Question about Hotpoint WMA50 Front Load Washer
Please tell me where i can get a new door lock for my hotpoint WMA50
    Problem Solver:
  • 4 Answers
Hotpoint website should sell them i got something for my dryer from there.
Posted on Oct 06, 2010
Washing machine not heating
PLEASE CHECK THE WATER COMING TO THE FRONT WASH FRONT LOAD WASHER DONT HEAT THE WATER IT AS A HOT AND COLD WATER VALVE CHECK WATER VALVE
May 02, 2014 | Hotpoint WMA50 Front Load Washer
My hotpoint washing machine (model wma50) will not start due to the door lock light flashing yet the door is closed
common problem on these machine's, you need a new door handle which comes as a full assembley with spring and all attached.
open the door, using star screw driver remove top and bottom screws along with two near the catch.
the doo wil split enough to remove old handle and fit new 1.
Oct 16, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
My Hotpoint wma50 1000spin is not pumping out all the water
Check /clean filter its located next to sump hose ..Switch off pull plug 1st ..
Oct 02, 2009 | Hotpoint WMA50 Front Load Washer
Hi, i have a hotpoint aquarius 6kg wma50, my
Have you checked for blockage in the pump. Or the have been some problems with a ball that sits in the hose between pump and the drum. This can block the water. Check this berfore purchase new pump.
Jul 26, 2009 | Washing Machines
Hotpoint WMA50 won't final spin, and water stays in drum
Running with a restricted water supply probably took out the pump.
The stator requires a steady water supply for cooling and lubrication. Without this accelerated wear between the stator & magnetic poles occurs.
This additional clearance makes the magnetism insufficient to spun the impellor.
Oct 17, 2017 | Hotpoint WMA50 Front Load Washer
I need to change the door seal on a Hotpoint Aquarius WMA50
Basic diy tools should be ok. Take out lid screws behind plastic caps on edge(will be stars but small flat will do it).Lift front of lid and push back to remove.Remove kick plate and take out screws behind it.Remove band holding front end of seal and detach seal from rim of opening. Remove screws holding door lock and push lock through. Remove soap drawer & take out screws behind it.Carefully bring panel forward & slide to right to remove(Take care here with board &wiring)Remove screws holding front panel & lift front panel & remove it.Remove band from seal and your there.Note locating slot on seal. If possible get an extra pair of hands to hold panel with board to avoid damage.
Nov 16, 2008 | Hotpoint WMA50 Front Load Washer
Hotpoint WMA50
you can buy a replacement from hotpoint.
Jul 28, 2008 | Hotpoint WMA50 Front Load Washer
Door locked indicator light flashing
reposition the switch.. in the door
first try holding button at door with finger and press start..if same symptom appears...check tab that depresses that switch and if its good try to reposition or replace switch.
Feb 26, 2008 | Hotpoint WMA50 Front Load Washer
Hotpoint WMA50 Front Load Washer Logo
54 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
