Question about Amana PTH123B25AJ Heat Pump Air Conditioner
Blows cool air
My unit heats fine but occasionally continues to blow cool air for several minutes after heat cycle. The information with my unit doesn't provide much technical information about how this works.
Can anyone help?
    Scholar:
  • 54 Answers
This is normal. To maximize the units efficiency the fan continues to run until all the heat from the coil is pasted to the circulating air.
Posted on Jun 12, 2008
Amana Wall unit blows cold air before heating
the unit works by chilling air and the byproduct is heat in the compressor, this is used for heating in the winter and then reversed in summer to blow cold air. It has to blow cold and warm up before it can blow heat.
Mar 17, 2017 | Amana Heating & Cooling
LG 8008R compressor runs one minute then fan blows 3 minutes
You need to have an AC tech come out and do some preliminary testing on this.
May 12, 2017 | LG Heat cool Window Air Conditioner
My ducted heating continually blows cold air thru
Well, if need be, turn the breaker off. Turn it on when you need heat. Sounds like the fan relay is sticking or something if that sort. Is the tstat fan selector on auto?
Jun 17, 2017 | Heating & Cooling
Intertherm electric furace
It sounds like the coils are fine if you are getting heat. They are likely shutting down from overheating after being on for awhile. Check your filter and overall air flow to make sure it's adequate.
Mar 03, 2009 | Intertherm P3RA-048K Air Conditioner
MR.Slim heater - NO HEAT??
make sure you have freon in your system. they act as a heat pump which does A/c as well s heat. without freon you want have cooling or heat.
Jan 17, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Blower Motor cycles on & off
whats happening is thje heat exchanger is cooling off and cycling the fan off this is a normal occurance whenever the unit is first turned on.
Dec 22, 2008 | Heating & Cooling
Thermostat ?
The Air conditioner are good only the adjustment of thermostat are the problem, select the thermostat in lower #3 you observe the thermostat will off in such time temperature reach to #3 If you full adjustment the compressor will not off.
In fan selector the compressor will autamatic off because no connection attached fan only .
Jan 05, 2008 | Kenmore 73089 Air Conditioner
Amana PTH123B25AJ Heat Pump Air Conditioner Logo
182 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Shehu Pro
Shehu Pro
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
