Question about Weather King 12AJA4801AH Air Conditioner
3 ton split system manufactured in 1992. Condensr unit Hot Gas Sensor on top of copeland scroll is defective. The sensor is in the 25v control circuitry .Is it replaceable? If so do I open the refirgeration system when I replace it. I am EPA certified so no problem, I just need to know. Thanks! unit is a weatherking (ruud, rheem) wrcu-12361a
  • Weather King Master
  • 43,501 Answers
The switch on the top is replaceable and no you do not have to open the system...the sensor is just stuck down in there in a thermal conductive compound similar to a boiler sensor in a well...
Just get the sensor, pull out the old one and insert the new one...
FYI, many of the newer scrolls do not have the sensor...I think they figured out that they are trouble and also that they are not needed...
heatman101
Posted on Sep 27, 2010
Testimonial: "Thanks, you answered my question completly. I will get the part in the morning and have the system on line tomorrow morning."
What are color of wires that goes to the temperature line switch that controls the defrost cycle?
PDF]4HP13/14 SPLIT SYSTEM HEAT PUMP - Armstrong Air
www.armstrongair.com/_/.../Armstrong_4HP13L_Install_506318-01.pdf
4HP13/14 SPLIT SYSTEM HEAT PUMP .... indoor unit, outdoor unit contains system refrigerant charge for operation ... may be installed with up to 50 feet of line set (no more than ..... The defrost control incorporates 2 pressure switch .... Note: Sensor resistance decreases as sensed temperature increases. Pins/Wire. Color.Missing: tempstar
[PDF]RESIDENTIAL SPLIT HEAT PUMP SYSTEMS
icpindexing.toddsit.com/documents/086477/42808100101.pdf
This Manual Supports Split Heat Pump Units of The Above Series .... two groups is based on a difference in Defrost controls and/or the .... completes a circuit between µRµ ? µOµ in the the thermostat sub-base. 2. .... before connecting line voltage. ...Wire "S1" is the first stage of electric heat through the outdoor thermostat.
[PDF]Trane Installer's Guide Air Conditioner/Heat Pump 4TTZ0 ...
Jan 18, 2016 | Heating & Cooling
Goodman air condenser is humming but the fan does not come on
The most likely cause is the fan motor has failed. If it turns free then see if the capacitor is bad. Turn off the power remove the capacitor. Your local supply houses can test it for you.
Feb 15, 2013 | Goodman Manufacturing Goodman GSC130181...
My indoor fan motor comes on even when the thermastat is off
Is your thermostat perhaps programmed with a circulation option. Many modern thermostats have this option. check your fan options. They may be On,Auto,Circ. If it has a Circ or Circulation option, your indoor fan will still periodically turn on according to ASHRAE standards, even if your stat is turned off. if you poke the fan button you should be able to choose auto and this will solve your problem. Hope this helps.
Dec 17, 2012 | Goodman Manufacturing Goodman GSC130181...
1995 honda odyssey starting problems
Hello! in 1995 stored trouble codes used the On Board Diagnostic I software (OBDI)..Scanners will not work...The control unit LED can indicate any number of simultaneous component conditions by blinking separate codes, one after another...An instrument panel mounted indicator lamp will light and stay lit. If the lamp is on, or if a system malfunction is suspected even though the lamp is off, it is necessary to inspect the electronic control unit LED display. The LED display is on the ECM (ECU), which is located just below the RH side of the instrument panel. The indicator lamps operate whenever the ignition is On and a DTC is stored in the ECM (ECU) memory.
When an abnormality is detected the ECM (ECU) display blinks. The LED blinks a certain number of times, with the number of blinks indicating the number of the DTC. After the LED blinks a number of times there will be a two second pause and the LED will blink out the number of the next DTC..here are the codes..If there is a code send it to me...If there isn't a code I'll take it from there...guru.saailer
CODE DEFINITION
1 ..Oxygen Sensor "A" (Primary) defective circuit or unplugged / defective sensor
2.. Oxygen Sensor "B" defective circuit or unplugged / defective sensor
3 ...MAP Sensor (Manifold Absolute Pressure) defective circuit or unplugged / defective sensor
4... CKP Sensor (Crankshaft Position Sensor) defective circuit or unplugged / defective sensor
5.. MAP Sensor (Manifold Absolute Pressure) mechanical problem / disconnected piping
* not 94-95
6... ECT Sensor (Engine Coolant Temperature) defective circuit or unplugged / defective sensor
7... TP Sensor (Throttle Position) defective circuit or unplugged / defective sensor
8... TDC Sensor (Top Dead Center) defective circuit or unplugged / defective sensor
9... CYP Sensor (Cylinder) defective circuit or unplugged / defective sensor
* invalid code for throttle body injection Hondas
** invalid code for V6 engines
10.. IAT Sensor (Intake Air Temperature) defective circuit or unplugged / defective sensor
12... EGR Lift Sensor (Exhaust Gas Recirculation) defective circuit or unplugged / defective sensor
* invalid code for non-equipped EGR valve vehicles
13... BARO Sensor (Atmospheric Pressure) defective circuit or unplugged / defective sensor
14... IAC Valve (Idle Air Control) defective circuit or unplugged / defective sensor
15... Ignition Output Signal missing or defective ignition output signal
16... Fuel Injector System defective circuit or unplugged / defective fuel injector
17... VSS (Vehicle Speed Sensor) defective circuit or unplugged / defective sensor
19...Automatic Transmission Lock Up Control Solenoid Valve defective circuit or unplugged / defective solenoid valve
20 ..Electrical Load Detector defective circuit or unplugged / defective sensor
21... VTEC Solenoid Valve defective circuit or unplugged / defective solenoid valve
* invalid code for non-VTEC engine
** invalid for V6 engine
22... VTEC Oil Pressure Switch defective circuit or unplugged / defective oil pressure switch
23... KS (Knock Sensor) defective circuit or unplugged / defective sensor
30... Automatic Transmission Signal: "A" / SEAF / SEFA / TMA or TMB defective circuit or unplugged / defective sensor
* invalid code for 1996
31... Automatic Transmission Signal "B" defective circuit or unplugged / defective sensor
41... Primary Oxygen Sensor - Heater circuit malfunction
43... Fuel Supply System defective or malfunctioning fuel supply system
45... System Too Lean or Too Rich malfunction in the fuel monitoring systems
48... LAF Sensor (Lean Air Fuel) defective circuit or unplugged / defective sensor
54... CKF Sensor (Crankshaft Speed Fluctuation) defective circuit or unplugged / defective sensor
61... Oxygen Sensor, Heated - Sensor 1 (Primary) high voltage, low voltage, or slow response
63... Oxygen Sensor, Heated - Sensor 2 (Secondary) high voltage, low voltage, or slow response
65... Oxygen Sensor Heater (Secondary) malfunctioning or defective oxygen sensor heater
67... Catalyst system Efficiency Below Threshold malfunctioning or defective catalyst system
70... Automatic Transmission malfunction with the automatic transmission controls
71... Cylinder 1 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire
72... Cylinder 2 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire
73... Cylinder 3 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire
74... Cylinder 4 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire
80... Exhaust Gas Recirculation insufficient flow detected
86... ECT Sensor (Engine Coolant Temperature) circuit range / performance problem
90... Evaporative Emission Control System leak detected in the fuel tank area
91... Fuel Tank Pressure Sensor low input
92... Evaporative Emission Control System insufficient purge flow
Dec 28, 2011 | 1996 Honda Accord
After going over 40mph the check engine light goes on n it gives the code 440
How did you read that code on your car? A 92 Accord is supposed to give you pre-OBD honda codes, which are all below 100. Please check the code again and re-post it.
Jan 04, 2011 | 1992 Honda Accord
New copeland compressor wont start
Hello,By all means install a hard start kit on the cap.Your wiring is correct.A scroll compressor usally doesn't need a start kit but I have seen 5 ton units that take one.Check the compressor tag and make sure the compressor is not a 3 phase motor!
Apr 21, 2010 | Heating & Cooling
I have a code flashing on my ecu for a honda
This is from the first or second google search for "honda civic ecu codes". I'm actually going through this myself.
EF Ecu Trouble Codes
Reading EF ecu Trouble codes
Reading them's pretty simple. When there is a long flash this indicates tens and a short flash indicates ones.
Look under the Passenger seat (under the passenger kick panel for flashing LED - engine code. Short the plug under there.
For example: Flaaaaaash Flaaaaaash Flash = code 21
Flaaaaaash Flash = code 11
Flash Flash = code 2
1) Primary oxygen sensor- Defective circuit or unplugged/ Defective sensor
2) Oxygen sensor "B" - Defective circiut or unplugged/ Defective sensor
3) MAP (Manifold Absolute Pressure) Sensor - Defective circuit or unplugged/ Sensor
4) CKP (Crankshaft Position Sensor) - Defective circuit or unplugged/ Defective sensor
5) MAP (Manifold Absolute Pressure) sensor -Mechanical problem/ Disconnected piping
6) ECT ( Engine Coolant Temperature) Sensor- Defective circuit or unplugged/ Sensor
7) TP (Throttle Position) Sensor -Defective circuit or unplugged/ Defective sensor
TDC (Top Dead Centre) Sensor -Defective circuit or unplugged/ Defective sensor
9) CYP (Cylinder) - Defective circuit or unplugged/ Defective sensor
10) IAT (Intake Air Temperature)sensor- Defective circuit or unplugged/Defective sensor
12) EGR (Exhaust Gas Recirculation) -Defective circuit or unplugged/ Defective sensor
13) Atmospheric Pressure Sensor - Defective circuit or unplugged/ Defective sensor
14) IAC (Intake Air Control) Valve- Defective circuit or unplugged / Defective sensor
15) Ignition Output Signal - Missing or defective ignition output signal
16) Fuel Injector System - Defective circuit or unplugged/ Defective fuel injector
17) VSS (Vehicle Speed Sensor) - Defective circuit or unplugged/ Defective sensor
19) Automatic transmission lockup control Solenoid Valve- Defective circuit or unplugged/ Defective solenoid. A/T Only.
20) Electronic Load Detector - Defective circuit or unplugged/ Defective sensor
21) VTEC Solenoid Valve- Defective circuit or unplugged/ Defective solenoid
22) VTEC Oil Pressure Switch - Defective circuit or unplugged/ Defective switch
23) Knock Sensor - Defective circuit or unplugged / Defective sensor
30) Automatic Transmission Signal- Defective circuit or unplugged/ Defective sensor
31) Automatic Transmission Signal "B"- Defective circuit or unplugged/ Defective sensor
41) Primary Oxygen Sensor Heater- Circiut malfunction
43) Fuel Supply System - Defective or malfunctioning Fuel Supply Sytem
45) System too lean or too rich - Malfunction in the fuel monitoring systems
48) LAF (Lean Air Fuel) sensor - Defective circuit or unplugged / Defective sensor
54) CKF (Crankshaft Speed Fluctuation) sensor- Defective circuit or unplugged / Defective sensor
61) Primary Oxygen sensor circuit- High/ Low Voltage, Or slow response
63) Secondary Oxygen Sensor circuit- High/ Low Voltage, Or slow response
67) Catalyst System Efficiency Below Threshold- Malfunctioning catalyst system
70) Automatic Transmission - Malfunction with Automatic Transmission Controls
71-74) Random misfire in Cylinders 1-4- Condition present Creating Misfire
80) EGR (Exhaust Gas Recirculation) Insufficient Flow Detected
86) ECT (Engine Coolant Temperature) Circuir Range / Performance Problem
90) Evaporative Emissions Contrlo System - Leak Detected In Fuel Tank Area
91) Fuel Tank Pressure Sensor- Low Input
92) Evaporative Emission Control System Control System- Insufficient Purge Flow
Ask your autoparts store how much the parts are and decide if it has a point to even do it, its a 19 year old car. You should also ask if that employee works on the side and would do it for you, if you aren't comfortable.
Mar 01, 2010 | 1991 Honda Civic
Hello, I have a 1.5 ton rudd ac/heat pump
Your outside unit is not defrosting. You need to call a service tech to check it out. Defrost board sensor or low on gas. Also you amy have an outside tstat that is not working correctly. Rus
Dec 06, 2009 | Ruud UAMB042 Air Conditioner
I am looking for specs, specifically the RLA, on a Carrier Model 48LH006600(?)-- not sure about model #, nameplate data is totally faded!
It will tell you on the metal plate on top of the compressor, or sticker what the R.L.A.are and the L.R.A's are. If you cant read them, try and get what information you can from the compressor, like the name, Tecumseh, Copeland scroll, ect, The 48 would be the tonnage, 4 ton, or 60 a 5 ton unit. You should have enough of the model number for a air conditioning wholesale parts house to tell you this. we deal with this in the field daily.
Good Luck, Shastalaker7 I hope this helps you.
Nov 06, 2009 | Humidifiers
Electronic Engine Control System
It means you have a computerized system management problem. An electronic sensor component has either failed, or a condition has occurred that has put a sensor out of normal range and the onboard computer is letting you know of it. Any time that light comes on it sets a code that can be read with a special code reader.Most auto parts stores will retrieve the code/ codes for you at no cost. Be very cautious interpreting the codes meaning, because various engine conditions will set a code as well, because the condition will affect what the sensor measures. If you spend the money for the replacement sensor(never cheap) it won't shut the light off.Once installed auto parts stores will not take it back.Also 90 percent of the time it is defective wiring running to the sensor or bad grounding that causes the codes/codes.So unless you have a ton of high priced testing equipment and a lot of electronic engine control troubleshooting experience,you best take in in for service. One more thing. The most common reason the light comes on is a loose or defective gas cap.The computer monitors that too.
Dec 02, 2008 | 1992 Mercury Cougar
Weather King 12AJA4801AH Air Conditioner Logo
110 people viewed this question
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
