Question about Water Pik Shower Head
Connected shower head to hose and the hose connection to shower head leaks back toward line. There is a white end over the inside of the end of the hose. I believe this restriction is causing the line to leak. There is no water coming through the line...help!!!
I understand that the white vac breaker end should be connected to the valve not the hand shower. FYI a little leak from this connection when the water is switched off is normal.
Posted on Sep 30, 2010
My mira elite 2 shower is leaking,The flow and tempt is ok. but the leak has got worse and it is cold water the leak is not from the hose that is connected to the shower head. It only leak when its on
Please use plumbers white tape wrapped in a clockwise diection. Tighten and let us know Geraldine. Thank you and send us a picture if you can. Best of luck leave feedback
Jul 13, 2016 | Home
Leaking pipe behhind shower head
See if there is a wall behind your shower stall you will have to open up the wall to fix your plumbing repair and patch the wall
Nov 20, 2015 | Home
Do you need plumbers tape where the handheld shower connects to the hose?
No tape is needed. As a matter of fact, taping the threads will make it harder for the swivel nuts on either end of your hose to tighten down and seal on the black washers that are supposed to be inside those nuts. It's exactly the same as a garden hose connection. No tape required.
Aug 07, 2014 | Oxygenics Hand Held Multi Function Shower...
Leaking faucet
I've had problems with the O-rings at the head leaking, feeding back inside the corrugated hose covering, and pooling under the sink. Might be your problem as well. Verify by holding the head downward, and look for water beading out further up the hose.
Apr 04, 2014 | Grohe Ladylux Cafe Faucet with PullOut...
Waterpik troubleshooting
Make sure the washer is setting inside the shower head properly. If you over tighten it you could crack the body of the shower head making it impossible to repair. Be careful. Remember you may need thread sealant too.
May 18, 2013 | Waterpik EcoFlow Watersense with...
Leaking
Make sure you fitted the rubber O ring on the end of the shower flexible hose. That will seal the water pipe.
Mar 29, 2017 | Kohler K-9511-BN MasterShower Shower Arm &...
Kohler shower hose leak
If the problem is solely because of the rubber washer with screen you can buy any cheap replica hose and use the washer that comes with it. If the issue goes away you are done. If not, switch heads and see if the issue follows the head. If it does then there would be a crack in the head at the connection. If neither solves the issue then you must buy a new hose.
Apr 15, 2010 | Home
The shower hose leaks from the connection between shower hose and
have you tried teflon tape? wrap it around about 7 times and you will be fine.
Jun 24, 2009 | Grohe Movario 59" Metal Shower Hose -...
Water pressure to main hose has ceased, with water now pouring out of a small outlet pipe at bottom of unit next to fixing for main hose.
Sounds like your outlet at the top has clogged with grit/dirt. Turn the shower off, remover the entire shower head hose from its base (where it screws into the wall or pipe. Turn water back on. If you get a steady flow (as you should) the problem is isolated to the shower head/hose. Detach the shower head from the hose and clean the screen inside, attach hose back on first, try water again, if this flows then your blockage is in the head itself. After removing and cleaning the screen inside the shower head, reattach and run water, this should fix your problem, if not, you may need a new shower head. If the water will not flow to the outlet pipe alone, either your shower switch is broken or you have a serious plumbing problem.
Apr 16, 2009 | Home
Shower leaking
Tried new washers with no joy. Replaced hose.
Nov 16, 2008 | Home
Water Pik Shower Head  Logo
364 people viewed this question
Top Water Pik Home Experts
Donni Steen
Are you a Water Pik Home Expert? Answer questions, earn points and help others
