Question about John Deere Garden
I have a John Deere 2E leaf blower. Lately it has been hard to start but runs fine once it is up and running. Would it help to adjust the H or L screws on the carb?
    Scholar:
  • 71 Answers
The H (High Speed) and L (low Speed) should not typically need adjustment. What happens is the diaphragms get stiff and do not operate efficiently. If the unit is over 5 years old and/or the fuel is not completely drained with the unit run dry at the end of the fall, then I would suggest replacing the diaphragms within the carburetor. This along with spark plug change, air filter cleaning and a check of the muffler to insure it is not clogged is considered a basic tune-up.
Posted on Sep 27, 2010
How do I replace the primer bulb in my JOhn Deere leaf blower?
well model number would help here but if its carb mounted its usually help on by 2 or 4 srews
Oct 11, 2013 | John Deere Garden
I have a Husqvarna 125 blower. Where do you start adjusting the high/low needle valves. Do you run them in and then do the 2,5/2 turns you mentioned. They are not set from the factory. Had trash in the...
2 needle adjusters? one should be marked L & the other H.I hope you removed them for cleaning. Re-install them turn to the right until they stop.Then back them out [ counter clock wise] 1 & 1/2 turns is a good guess to start from. try to start,you will need some patience for this as it is trial & error.Keep tweaking them until it runs. once you get it running the one marked L is low speed or Idle H is the high speed. Tweak them while its running for best performance. I just went through this yesterday with a john deere 2 stroke and ended up at about 1 turn out from full stop on the needle adjustments. I also did this with the air filter off so I could see when flooding was happening. When it did I had some compressed air to blast the excess fuel away. good luck
Oct 04, 2013 | Husqvarna Garden
What is the fuel/oil ratio of a john deere BH25 leaf blower?
The BH25 that I use from my friend runs on STRAIGHT gas, it is 4cycle. Do NOT put a fuel mix into it!! It has separate oil system.
Nov 24, 2012 | John Deere Garden
I have a John Deere hand held blower. I can't get
Your adjustments to the carburetor may make it worse.
Plus if the fuel mixture is over 30 old, I would replace it.
Manufacturers have told us this year any gas over 30 days old is considered bad gas and needs to be replaced. I would try some fresh gas(from the station) and some new 2 cycle oil at 40:1 Ratio(3.2 ozs 2 cycle oil to 1 gal of gas).
Good day.
Nov 07, 2009 | Garden
Manual for john deere leaf blower
you have to order the Manuel from john deer or a john deer dealer
Oct 12, 2009 | John Deere Garden
My 1997 john deere just dont run as fast and hard
check your throtlle cable ... it is very possible that if the engine runs fine just doesn't run as fast as it used to that you throttle cable has slipped in the clamp and you need to adjust it ...
Aug 19, 2009 | Garden
I have an eztrak john deere 445... quits.
The vent in your gas cap is plugged, it's a very small hole right in the center.
Mar 30, 2009 | John Deere 42 in. EZ Trak Bagger
Mightylite 26 leaf blower
have you tried changing the air filter and spark plug?
Nov 20, 2008 | Homelite Consumer Products MightyLite...
Garden Logo
488 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
