Question about Jacuzzi Bath Era BK37 959 White toilet bowl and tank
Need new bolts to attach seat to toilet - Jacuzzi Bath Era BK37 959 White toilet bowl and tank
  • 863 Answers
Hardware store will have the bolts you need. Its in the kitchen faucets isle or in the plumbing isle depending on which hardware store you frequent.
Posted on Oct 12, 2010
Kohler Toilet seat bolts stuck
If the bolts are plastic or metal you will need to cut them off and install new ones from new seat or bolt kit there is no easy trick its just an easy cut them off or you could try some wd-40 or nutbuster.
Apr 12, 2014 | Kohler K-3384-2 San Raphael Elongated...
Self closing all in one tolet seat boxed, hidden screws, how to tighten
If you are trying to install a standard toilet seat on a special "smooth sides" toilet, it likely will not work. Most hidden bolt toilets come with a special seat because you cannot get to anything from below. This special seat has a set of expanding style bolts that are attached to the screw that is part of the seat. The plastic expanding bolt goes into the hole(s) on the toilet, and as you tighten the screw on the toilet seat bolts, they expand the plastic part in the hole of the ceramic toilet.
Aug 29, 2013 | Kohler 3386-6 Rialto Skylight Round Front...
The toilet seat looks terrible on the underside and on the top it has the worn look. The price of over $400.00 to replace it is crazy. Is there a way of painting , cleaning up or should I buy a a new...
You should be able to remove an old worn out, toilet seat and replace. Usually its two Plastic Toilet Seat Bolts and two plastic wing nuts under the bowl. Most of them are hidden in a Plastic Cap where the seat attaches to the Toilet Base. You unsnap the caps to see the bolts. Make sure to hold the Wing Nuts underneath or they might just spin.
If its a matter of cleaning something because of neglect. I have recently started using new products that I purchased from www.ChristineFrey.Norwex.biz with great success!
I clean the entire bath room with three products and water!toilet-seat-looks-terrible-underside-2a0cfbtak4y3luwyen1qnfe3-5-0.jpg
Dirty to Clean its simple fast and effective.
The products are: my EnviroCloth, Blue Diamond Cleaner and my toilet brush. If you are like me, I never heard of any of this until I saw a demonstration November 2014 by this person who's website I posted above in this response.
Feb 28, 2011 | Herbeau Charleston, White Toilet Seat &...
The toilet seat is very loose and I can't figure out how to tighten it. Please help! Its about to come off completely Thanks
Usually there are plastic caps that snap down over the bolt head.
Shut toilet lid and get down close with a flashlight.
Seat attaches in two places.
Reach underneath and you can feel two bolts with nuts.
You don't need to see them, just feel with your hand.
The bolt head is covered with a plastic cover.
The cover is added for aesthetic purpose only.
Use small screwdriver or fingernail file or nail or scissors to pry up the cover and reveal bolt head.
Use bigger screwdriver to tighten bolts.
You may have to keep one hand on underside to hold nut while turning bolt clockwise.
Another trick is use hand to push bolt all the way up, and then finger tighten bolt most of the way, and use screwdriver for last few turns.
Tighten bolts good and tight, but don't overdo it.
Bolts will come loose again and you can tighten more later.
Dec 13, 2010 | Bemis 1200 Slow Elongated Toilet Seat,...
I have a toilet which is a one peice. The toilet seat has come loose and the bolts have dropped to the floor. I can not fit the seat back as the pieces that i would use to tighten the seat are on the floor...
In no case would you ever have to pull a toilet to get to seat bolts.My guess is if you take the tank lid off and look inside there youll see the bolts . If not you can buy another toilet seat with new bolts or just get the bolts to fit your seat and tighten it down.Forget about the old bolts unless they become a problem with the flushing of the toilet. Hope this helps
Jun 22, 2010 | Home
Can't find the right toilet seat from standard stores
Grohe does not make toilets. look inside the tank for manufacturer and model number it sounds like a one piece toilet and the seat bolt nuts are in the tank feel around for them.Grohe only makes handles for toilets to match their faucet finishes
Nov 14, 2009 | Grohe 28917ZB0 Oil Rubbed Bronze Relexa...
I have a kohler toilet that needed a new seat.
Now isn't that a trick. Epoxy! The bolts,now studs, must be quite short. Well, glad you got it resolveve. I hope your house has more than one restroom..That epoxy will need a day or two toset up properly. :) Thank you for the reply. We all learn from each other.
Nov 14, 2009 | Kohler 3386-6 Rialto Skylight Round Front...
Broken bolt on toilet seat
your new seat will have bolts and nuts with it.
Jan 11, 2009 | Kohler - Toilet - One-piece - Santa Rosa -...
Jacuzzi Bath Era BK37 959 White toilet bowl and tank Logo
67 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
Donni Steen
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
