Question about Hampton Bay 24002 Ceiling Fan
The pull cord came out to turn the fan on. How can I fix?
    President:
  • 512 Answers
Home depot sells hampton bay fans. They also sell replacement switches for these fans. remove switch and bring into store to match with right one,.
Posted on Sep 28, 2010
How to fix a ceiling fan light fixture?
If the pull chain doesn't make a clicking sound when you pull it, you need a new switch.
May 10, 2016 | Hunter Dryers
Dimplex bathroom fan heater cord problem
take the cover off and clean the inside and were the cord is and use some wd 40 turn of the supply first and that should loosen it for you
Jan 06, 2014 | Dimplex Fx20ve 2kw Timer Wall Mounted...
Dimplex Fx20ve 2kw Timer Wall Mounted Bathroom Downflow Fan Heater Pull Cord is stuck
turn of the powere and take the cover off and clean the pull cord and the use a bit of lubricant to keep it free that should loosen it
Sep 24, 2013 | Dimplex Fx20ve 2kw Timer Wall Mounted...
We have a traditional black Hunter ceiling fan. The metal pull broke this morning. I can't turn off the fan or re-attach the pull cord
You can easily fix this. Turn the breaker off that runs the circuit the fan is on. It will likely be a 15 or 20 amp single pole breaker. If you don't know which one it is just turn off breakers until your fan goes off. Look closely at how the fan is assembled and remove the base that the pull mechanism is enclosed in. Them just remove what is left of the pull chain and replace it. They sell the pull chains at Home Depot or Lowes.
Hope this helps.
Sep 13, 2011 | Hunter Heating & Cooling
The speed pull cord will work on off or low, but will not go into medium or high. Can this be fixed? And how?
Yes, that switch can be replaced and is an easy repair. You can find a generic fan speed replacement switch at Home Depot or Lowes. Just be sure you turn off the electricity at the beaker box. Remove the light kit and the lower cover of your fan. The new switch will come with some instructions also. Hope This Helps Fix Ya Up.
Jul 06, 2011 | Casa Vieja Probe White Ceiling Fan
The fan will not work, it is connected to power and the wiring appears to be correct
This may sound silly and you may have done it already ... is the switch on the fan on?
May 30, 2011 | Hampton Bay 24002 Ceiling Fan
I pulled the pull cord right out of it s hole. So I unscrewed all of the screws to fix it but i cant unscrewed the fans screw ????
There should be no need to remove the flywheel (fans?) to repair the starter cord. The starter mechanism should have come free of the left side housing so that everything you need to deal with is in that package. Did the cord break, or just pulled the cord free of the spool inside? If the cord broke, then buy a replacement cord (about 1-meter in length) of the same size and material (no cotton cord). Thread the cord into the spool center where there is a hole for the inside part of the cord and bring the end out of the hole. Melt the cord end, and then tie an overhand knot in the cord. Pull the knot back tight and proceed to wind the cord in a CCW direction around the spool until you have about most of it wound. Pull on the cord to wind the internal spring several turns and wedge the spool so that it won't unwind the spring. Wind the balance of the cord until you have about 8" left--feed that end through the outer hole and into the handle. Melt the cord end, then tie an overhand knot in it. Stuff the knot into the handle cavity and remove the spool wedge. Try the cord several times to make sure the spring pulls it back firmly and allows ample cord pull-out. Hope this helps!
Jan 29, 2011 | Garden
Ceiling fan
mcdevito75 here, You"ll have to remove the cover close to the ceiling to get at the switch, Make sure the wall switch and fuse are out. Note the wire position and replace the switch with 1 from a hardware store. Are you sure that toggle switch is for the lights, as you should have another for the fan. Usually the wakk switch is used to turn the lights on and a toggle switch used to start the fan.
Jul 27, 2010 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Ceiling Fan Light Switch Has Busted
The pull cord light switch you can buy at any lowes or homedepot ( or hardware store) cost will be about 3-6 dollars
Jun 21, 2008 | Hampton Bay 24002 Ceiling Fan
Hampton Bay 24002 Ceiling Fan Logo
379 people viewed this question
Top Hampton Bay Dryers Experts
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
