Question about Keurig B70 Coffee Maker
My Keurig shuts off after making a few cups... If i fell the reservoir with water and it is heavy enough, it does work, but as soon as a few cups are made the keurig shuts off.
  • 40 Answers
Is the Auto OFF on?
Posted on Oct 07, 2010
Keurig B70 automatically pumps water when turned on
When you purged the lines or tubes retained debris and need full purging and flushing.
May 30, 2012 | Keurig Platinum B70 Coffee Maker
My Keurig will not stay on long enough to brew even one cup of coffee. The automatic shut off is on the off position. It only stays on seconds.
When is the last time it was cleaned? That's usually the issue & the quickest fix. If the Keurig gets lime/calcium build up on the internal components it will ignore whatever has been programmed into it & just keep cutting off or keep making partial cups. Run some white vinegar thru it - fill the reservoir with a strong vinegar/water mix, remove any kcups/my kcup, also remove the carbon filter ( fyi - that's not going to eliminate any lime/calcium in your water - it's just to eliminate any bad tastes/odors) and "make" how ever many cups it takes to empty the reservoir. Depending on the build up - you may need to do this 2 or 3 times. Also run about 2 more reservoirs of just clear water to help rinse out the vinegar mix (otherwise your next cup of coffee will not be what you expected).
This should eliminate your problem & should be done every 2-3 mths. Good Luck.
Jul 07, 2011 | Vacuums
Keurig B70 won't stop cycling water. it just keeps draining the resevoir. Water is cold, not heated.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Feb 02, 2011 | Keurig B70 Coffee Maker
I have a two month KEURIG Platinum 10 cup coffee maker. I used filtered water from my frig, soon discovered white flakes swimming in it. Today mysystem said De Scale, will notadmit water from...
Try passing a fine wire back up through the water inlet that punctures the K cups. Drain most of the water from the reservoir and add white vinegar. If necessary, add enough water to clear the low level light on the panel. Hit the start button, and collect a cup of whatever comes out. Either filter the water and re-use or dump out. Continue using the white vinegar, letting it work in the reservoir and internal pot for ~10 minutes between cycles (cups). It will take at least one hour to clean it out and flush it well. Once you are making a cup's worth of water at normal speed and time, dump the reservoir on the side, and refill with clean water. If the reservoir has a bit of a slimy feel inside it, wash it thoroughly before re-installing. (You should wash the reservoir probably weekly, or so, depending on you water).
Flush clean water through the system, dumping each cup produced, until all traces of the vinegar are removed.
Best regards,
--W/D--
Jan 17, 2011 | Keurig B100 Coffee Maker
Keurig will work only part time. Sometime will make one cup of coffee and then will not draw in the water for the second cup and shut itself off after 1 or 2 minutes. Has plenty of water in it just won't...
The water reservoir tank probably isn't seated properly. Try wiggling the tank a bit and if that doesn't do the trick, completely remove the water reservoir and then replace it. Once it's seated properly, it should start drawing water and brew as designed. This seems to be a design flaw with this particular model, so periodic adjusting of the water reservoir may be necessary to ensure it is seated properly if your problem persists. Hope that helps! Best of luck...
Jan 16, 2010 | Keurig B60 Coffee Maker
Keurig B70 Coffee Maker Logo
190 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
