Question about Sony PlayStation Portable (PSP) Console
A problem with my psp
I put a sticker on my psp and when i tuk it off white stuff was left beind it and i put finger nailpolish to gover it up and it look nasty
    Problem Solver:
  • 41 Answers
Use lighter fluid. It works perfectly. Rubbing alcohol also works well, but lighter fluid works the best and won't take off paint or anything on your psp. Just be sure not to let any lighter fluid get inside the psp. Put some lighter fluid on a paper towel or cloth and rub the sticky adhesive off.
Posted on May 24, 2008
Why the nailpolish is cool when we applied to our nails
Nail polish contains ether which is need to dry the paint you are applying to your nails quickly. This evaporation of the ether make it feel cool on your finger tips.
Feb 04, 2011 | Health & Beauty
Wisdom required
If you can find the C-below-middle-C ?
Put your small finger on C,
your next finger on the next white key: D,
your middle finger on the next white key: E
your index finger on the next white key: F
your thumb on the next white key: G
Lift your fingers away from D and F -- to keep this simple -- all we did was identify the D and E and F and G keys, relative to the C key.
Press C and E and G (small, middle, thumb)
to play a "major" chord in C.
Move your fingers "up":
C to D, E to F-sharp, G to A,
and play a "major" chord in D.
D to D-sharp, F-sharp to G, and A to A-sharp,
and play the chord in D-sharp (usually called 'E-flat').
D-sharp to F, G to A, and A-sharp to C,
and play the chord in F.
Move your fingers "up",
F to G, A to B, and C to D,
and play the chord in G.
Go back to the starting position (C-E-G),
and move "down": C to B-flat, E to D, and G to F,
and play the chord in B-flat.
So far, you have C-major, D-major, E-flat-major, F-major, G-major, and B-flat-major.
There are more chords, but most pop-music is in one of these keys.
Give it a try.
A lot of left-hand stuff is just the small-finger and thumb, omitting the middle finger, e.g., C&G,
to avoid a too "muddy" sound.
Or, "stretch" your hand: C-and-G-and-the-next-higher-C.
Jan 14, 2010 | Yamaha Full-Size Keyboard
How to install new printhead
first You need to open the printer access door of your printer for you to able see the ink cartridges and the printhead. Now if the printhead already on the center remove first the ink cartridges. Now without the ink on the printhead you should see a white sticker or bulleye sticker on the middle of the printhead, Now On that sticker put your index finger upside down then move your index finger upward until you feel a latch or a tab that you can press, just press and pull, i guarantee you it wil removed.
Now if the printhead is removed put your printhead on the carriage then put the printhead all the way in until you hear a click sounds.
Note: Just take a time the latch or a tab on the printhead is hidden it will take a time for you to remove it especialy if this your first time to do it. That's base On my experince
Nov 13, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Change print head on kodak 5300 printer
Are your asking how to replace the printhead?
First you need to turn On the printer and open the printer access door where you can see the Ink. Now wait for the Printhead to stop into the middle then remove the ink cartridges both ink and black., Now to rmove the Old printhead you need to press a Tab which is hidden on the printhead., heres the step to remove the printhead which for me the hardest part
-Point your index finger on the white sticker that attached on the printhead or the bullseye sticker(If theres no white sticker on the print head just put your index finger on the middle of the printhead)
-Now your index finger is on the middle of the white sticker right? Move your index finger upward unti you feel a latch that you can press., Just press and full then your printhead wil be removed
-Now Your ready to insert your new printhead
-To insert new printhead just put the printhead on the carriage of the printer and gently press the white sticker of your new printhead make sure that you will hear a clicking sounds then put your cartridges back
-Theres some instances that the printhead will not stay on the middle., it keeps on staying on the right or on the leftside for you to solve that heres the step
-Turn on the printer open printer access door and wait for the printhead move into the center and if the printhead its on the center immediately unplug the power cable so the printhead will not move.
GudlucK
Nov 06, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
How to install a new printhead in 5500
GudlucK
Nov 05, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
How do I change headlight bulb . Left side low beam headlight bulb is blowed . I have the new bulb and just need to know where the lever or turn object is to remove from the back side so I can change the...
Reach beind the headlight and just unscrew the cap that holds it in. However don't touch the new bulb with your bare fingers or you will drastically shorten the life of the bulb.
Oct 16, 2009 | 2003 Chevrolet TrailBlazer
I have bought a new faceplate for my psp and I don't know how to take off the original.
Since your replacing the faceplate only, only remove the screws on the outside border. not the two on the right side of the battery.
* The bottom silver screw (located on the bottom part, opposite the top part, which has the USB port)
* The top left black screw (underneath the battery)
* The bottom left black screw (underneath the battery and the left side of the warantee sticker)
* The top right screw (located on the back side of the psp in a hole on the outer casing)
* The bottom right screw (located on the back side of the psp in a hole on the outer casing)
Then do the reverse to put it back together.
Dec 18, 2008 | Video Game Consoles & Games
I want to replace the joystick
nah, theres not really a trick to it, apart from sony tricking you into voiding your warranty. if you want to change the joystick, your gonna have to remove the faceplate. get a small phillips head screw driver. the first thing you should do is put the psp face down on a flat suface. next remove the two screws on the right of the console, and the one on the very bottom on the underside of the console. now, take the battery out and there should be two stickers underneath one black scrwe and one silver screw. remove the black one. now, you only have one screw left, but problem is its under neath the warranty sticker and if you remove, you remove your warranty. it is possible to take it off using a hair dryer, just so long as you dont damage the sticker. once you have the sticker off, the faceplate will just pop off so just take out the screws on the back of the joy stick, slap your new one in, put it back together and away you go!
Mar 16, 2008 | Sony PlayStation Portable (PSP) Console
Getting a memory Pro Duo into Psp
look to the left theres a tab (made up of rubber )open it then push the memory stick pro duo into it lightly if it doesnt take it put it the other way until you hear a click.
Dec 09, 2007 | Sony PlayStation Portable (PSP) Console
Power problems
Hi Gohan102,
Open the battery compartment, and remove the battery.  Look at the bottom inside corner for a little square sticker with has marks on it. is it dark or light,  If it is dark, your PSP has come in contact with moisture. I suspect that your PSP has gotten wet or damp.  If the sticker is dark, you need to keep your battery out for about 2 days, and keep the UMD door open and the whole PSP kept in a dry environment.  Try it after 2 days of drying to see if it is recovered. Good luck Gohan....
Oct 17, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
