I have a Carrier Heatpump. The thermostat states it is a "E1" problem. What does this mean?
  • akchinq Sep 27, 2010
    thank you.
  • 1,711 Answers
From Manual Carrier mention this.
E1 means the system is not cummunicating properly. Call carrier service.
Now Actual posible problem can be.
Most common problem is polarity of wires are reversed or hooked to t-stat wrong or loose contact. Check it out.
Posted on Sep 27, 2010
I have a carrier air handler heatpump can I use a Rudd heatpump condensor
Yes if they match up correctly. I would stay away from Ruud though. Best off with Carrier or Trane in my opinion. Also, if your spending the money to replace the condenser, you should spend the extra bit and replace the air handler as well. New systems use a new refrigerant that is more cost effective and better for the environment.
Jan 26, 2014 | Heating & Cooling
Dometic model 3313192 thermostat error code E1 what does this mean?
Hi By E1 error it means
Loss of communication between the Single Zone LCD thermostat and the module board. LCD will cycle between E1 error.
Check the link for regular maintenance Of the LCD thermostat.
If it doesn't help then you have to replace the LCD thermostat.
Ajin
http://www.google.com/url?sa=t&rct=j&q=dometic%20model%203313192%20&source=web&cd=1&ved=0CCwQFjAA&url=http%3A%2F%2Fmanuals.heartlandowners.org%2FHeating-Cooling%2FA-C_Units%2FDometic%2FDometic_Single_Zone_LCD_Thermostat_Operating_Instructions.pdf&ei=hOg0T7OUNIjkrAer4Ny6Dw&usg=AFQjCNEn2y9-ItUcF2KRJZ0dm0Ftrq8Jhw
Feb 09, 2012 | Dometic Rooftop RV Air Conditioner
My carrier comfort zone II thermostat is flashing E1. What does this mean and why am I having trouble setting my temps?
I suspect that if you change the battery in the thermostat. All will be right again.
Thanks for choosing FixYa.
Aug 27, 2011 | Carrier Heating & Cooling
Brought new thermostat wired it up as stated but keeps on tripping out
Hi; Need more info what is tripping out. Sometimes the old tstat has a different wiring code than the new . Is the unit a heatpump or elec heat or gas heat with cool...alpharome416.
Feb 19, 2010 | Carrier TSTATHCP Programmable Thermostat...
Carrier programmable thermostat flashes E3
manufacturers put their name on lots of other peoples stats. Honeywell has a very good help line and an online service. Need to know whose thermostat white- rogers, Or honeywell Or Model number
Aug 20, 2009 | Carrier 38CKC060 Air Conditioner
I have a carrier heatpump model 38Q130300 when I turn the thetmostat to run the fan the heat comes on and stays on until I turn the fan off. Any Ideas. Thanks Doug
suggest starting with thermostat replacement only because it sounds as if the fan/heating control has constant power.
good luck
Dave
Jul 16, 2009 | Heating & Cooling
Carrier Comfort Zone 2 flashing E2
the e2 error on your thermostat is a problem with the return temp sensor on your system, the only thing you can really do is call a company and replace it, you can't bypass it or remove it cause the system wont run properly
Jun 29, 2009 | Carrier 38CKC060 Air Conditioner
High Electrical bill - Appears to be heatpump problem.
Sound like there are running on emergency heat which is elrctric.Have the system checked out buy a local heating and cooling company. Have they checked the filter and changed them.
Jan 14, 2009 | Honeywell Electronic Programmable...
Open Questions:
Heating & Cooling Logo
43 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
