Question about Kenyon 14 in. Kiss B23006 Gas Cooktop
Hello - When we place a gas cannister in the unit and fit the black secure cap to expell the gas from the cannister,the unit just completely lets all the gas out of the unit until the refill cannister is empty. Is there an adjustment so the pressure is just right on the cannister and the gas is only expelled when the correct cooker start button is operated? How do we adjust this or is there a service agent in New Zealand that could make this adjustment? Thank you, Kind Regards,
My 5-burner 36" gaggenau has stopped working. I
What the problem is a part in the cooktop that opens to let gas flow to the knobs as soon as they are turned on is bad and no gas coming to surface unit burners. This a safety feature that the German goverment(where Gaggenau is made) requires that part to prevent a gas leak when cooktop is off.
Aug 08, 2011 | Gaggenau 36 in. KG 291 Dual (Electric &...
I have acquired a Rosiers hob with 3 gas rings and 1 electric, but 2 of the gas fittings are missing is there any chance of getting new ones . I think the model is the Tologne The rings are the med and...
hello there, the model name does not match any of our documents or any documents online. Please check your unit for the model number to enable us get the parts list to determine the part number. The gas rings are usually available for sale although most of the time gas rings from other makes would fit but lets see if we can get the exact ones for your unit. Please furnish me with the model number.
Hoping to hear from you soon.
Thank you for visiting FixYa.
Aug 06, 2011 | Cooktops
I need 4 replacement knobs and I cannot find them!! Please help
Hi and welcome to FixYa, I am Kelly. I am assuming that your model number is MGC5430 as listed in your post. If not use this link to find them by entering your model number:
(just note that there are 2 to 5 digits missing from your model number)
See this page:
It brings up the following models:
arrow_link.gif MGC5430ADB SURFACE UNIT- GAS arrow_link.gif MGC5430ADC SURFACE UNIT- GAS arrow_link.gif MGC5430ADQ SURFACE UNIT- GAS arrow_link.gif MGC5430ADW SURFACE UNIT- GAS arrow_link.gif MGC5430BDB SURFACE UNIT- GAS arrow_link.gif MGC5430BDB20 36`` GAS COOKTOP arrow_link.gif MGC5430BDQ SURFACE UNIT- GAS arrow_link.gif MGC5430BDS SURFACE UNIT- GAS arrow_link.gif MGC5430BDS20 36`` GAS COOKTOP arrow_link.gif MGC5430BDW SURFACE UNIT- GAS arrow_link.gif MGC5430BDW21 30`` GAS COOKTOP
I used the MAYTAG MGC5430BDB20 as a reference and the BLACK knob is item 6 this link: Detailed view is here: If you need more assistance please respond with a complete model number and I will use other sources to loate your knobs. Thanks for choosing FixYa, Kelly
Jan 05, 2011 | Maytag MGC5430 Gas Cooktop
My gas glass cooktop keeps clicking. I unplugged the it and left it overnight. When I replugged it the next day it still continues to make the clicking sound. It is driving me nuts! Two days ago my...
That was a really smart idea to unplug your cooktop and let it dry out. Many times that fixes the problem, however, if the problem returns as in your case it is time to replace the wire harness. Their are 4x switches associated and directly under the 4x burner knobs. Moisture can case a short and send a false single to ignite the burner when nothing has been turned on. Take a look at this picture from the link. Number 12 is the wire harness that has failed.
You can purchase this switch by typing in the model number on a appliance parts website and doing a search.
If you are handy here are some general steps to remove and replace the bad igniter/switch harness.
  1. Take off all the grates and burner caps
  2. Unplug the unit and turn off the gas line
  3. Un-screw the 2x screws on each burner
  4. Remove burners and knobs
  5. Lift up on the cooktop cover separate it from the burner box
  6. Pop off the wire harness switches one by one and observe the way it comes off
  7. Place the new wire harness into place and snap in switches then connect wires
  8. Reinstall all components
Fasten everything down and retest unit. This job should take around 45min to 1hr to complete.
Please rate me "4 thumbs" if this free answer was helpful to you. Always the best of luck!
Dec 16, 2010 | KitchenAid 31 in. KGCC505 Gas Cooktop
One gas cooktop does not light, no gas smell
Hello Liz. The most common reason for the problem you are experiencing is greasey dirt in the burner. Use a small brush, some fine wire and some degreaser to clean up the burner. Then let it dry overnight and try it again. If it still won't start, you will have to replace the ignitor.
Nov 28, 2009 | Thermador SGS36GS Gas Cooktop
Cook top burner knobs all 4 not able to turn
Just to be clear, non of the 4 burner controls/knobs will turn ? You are familiar with this unit are you ?
Typically you must push down and turn to activate them.
Let me know if that is not the solution.
Good Luck :)
Oct 29, 2009 | Gaggenau 23 in. KG 260 Gas Cooktop
Viking pro 6 burner cooktop igniter won't stop clicking after lighting on two of the burners
Do not attempt if your stovetop is hot, you will get burned!!
This is an easy fix, the problem is your burners aren't lined up properly. Remove the iron grates (what your pots rest on) and the burner cap (the round black top on the burner) and finally the burner base (the round golden colored piece resting on the stainless stovetop). If you flip the base over you will see that it is keyed, meaning there is a grove that fits the indentation on the stove top. When you replace the base make sure to line the grove up with the indentation. If it's not flush with the stove top, slowly twist the round burner base until it falls into place. That's it!
Jul 09, 2009 | Viking Cooktops
Romvoing the top of my Whirlpool Cooktop
well usually you have to remove the knobs. thentake all of the caps off of the burners. sometimes there are scres that hold the burner caps on. make sure you turn the power off. Then after you have done this the glass should come right off. If not there may be screws under the cooktop. Do these first steps and let me know how it goes.
Jan 18, 2009 | Jenn-Air 30 in.JGD8430ADS Gas Cooktop
Need to know part nos. of gas burners and blackcaps, PLEC36S9ECA
try to bring the small part wen the place the burner cup(black cap) in the store wat brand u have also use other brand but bring it to put it in actual.
Nov 28, 2008 | Frigidaire PLGC30S9EC Stainless Steel Gas...
Gas Hob Flame
Tha sounds to me like the air mixture nedds to be adjusted on the stove, It's not difficult to do, just rotate it until the flames loose the yellow or your pans will be stained with soot.
The should be by the fittings (convertion fittings), you know?
LP Gas to Natural Gas or Natural Gas to LP Gas.
Hope this help
Eddie Rentas
Tupper Lake NY
Jul 30, 2008 | Cooktops
Open Questions:
Kenyon 14 in. Kiss B23006 Gas Cooktop Logo
112 people viewed this question
Top Kenyon Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kenyon Cooktop Expert? Answer questions, earn points and help others
