Question about Lexmark X2600 InkJet Printer
I am trying to get my scanner to working. - Lexmark X2600 InkJet Printer
  • 3,866 Answers
Mosr likely its the drivers you need to go to www.lexmark.com download the drivers for he scanner to work correctly, the driver should be there if that does not wokr and the drivers are downloaded the it could be hardware issue.
please update me with any questions you
Posted on Sep 27, 2010
My HP 5370C scanner no longer works. When I tried to scan, a blank white image appeared. Tried a few more times, same thing. The next day I tried scanning again a pop-up appeared indicating ,no scanner...
The problem is in the connection cable, Check the cable that connects your scanner with your computer, If still not working, try replacing it with a new one.
Jan 26, 2010 | HP ScanJet 5370C Flatbed Scanner
Try to copy and get scanner failure motice
scanner failure is a hardawre problem. try to copy again and check if the scanner light is on. once the scanner light is not working then try to return your printer in the store that you have purchased it.
Oct 20, 2009 | HP Officejet 5610 All-In-One InkJet...
On the CanoScan 5000 I try to open the Scanner and there is a msg. that says "cannot communicate with scanner...check connection etc." This is not unusual with this lousy scanner. What usually will fix the...
Try using other application aside from the canoscan. Try to use Paint, you just click on File then from scanner. If it doesn't work, check the scanner itself, try to plug it in on another power outlet, if you are using a power surge try to unplug it and directly plug it in to the wall. You should notice the light on the scanner. If it is not litting up, you need to have the scanner serviced due to defective bulb
Sep 05, 2009 | Canon CanoScan 5000F Flatbed Scanner
I have a uniden ubc73xlt handheld scanner,can't program channels, keeps saying locked out, have tried to unlock as per instructions but not unlocking.
Try a master rest:
If the scanner's display locks up or stops operating
properly, you might need to reset the scanner.
Caution: This procedure clears all the information
you have stored in the scanner. Before you reset the
scanner, try turning it off and on to see if it begins
working properly. Reset the scanner only when you
are sure it is not working properly.
1. Turn off the scanner.
2. While holding down 2, 9, and Hold, turn on the
scanner. It takes about 3 seconds to initialize
and CLEAR appears.
Feb 22, 2009 | Uniden BC72XLT Handheld Scanner
After running full system recovery I tried to reinstall my printer and scanner. I reinstalled my printer (HP Deskjet 870ces). Then tried to reinstall HP Scanjet 5100c on a machine running Windows XP Pro....
Some time printers and scanners conflict. Try this, uninstall both printer and the scanner, then install the scanner first and try it to see if it works. Then install your printer. If it doesn't work let me know I'll walk you through. Good luck :)
Feb 21, 2009 | HP Office Equipment & Supplies
Scanner problem
Try uninstalling and reinstalling the scannner. Scanner's can be tough. Try disconnecting USB cable and reconnecting too. How recently did the scanner work? Try reinstalling the scanner software/driver. Also see if you can trouble shoot by right clicking on scanner icon from control panel, scanner.
repost if none of these work. thanks.
Sep 02, 2008 | Sharp AL 1631 Copier
Scanner has stopped working
When I had the cable that came with the printer connected to the scanner, and the cable that came with the scanner connected to the printer, the scanner didn't work.
Changing the cables changed everything.
Oct 15, 2007 | Canon CanoScan LiDE 70 Flatbed Scanner
Scanner
Usually this is a problem with old (parrallel port ) H.P Scanners. Shut down your PC, remoce power of the scanner, remove the data cable of the scanner both at PC as well as at scanner end. Reboot the PC. reconnect the data cable and then the power cable ofthe scanner. Try using it. If you have win98, it should work now. If Win XP_P, reboot your PC, it should work. If the problem persists, try re-installing the drivers.
Oct 07, 2007 | Office Equipment & Supplies
Lexmark X2600 InkJet Printer Logo
37 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
