB TURNS ON BUT TURNS OF IN A 4OR 5 SECONDS ANY SUGGESTIONS
light pilot then turn blower on by thermostat. if it blows it out bad heat exchanger. if it stays lit shut down & pull burner assembly clean pilot orifice.
Feb 16, 2015 | Intertherm Heating & Cooling
Looking for a gas valve for a intertherm furance model no. mgh-055aacwl-06 ser.number mgh9009-00077
you need to contact your nearest a/c supply house. most company's that sale parts on line will not sale gas valves to the public due to liability.
May 15, 2014 | Intertherm P3RA-048K Air Conditioner
Intertherm gas fireplace, model BDM 35, pilot goes out
could be thermocuple or pilot blocked clean pilot then try make sure you are turning to on and not back to off i was doing this the other day some go clockwise some anticlockwise
Jan 02, 2010 | Heating & Cooling
Apr 05, 2009 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
32 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
