Question about Eureka Whirlwind 4488 Upright Vacuum
The vacuum is making a ruff sound when it is on. Like the motor is working harder then it should. Do you think it is a belt issue?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 100 Answers
1. belt
2. carbon brushes in motor
3. debris in brush?
4. brush end caps worn?
Posted on Sep 28, 2010
New belt now harder to push than before
the new belt already snapped is what it sounds like try taking it into guarantee vacuum and sewing center
Mar 26, 2014 | Dirt Devil Featherlite Bagless Vacuum...
Can't get the roller to spin
i suggest taking hose off and declogging it by using a water hose to make sure its free of debris. Plus check your belt first take off bottom plate the you'll be able to tell if belt is broken which it sounds like it is.
if belt is good and hose is clear and still brush wont spin then your brush motor needs replacing. hope this helps.
Mar 05, 2013 | Eureka Whirlwind Litespeed 5740 Bagless...
Hoover H3030-006 240 V Motor making a loud sound and burning smell
If you have little to no suction, that sound is happening because you most likely have a clog some were in the vacuum.
smell is probably your motor over working itself do to the clog.
also double check your belts on your brushes that they are moving with the motor. smell and sound could come from the brushes being jammed which would cause the belt to freeze and heat up and could burn the belt and or your motor.
if it is still running though your not in the red yetm so triple check that the machine is cleared off all clogs and jams in the belts and brushes.
Jul 02, 2011 | Hoover H3030 FloorMate SpinScrub 500...
It sucks but the roller doesnt turn...I think my motor has burned out?are these vacuums made anymore? I also need the manual for the model 116 35913401 thanks
this is not a motor problem this sounds like a broken belt. Take the model and make # to your local used vac store and they can help you with the belt. If you dont or cant install it yourself bring the whole maching to them and they will do it for next to nothing.
Oct 07, 2010 | Kenmore 35912 / 35913 Progressive Upright...
Grindind sound on carpet setting
If the belt is still connected to the brush and it is tight then the motor has gone wrong depending on how old the machine is you could take it back if not a repair is the only option
Jul 28, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My vacuum is loud and dies
your impeller is broken that make motor work harder and shut off
Oct 14, 2009 | Eureka 4700A Maxima Bagless Upright Vacuum
Loud noise
I think you damaged the belt. I ran over a sock once and it made a grinding noise but still worked for several months after the incident. Finally, the belt broke off. I had it replaced and now it doesn't make that sound.
Sep 26, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
I have a windtunnel bagless twin chamber. Model U5753-960. carpet adjustment is not working. It's harder to push than it was. It is not sucking up everything it should be. I just put a new filter in. ...
You probably need to replace your belt. Rubber vacuum belts require replacement every 3-6 months.
There are 4 screws on the bottom of your machine on the plate covering the brushroll. Remove these, remove the brushroll and belt, place the new belt over the motor pulley, (the metal bar sticking out of the motor,) then place it on the brushroll and pull the brushroll back into place. Spin the brushroll to ensure that the belt is not pinched, and replace the baseplate. Party.
-R
Aug 11, 2008 | Hoover Vacuums
Fixing my vacuum cleaner
Check to make sure that your agitator still spins. (Agitator = brush). If your agitator still spins, it eliminates your belt and agitator as likely culprits. The last possible solution would be that your vacuum is clogged. The grinding sound might be a motor-related issue or could possibly mean your bearings are going out. Check the bearings of the agitator and the motor of the vacuum.
Accessing to the agitator and belt can be done by removing the bottom cover of your vacuum. There are 2 scews that are holding the bottom cover to the head of the unit. Remove these 2 scews and the bottom cover should snap off.
Mar 07, 2008 | Vacuums
Panasonic MC-V7395 Belt overheating/snapping
I have the same problem. I keep thinking I have fixed it, but then another belt breaks. I only have the issue when the roller is disengaged. (on bare floor setting). I did find that the unit was slipping back into engaged slowly, because the disengage mechanizim was not kathing prperly,. Tightened up a screw, and now appears to hold, but somehow the belt still get broken - I beleave it is an issue that the belt is not staying away from the drive when it is disengaged.
Jan 05, 2008 | Panasonic MC-V7395 Vacuum
Vacuums Logo
24 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Irene Tulloch
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
