Question about Toshiba REGZA 47HL167 TV
My toshiba 47hl167 screen not on and yellow led light keep flashing event i reseted with power botton but it still do same thing
    President:
  • Toshiba Master
  • 1,114 Answers
If you have the manual, check in the troubleshooting section. The flashing light is code for what the problem is. If you don't have the manual, reply to this solution and I will pull it for you. if you still need help, post with all products connected to the system etc... Surge protection? etc. Hope this helps get you started, and if needed, I will help you further
Posted on Sep 27, 2010
  • Toshiba Master
  • 8,457 Answers
Power supply board have problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
The yellow LED on my Toshiba 32CV510U flash all the time and TV won't turn on
check some leak or bulged capacitors at the power supply board then replace it.
Oct 02, 2012 | Toshiba 32CV510U LCD TV
What's your problem? won't turn on..... yellow/orange light continually flashes three times...
Toshiba Regza 37in - 37HL17
TV will not turn on - Yellow power ind. Light blinks three times...
Fixed with a firmware update (hard to believe, but true). Search Google for a file named: 2007SEN069.zip (don't worry if the page you find it on doesn't mention the 37HL17 - it worked fine). Unzip the file, and copy the 3 folders and 3 files to the root of a small SD card. The SD card MUST be 2GB or less in size (I used a 1GB card), and it MUST be formatted with FAT-16 (not FAT-32). Mine was pre-formatted as FAT (FAT-16). The SD port is on the back of the TV behind a cover plate near the power cable. You do NOT need to remove the back cover of the TV, just the small cover plate (1 screw). UNPLUG the TV; remove the cover plate; insert the SD card (prepped as explained above); Plug in the TV; Watch the yellow lights blink, then turn blue, then go dark; UNPLUG the TV; remove the SD Card and replace the cover; Plug in the TV; Yellow lights will blink a few times (this is normal); when blinking stops, turn on the TV and you should be good to go. :-)
Pictures attached are from a Toshiba software upgrade bulletin I found online.
09adb97e-8925-4d59-b218-7443a6e64989.png 82ea33aa-2353-4e13-a5db-8be13ba85711.png
Aug 06, 2012 | Toshiba Regza 37HL17 37 in. LCD TV
REGZA 47HL167 TV is difficult to turn on. when powered on the amber lite flashes 3 times then pauses for 1 second then repeats the 3 amber flashes. If I keep pushing the power button on the side,...
3 flashes of the led light at the front panel is means that the unit is in booting process. The symptoms you've mentioned is caused by faulty electrolytic capacitor in the power supply section.
Look for faulty capacitor with bulged, dome at the top and then replaced it with same ratings. If you have a capacitor checker, it will make you more easy to identify the faulty capacitor without a physical indication of fault.
http://www.youtube.com/watch?v=oDGjWOabJ2E&feature=related
http://www.youtube.com/watch?v=YCSNWi3UHf4&NR=1&feature=fvwp
Oct 07, 2011 | Toshiba REGZA 47HL167 TV
Led light keeps flashing orange, can get some sound.
It sound like you have a bad capictor on the power supply. If you take the back off your tv, you will see little round componets. These are the capictors. The tops should be completely flat. You may need to put your finger on the top to feel if they are bubbled at all. Find the one that is bubbled and replace it
Jun 11, 2011 | Toshiba REGZA 47HL167 TV
Had my toshiba regza 42rv530u since March 2009 a few days ago it cut off and will not come back on, the yellow light flashes at the bottom of the tv, 3 blinks pause 3 blinks etc....
try resting your tv. power off it press and hold av select botton and then power on your tv wait few minutes and it will rest your tv.... if not used the same wy holding menu botton instead.
May 30, 2011 | Toshiba REGZA 42RV530U 42 in. LCD HDTV
Toshiba regza 47" flat screen last night i was
Check your power cable. Unplug it from both ends and plug it back in
Mar 05, 2011 | Toshiba REGZA 47HL167 TV
TV does not turn on. There is a yellow blinking LED light on the right lower corner of the TV
Disconnect your TV. for few minutes (10) then plug it back on, turn it on using your remote control, wait few seconds, until the light bulb gets its normal intensity, if you can not see anything, but there was a clicking noise,then you bulb it's burn out
Dec 23, 2009 | Toshiba REGZA 47HL167 TV
I have a toshiba 42HL167. Love it but recently when the power is off iget a repeating blinking yellow light. Blinks 3 times pauses blinks 3 time pauses blinks either 2 or 3 times then stops for 25 seconds...
Yes. The Yellow LED blinking 3 times is a normal boot-up, but if it keeps doing it -- it needs the firmware "update" (which is more like a reload because it got corrupted.) The problem is, no one talks about how to do that. (there is a PDF and firmware on toshiba's website, but it lacks some crucial details.)
My friend gave me his 42HL167 after this problem started after a power event during a storm and I managed to fix it by reloading the firmware.
I posted instructions on my website at:
http://www.benjammin.net/www/pages/techtips/Toshiba-Regza-42HL167.html
Once I figured out some of the facts, it was a breeze...
Nov 06, 2009 | Toshiba 42HL167 42 in. LCD Television
Tv won't turn on at all
Hi
the best thing you do is to go back the unit where it you buy because this is under warranty
Thanks!
Jun 09, 2009 | Toshiba REGZA 47HL167 TV
Toshiba REGZA 47HL167 TV Logo
407 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
