Question about KitchenAid KEYS850LQ Electric Dryer
Clothes take long to dry on Kitchen Aid Model - KEYE660WWHO
    President:
  • 512 Answers
First thing to do is vacuum out all lint from dryer, unplug, remove back and vacuum all lint out of it, also where vent hooks up. Then clean out duct work from inside of home to where it exits. Excess lint holds moister and causes dryer not to dry.
Posted on Sep 27, 2010
My kitchen aid gas dryer timer isn't working. The clothes dry when I run it but the timer doesn't work - Model #KGYE670BWH0. Where can I pick up this part relatively cheaply?
Hello there and welcome to fixya
This is a really easy part to replace and it is rather cheap you can purchase it online at repair clinic.com
Timer
RepairClinic Item # 528733
Timer assembly for dryer
Manufacturer Number 3405331
More
Skill Level Skill Level
$118.30
Quantity:
Oct 14, 2013 | KitchenAid Dryers
Our Kitchen Aid Gas dryer is heating, but not drying the clothes. Can this be fixed?
If your
dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about
Dryer Maintenance
heatman101
Jan 19, 2011 | Dryers
Kitchen aid dryer Partial drying the cloth
First you should make sure the exhaust vent and ducting and lint trap is not clogged or restricted, birds/insect nests, or lint build up. If the dryer is heating up it is most likely an airflow issue.
Jun 05, 2010 | KitchenAid KGYS850LT Gas Dryer
My kitchen aid dryer does does not reach the higher temperatures it used to--it takes a much longer time to dry clothes.-even when set at "high"
Please clean the entire vent system from the dryer to the outside.
Make sure the vent is not smashed behind the dryer.
Long time to dry complaints are usually due to restricted house exhaust vents.
To test...Remove vent from dryer and operate dryer with a wet load if the unit dries ok the vent is @ fault.
If not one stage of the heat element could be burnt out.
Jan 19, 2010 | Dryers
I have a kitchen aid electric dryer Model KEYE660WWHO, serial #1422813. My dryer won't start. The fuses have been checked and are fine. When you select the drying time, you can hear it ticking, but when...
ma be the door switch push on the door switch with a screw driver to see if it comes on if it does you have found the problem. If that does not work let me know and I will help you solve the problem.
Nov 28, 2009 | Office Equipment & Supplies
Doesn't heat to dry clothes.
i have the same problem and am looking for a solution too so i will write back and let you know
Mar 27, 2009 | KitchenAid Dryers
My kitchen aid superba won't spin until i take wet clothes out close the lid again so that it begins to spin while empty, and then return clothes and it will usually spin then, unless a heavy load, then i...
I think that you have a bad drive block. It is located under the inner tub and the agitator. It is a pretty intense repair if you have never replaced one.
Feb 28, 2009 | KitchenAid KAWS850L Top Load Washer
KITCHENAID dishwasher will not dry the dishes
kitchen aid mod kud101dl does not clean dishes well. lot of scum on door.
Feb 26, 2009 | KitchenAid Dishwashers
The dryer heats up & spins,clothes don't dry,lint areas are now clean
restriction in your vent check it from the back of the dryer it must be 4 inches in dia and clear get a flashlight and look behind the dryer see if its mashed coiled or folded check the dryer hood make sure if there is a bird screen on it its clear easy way to tell if vent is at fault disconnect from dryer and do a load then let me know
Jun 05, 2008 | Roper REX5635E Dryer
Gas clothes dryer not drying clothes
could be an ignightor problem reply and we can talk
Jan 03, 2008 | Dryers
KitchenAid KEYS850LQ  Electric Dryer Logo
341 people viewed this question
Top KitchenAid Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
