Question about HP Computers & Internet
I am trying to hook up an hpxl953 desktop and it just beeps... one long and two short. Any ideas?
  • HP Master
  • 27,725 Answers
Make sure your ram is properly seated
the beeping sound is the post system searching for your hard drive and other connected devices
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
good luck
Posted on Sep 27, 2010
My hp p6536f-b mskes 1 short andcone beep when i turn it on..any ideas why?
Beep codes depend on BIOS version.. for your machine, go here:
http://support.hp.com/us-en/product/HP-Pavilion-p6536f-Desktop-PC/4162263/model/4260057/document/bph07107
Near the bottom of the page you will find "Beep and LED code descriptions" along with the different bios suppliers
Hope this helps
Sep 25, 2013 | HEWLETT-PACKARD Pavilion p6514f PC Desktop
My hp-compaq dx2300 microtower restarts automatically when working. It is installed on win xp sp3. Please let anyone help if solution is known.
Hi names Rui, i question for you does your PC give a beeping sound when you turn it on? if does can you tell me how many beeps it gives?
if it give a designated number of beeps this might be the problem i will give you a chart so you can differentiate the warning beeps you hear.
warning beeps:
1 Short Beep DRAM refresh failure
2 Short Beep Parity circuit failure
3 Short Beep Base 64k RAM failure
4 Short Beep System time failure
5 Short Beep Process failure
6 Short Beep keyboard control gate A20 failure
7 Short Beep Virtual mode exeption failure
8 Short Beep Display memory read/write test failure
9 Short Beep ROM BIOS checksum failure
10 Short Beep CMOS shutdown read/write error
11 Short Beep Cache memory error
1 long, 3 short Beep Conventional/Extended memory failure
1 long, 8 short beep Display/Retrace test failed
hope this will determine the problem if none of this warning beep is heard try reseting the power botton in you PC cause sometimes the power botton will loosen cause of continuous use of the botton.
hope this will help you.
Jul 20, 2011 | HP Compaq dx2300 Microtower - RT950UTABA...
Was trying to hook up hp printer. when i plugged
HP Printer driver problem. Disconnect Printer and see if the computer boots up properly now.
Mar 09, 2010 | HP Compaq Presario 6320US (DA202A#ABA) PC...
Hi, I have a Gateway831GM. When I try starting it, it beeps three times with the fan running at a high rate. Nothing else happens...nothing on the monitor. I've tried several times to turn it off and...
Hi, those beeps mean something is wrong, perhaps one of the cards inside the box have come out of their slot partially? If you feel able, unplug the power and make sure all of the cards and memory chips are firmly seated, then try again
Jun 22, 2009 | Gateway 831GM PC Desktop
My sony vaio makes a beeping sound one long and to short beeps and it wont turn on
One long beep and two short beeps usually means a video problem. If you have an add-on video card, try replacing it with a new one. If you are using an on-board video, go into the bios and turn it off. then shut down & install an add-on card.
Feb 22, 2009 | Sony VAIO VGC-V617G PC Desktop
Beeps on startup
plz check with the RAM...
open the cabinet... and try taking out the ram and clean it with a smooth cloth... fix it back again...and start your computer...
this should resolve your problem...
Jan 13, 2009 | Microsoft CyberpowerPC Gamer Infinity 7511...
Spilt a drink
I don't know if I can solve this here. But the beeping noise is your pc trying to tell you what is wrong with it. Somewhere there are pc beep codes. http://www.pcstats.com/articleview.cfm?articleID=1223 If these can't help you just put "computer beep codes" into google. Here they are:
Beep Code: Description of Problem: No Beeps Short, No power, Bad CPU/MB, Loose Peripherals One Beep Everything is normal and Computer POSTed fine Two Beeps POST/CMOS Error One Long Beep, One Short Beep Motherboard Problem One Long Beep, Two Short Beeps Video Problem One Long Beep, Three Short Beeps Video Problem Three Long Beeps Keyboard Error Repeated Long Beeps Memory Error Continuous Hi-Lo Beeps CPU Overheating
Dec 08, 2008 | Compaq Presario 5000 PC Desktop
Upgraded RAM in D51C, from 256 to 2GB, got 1 short beep, 2 long
Remove all the memory, start up, it will beep. shut down, place in one memory and try starting up. IF it still beeps count the beeps short and long and let me know.
Thank you
iWillFixIT!!
Nov 15, 2008 | Compaq Evo D500 PC Desktop
Acer Aspire T690 startup problem
MEMORY PROBLEMS Hi, FOR LONG BEEPS, ONE SHORT BEEP IN AN ENDLESS LOOP, BLUE SCREEN OF DEATH AT STARTUP Try using Memtest 86+ http://www.memtest86.com/ to diagnose your memory problem. You can also try the following methods. Turn off power, Unplug. Remove the cover of your PC. Remove the memory from the Motherboard. Note on the locks! Clean the memory contacts with an eraser yes that's right a rubber Pencil eraser. It should be shiny gold. Reseat your memory to the motherboard and Test! ====================== If you are having trouble with Newly bought items save your self from headaches by returning them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
Sep 19, 2007 | Acer Aspire T690 (AST690UP820A) PC...
Computers & Internet Logo
27 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
