Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Craftsman LT1000 17.5 HP Lawn Tractor. Tractor starts and runs for a minute or so and then stalls and won't start again. I run the tractor every week or two to cut the grass and this has never happened before.
Make sure it is not vapor locking. My mower gets dust in the vent hole of the gas cap
Posted on Nov 10, 2010
  • Ron Sanders
    Ron Sanders Mar 17, 2016
    pull the carb bowl to see if the float needle is stuck. gas can leak by and let it start but then it will die, and not start again. Good Luck
Tip
2008 Craftsman lawn tractor
Tip for 2008 Craftsman lawn tractor that runs for about 30 minutes then starts to cut out and dies, and will not restart. These tractors have a defective gas cap that will not vent. Simply remove gas cap and reinstall loosely. The best fix is replace gas cap. If your tractor is less than two years old Sears will replace it free. preview_graphic.jpg
on Jul 30, 2010 | Craftsman 42" Briggs Stratton 20 hp Gas...
Craftsman lawn tractor model no.917.289101 stalls out
Stall or quits? Will it run 15 minutes again after it cools down. Check
carb bowl for water. Loosen the bottom screw a little until gas come out and water will "roll" off the gas that drops out on the deck.
May 21, 2012 | Craftsman Garden
My 26 hp tractor stalls and won't start when it gets hot
is there spark?is there fuel threw the carb?
May 01, 2012 | Craftsman Garden
I have a 7 year Craftsman 17.5 HP 42 in. lawn tractor. It starts to leak gas recently and stops frequently after running over 30-40 minutes. I can not identified where is the gas leak from but I saw gas on...
I have a Craftsman mower. Last year I had a similar problem with the mower stopping after running awhile. I noticed that the plastic gas tank was collapsing. The next time it began to stall, I immediately loosened the gas cap and it didn't stall. The vent holes in the cap had plugged up. Check this out.
I can't help you locate the fuel leak, although it sounds like the carburetor float is not stopping gas from flowing into the carburetor.
Dec 02, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 16.5hp 42 in. Mower runs for about
mine always starts-- and won't start again if I turn it off- going to try the flywheel key replacement-- which affects the timing-- otherwise-- let me know what you find out as a solution
May 24, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Tractor starts, but runs for about a minute, then starts to miss and then stalls. Sometimes it will not start again for awhile. Please advise.
sounds as though it has a bad ignition module,...check manufacturer for any call backs on this model,.....have all serial and model #'s. it does sound like it's ignition related,...or bad gas,..in which you'd drain and refill with new gas,......good luck, cracklin joe
Jan 09, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Tractor starts, stalls when blade is engaged, or brake released
you have a safety switch malfunctioning or a transistorized relay not working properly. Go to www.partsdirect.com, this is sears website. It should be able to find and illustrated parts list for your mower.
Sep 28, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
YS 4500 Stalls out after running for 20 mins
I do believe they change plug(s) and air filter? There could be impurities and water in tank. Check for any loose electrical connections. Problem with valve clearance. Keep me informed.
Jun 13, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
734 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
